Author Topic: Where was that !&#$ thread?  (Read 1098 times)
kaybee
« on: August 12, 2006, 06:18:50 AM »
Hello to all and my first post with a Q?
 I'm trying to freshen up the clutch on my 750-K1. Got everything apart ok...rings are within specs. I'm replacing stock with barnett springs. When I was tightening the clutch lifter plate, I broke off the one of the "tabs"  >:(
 About 2 weeks ago, I was reading a thread on the exact same situation and how to prevent this from happening.  (I know enough to tighten in a pattern with 1/2 turns). At any rate, I can't seem to find that thread again to refresh my memory. Any tips or help to find that thread would be a great help to me.
Offline puppytrax
Re: Where was that !&#$ thread?
« Reply #1 on: August 12, 2006, 06:29:35 AM »
Ain't that something?? You can go back 10 pages in this Forum, and the threads are only from 9 days ago...   :o
I never seen a Forum build up threads so fast...   ::)
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline Magpie
« Reply #2 on: August 12, 2006, 08:56:02 AM »
Have a look at this one and scroll down a bit. I have done the same thing assembling my '71 clutch. Hope this helps
http://www.sohc4.us/forums/index.php?topic=6467.0
Cliff.
Offline Pinhead
  • 1979 CB652-ST
« Reply #3 on: August 12, 2006, 11:02:59 AM »
I was thinking the very same thing. This is the most active forum I've found on the 'net for any subject.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
