Author Topic: 76 CB550F - Oct 2021 - Rear tail light and rebuilding gauges  (Read 29155 times)
Offline KennyRedman
  • 1976 CB550F, Indiana
Re: 76 CB550F - Oct 2021 - Rear tail light and rebuilding gauges
« Reply #150 on: November 28, 2021, 02:47:47 PM »
Tail light bracket looks awesome.  What bike was it listed for?
Found it on eBay here:
https://www.ebay.com/itm/Motorcycle-Tail-Light-Lamp-Assembly-6V-Bulb-Kit-for-Honda-CT70-SL70-XL70-CL70-/265189862846?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=711-127632-2357-0
The plastic light it comes with is super cheap, but the stock or repro 350 fits perfectly.
Offline Alan F.
« Reply #151 on: November 28, 2021, 07:07:07 PM »
That looks really good and really easy, make sure to rubber mount it so vibration isn't an issue and forget about halogen bulbs, they run too hot.
Reminds me of my CB160 light:
Offline KennyRedman
« Reply #152 on: November 28, 2021, 07:26:40 PM »
Ya, will be straightforward. Didn’t think about a rubber mount- would rubber washers do the trick?
Offline Alan F.
« Reply #153 on: November 28, 2021, 07:55:44 PM »
Yes anything will help. Thankfully your bike is a four and doesn't vibrate like crazy.
Offline KennyRedman
« Reply #154 on: November 30, 2021, 08:07:24 AM »
I may have to go a different route or think of a different way to mount the plate. The holes for the plates are about 1/2” too narrow for Indiana plates.
« Reply #155 on: November 30, 2021, 08:21:21 AM »
Could bridge it with a secondary plate that bolts to the plate and then bolts from it bolt to the plate holder. Countersunk screw heads would lessen the standoff.
Offline KennyRedman
« Reply #156 on: November 30, 2021, 09:00:01 AM »
Ya, I’ll have to figure something out because this bracket is too perfect for what I’m looking for. Thanks for the idea.
Offline KennyRedman
« Reply #157 on: October 12, 2022, 08:15:41 AM »
This has been a crazy year so far, and I'm finally getting back finish what I started last year.  I began a new position at my company that I've been with over 15 years, and it's been an immense amount of work and travel.  Things are starting to slow down and I'm ready to get this to the finish line!
I've been staring at my box of gauge parts from Marcel forever, so I'd like to get those wrapped up.  I have some NOS components and the repros, so it should look really nice.  I just need to take my time and roll the seams.
I look forward to posting my results and finished bike soon! Are they ever finished?
Offline Nelsonic-d
« Reply #158 on: December 09, 2024, 12:31:50 PM »
Kenny what happened to your interactive wiring diagram? That diagram was heaven sent and chance you could get the link back up and running?
Offline BenelliSEI
  • 1969 cb750
« Reply #159 on: December 09, 2024, 12:54:25 PM »
Try slicing the holes on the plate bracket right out the ends. Then weld on a set of 1/4” body washers (the large ones) where you want them. A bit of black paint and you’re done. Looks good!
Offline BenelliSEI
  • 1969 cb750
« Reply #160 on: December 09, 2024, 12:58:59 PM »
P.S. The bracket from a CB750 1969-71 will take the small lamp and should be the right size for your plate.
« Last Edit: December 09, 2024, 01:01:01 PM by BenelliSEI »
