Author Topic: Thin layer of chrome ?  (Read 841 times)
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« on: August 18, 2013, 03:24:44 PM »
The chrome that my po put on this bike is flaking off. Is there a way to get this back to the aluminum without doing the reverse chroming process?
Re: Thin layer of chrome ?
« Reply #1 on: August 18, 2013, 03:47:23 PM »
Chrome is very hard to remove, I failed when trying to do it with a sandblaster.
I would just replace the covers.
« Reply #2 on: August 18, 2013, 04:04:35 PM »
You could  take it to a chrome plater and have him dip it in acid, I'm not sure exactly what acid it is but i rang a plater about the same thing and he said "bring it over"... ;D ;)
There is also an oven cleaner that will remove chrome, I read somewhere that submerging chrome in cola overnight will remove it as well, apparently it wipes straight off...
« Last Edit: August 18, 2013, 04:07:58 PM by Retro Rocket »
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #3 on: August 18, 2013, 04:55:33 PM »
Used baking soda in a plastic bucket with battery charger hooked up.  Took the chrome off of a set of springs off a girder/ springer frontend.  I didn't expect that to happen but was powdercoating so it worked out.
Offline robdrobd
  • Who? Me?
« Reply #4 on: August 18, 2013, 08:25:41 PM »
Ok, so how exactly do I do it!
« Reply #5 on: August 19, 2013, 12:44:16 AM »
Offline Viktor.J
  • Breaking in the forum
« Reply #6 on: August 19, 2013, 01:22:54 AM »
I searched the forum for the same answer, might be some information in my project thread. But depending on what kind of chrome and alloys it's different procedures. I called a chroming company that couldn't leave any kind of guarantee on the job regarding, finished surface, amount of material removed etc.
SOOOoooooo I ended up changing all the covers, cheaper and nicer.
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
Offline mick7504
« Reply #7 on: August 19, 2013, 02:01:01 AM »
I stripped a set of head pipes with a strong salt water solution and a battery charger.
It was only a small charger and I think one with a bit more grunt would've been faster.
Just can't remember which way around the anode + cathode (+/-) were now.
Have to Google that one to find out which way the current flows.
I used a length of flat steel in the salt water clipped on one side and the head pipes clipped on the other and keeping them apart in the salt water.
It bubbled away with this black frothy stuff floating around on top.
The copper looking coating was still on them and the shiny stuff was gone.
If I was you
I'd be worried about me.
Offline robdrobd
  • Who? Me?
« Reply #8 on: August 19, 2013, 06:25:03 AM »
Seems to be flaking off already. Maybe I'll try the Coke first :)
Offline robdrobd
  • Who? Me?
« Reply #9 on: August 25, 2013, 10:18:45 AM »
I think that just the first layer flaked off
Offline Powderman
« Reply #10 on: August 25, 2013, 06:15:35 PM »
Theres only one layer of chrome. If it was a good plating job there will be a layer of copper, then nickle, then chromiujm. The DIY remedies for removing the chrome do just that but don't remove the nickle.
« Reply #11 on: August 25, 2013, 07:41:21 PM »
Simple Green eats chrome. That stuff look like you could peel it of with a plastic scraper
Offline gonzobrian
« Reply #12 on: August 26, 2013, 05:00:40 AM »
My chrome was flaking off also.  I had Brown's Plating remove it for me.  Get ready for a lot of polishing once the chrome is removed as you will be left with a dull finish.
