Author Topic: Oil Pump Dowel Pin CB550  (Read 1048 times)
Offline Zora
« on: August 13, 2013, 11:15:30 AM »
Does anyone know where to find a replacement dowel pin that goes inside the oil pump? My oil pump is missing one and it is leaking oil everywhere. I've also seen them called an o-ring collar. The oil pump should have two of them and they add support to each of the small o-rings. The dowel pin is in the lower right of the attached picture.
Thanks.
Steve
'77 CB550F - Finally on the road...
'78 CB550K - not running yet...
'06 YZ450F
'01 KLX300
Re: Oil Pump Dowel Pin CB550
« Reply #1 on: August 13, 2013, 01:57:08 PM »
Have you tried looking up the part number and seeing if Honda still sell it?
Offline Zora
« Reply #2 on: August 13, 2013, 05:34:11 PM »
The dowel pin is not available from Honda anymore. I checked with one of the local junkyards, they want to sell me the whole pump for $60...
'06 YZ450F
'01 KLX300
Offline reddyvv
« Reply #3 on: August 13, 2013, 07:04:17 PM »
You can get one here - last one left!!
http://www.cmsnl.com/products/collar-o-ring_15155323000/
Offline xsmooth69x
« Reply #4 on: August 13, 2013, 08:29:15 PM »
whats wrong with it that you need to replace it?
are you sure its not still stuck to the side of the case (engine case not the oil pump case)?
« Last Edit: August 13, 2013, 08:30:54 PM by xsmooth69x »
1975 CB550 (FINISHED?!?!?)
Offline reddyvv
« Reply #5 on: August 13, 2013, 08:36:29 PM »
Since the oil pump was leaking oil already, sounds like a PO mystery missing optional part situation.  :P
Offline xsmooth69x
« Reply #6 on: August 13, 2013, 09:39:53 PM »
ya true but i just want to make sure i thought i lost mine to but i found it stuck to my engine case over the hole where it sits against the case instead of coming off with the oil pump housing
Offline reddyvv
« Reply #7 on: August 13, 2013, 09:53:13 PM »
Good point, easy to overlook.
Offline Zora
« Reply #8 on: August 14, 2013, 10:47:05 AM »
Thanks for the tip to the CMS site. Unfortunately shipping is $42 so the search continues.
The part was missing when I took the pump off. The PO tried a ton of sealant on top of the o-rings though. He even had sealant on the sprocket cover. I found a brass tube at the local metal supply that might work but the wall thickness isn't as thick as the original. I'll probably give it a shot if I can't find an original part.
'06 YZ450F
'01 KLX300
« Reply #9 on: August 14, 2013, 12:06:06 PM »
Same part for 500/550/650 so you ought to be able to find a used one somewhere, I'm in UK so as you found shipping kills one from here
Offline goldarrow
  • one day, i'll be an
« Reply #10 on: August 14, 2013, 02:48:51 PM »
try local hardware store to see if you can find something of similar or same size in the plumbing department? or put up wanted ad in the classified section?
CB550 K0
Offline reddyvv
« Reply #11 on: August 14, 2013, 03:30:20 PM »
$42?!!! That's crazy, no way does it cost that much. I guess they charge a minimum, that sucks.
