Stand came in today. I got the wheel pretty close using this. Waiting on magnetic base dial indicator later this week and I'll get it dialed in. Also at lower left you can see the front hub polished and ready to be laced.
Removed the front tire and broke down the wheel. Actually had to cut the tire off as I couldn't get it. It was old, cracked, crunchy, and otherwise very stiff. Not worth fighting so I just cut it after a brief struggle. Disappointed to find the inside of the front rim quite rusty. Shame as the chrome is pretty good. Didn't feel like dealing with it so just ordered a new DID rim, the rear is a newer DID stamped on side anyhow so not winning any concours shows with stamped rims. This may be safe after cleanup and inspection so I'll just hang on to it in case I get around to restoring the K1 I wrecked on some day.
I was debating on ordering repop cush drive rubbers or reusing mine. Figured I'd save a few bucks and use what I have as they're not all cracked and I don't recall them being loose. Soaked and scrubbed in soapy water to get the brake dust and crud off them and will use the best of the two sets I have.
Not much progress otherwise, waiting on parts and doing the bits I can while I wait. A few small parts still need sand blast and paint. At some point while I'm waiting I need to bite the bullet and do the gauges. Never gone thorugh a set before so I've been avoiding it.
