Author Topic: Midland Christensen air brake  (Read 1236 times)
Offline goofy3392
« on: August 20, 2013, 01:22:09 PM »
I found this at a garage sale, was being used for a homemade air compressor in a small engine shop, I got it all for $15 and it works. The guy put a newer 1/2 hp motor on it.
Does anyone know anything about this pump or where I can go to find out about it? has some old patent numbers listed.
Sent from my ADR6410LVW using Tapatalk 4
1976 CB550
Re: Midland Christensen air brake
« Reply #1 on: August 20, 2013, 01:34:19 PM »
an old truck unit?
Offline goofy3392
« Reply #2 on: August 20, 2013, 02:05:32 PM »
Oops I forgot to post a picture.
1976 CB550
Offline mick7504
« Reply #3 on: August 20, 2013, 02:23:40 PM »
There are a lot of those used here in Oz mate.
They're just called Midland here and can be used as a direct replacement for the Westinghouse Tu Flo air compressors.
They're fitted to to the earlier Macks, GM's,Perkins, CAT, Cummins etc.
You can still get parts for them at a good Brake place.
If I was you
I'd be worried about me.
Offline goofy3392
« Reply #4 on: August 20, 2013, 03:17:01 PM »
Ok so maybe if I take it to a truck parts store they might be able to tell me about it. I just wanna know if its valuable and how to check the oil, what type of oil to use..etc.
1976 CB550
Offline mick7504
« Reply #5 on: August 21, 2013, 02:22:25 AM »
They're usually pressure fed from the motor through the rear housing and into the crank gallery with an oil return line back into the sump of the motor.
15/40 Diesel Engine Oil or something similar should do the job.
It must have been modified to have it's own sump so providing that the crank can flick a bit of oil around inside it should be ok.
If I was you
Offline goofy3392
« Reply #6 on: August 21, 2013, 05:33:30 PM »
I think I'm going to take it off the setup and clean it up and check out the inside. It produces pressure, it got the tank up to 65psi in about 10 minutes or less. The tank is a 100lb lp tank. I don't know if that's too long of time or not for this compressor, it did get pretty hot, maybe I should mount a fan on it.
1976 CB550
