Author Topic: Steering stem s-t-r-e-t-c-h-i-n-g .... Sorcery...  (Read 1849 times)
« on: August 14, 2013, 09:30:37 pm »
So we were fitting a Ceriani fork to an Amen rigid 750 frame... But the stem was to short. ...the top bearing area ended just underneath the top race. We wanted rhe front end on now, and did not have time to make a new stem. ( I will have to make 2 anyway)..
 So here is what I did, if you cannot follow I will post a drawing..later
 I chucked the stem in the lathe, got the race area to less than a half thou runnout.. A lot less.
 Then  I cut a groove in the threaded part, right beside the bearing area. Groove was .400 wide, and approx 60 thou deep. Got the bottom same size all the way across.. Threaded portion was gone
 The stem in the groove i cut measured .925. The race area measured 1.024. Then I made a bushing. 925 id, 1.024 od, and .39 wide out of leaded steel.. Next I chamfered the inside of the bushing, then sawed it in half, ending up with two pieces that looked like bearing shells.
 Now i tested it and it fit nicely. So I greased up the races, added the balls slid the stem up thru. Then I installed  the two half shells in the groove..which was right where the balls sit in the race, then slid down the top race, a few light taps, and it slid on over the split shells.
 Nice and tight, no movement.. It worked but, I will still make a stem for later as it will need a dustcap.
 Might save the day if you ever get stuck when converting front ends...
« Last Edit: August 14, 2013, 09:45:48 pm by 754 »
Re: Steering stem s-t-r-e-t-c-h-i-n-g .... Sorcery...
« Reply #1 on: August 15, 2013, 06:31:41 am »
OK, got it now, took me a while.
Pretty slick, Frank!
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #2 on: August 15, 2013, 07:03:12 am »
I was thrown off on this on too.
Didn't realize that stems with integral bearing races existed.
Nice work around Frank.
« Reply #3 on: August 15, 2013, 07:19:20 am »
Its just like a stock stem but with no step in diameter,but the threads were 1 mm or more smaller than the part the race sides onto.. So now it sits snug, and could be run like that.
Offline shovelheadshawn
« Reply #4 on: August 15, 2013, 07:33:19 am »
way to adapt and overcame!!
1978 CB750Four
76 Shovelhead
84 Ironhead
47 Panhead
52 Panhead
1975 80cc Yamahaw my first bike
64 Triumph
70s Tricat
always trading
Offline camelman
  • Man... Myth... Legend
« Reply #5 on: August 15, 2013, 08:09:21 am »
Clever!
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline jamesb
« Reply #6 on: August 15, 2013, 11:05:59 am »
Lets see some pictures of that rigid what kind of front end are you putting on it. We are getting ready to build our amen rigid my sons putting a goldwing front end on his. He's going with the bobber look. To me it seems like a waste of a good frame to do that.
« Reply #7 on: August 15, 2013, 11:42:59 am »
Look at inspiration thread
Offline Powderman
« Reply #8 on: August 16, 2013, 04:36:52 pm »
WTF, Did you really ask this question? Lol
