Author Topic: Gear ratio 18-48 or 17-48  (Read 10521 times)
Offline DarkRider
Re: Gear ratio 18-48 or 17-48
« Reply #50 on: September 04, 2006, 02:11:36 PM »
So with that said the 17/48 combo would bring my K4 closer to the performance of a K0?
Yes. The engine will still be detuned, but it'll have more "pep".
Ok what else would i need to do to my K4 to bring it closer to a K0? Im already buidling a 4 into 4 baffled straight pipe set up to replace the hacked off exhaust im seriously considering regearing it to the 17/48 set up once i get comfortable riding the bike.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
« Reply #51 on: September 07, 2006, 07:41:17 PM »
One thing: add some spark advance to the advancer by moving the stops outward. The K0 had 40 degrees advance angle, the K1 had 34 degrees, and the K2-later only had 26 degrees. The K2-later also ran on regular gas: you'll have to run premium on the new advance setup. You might also have to up the main jet size by 5 or 10: keep an eye on the plugs.
eldar
« Reply #52 on: September 07, 2006, 08:39:37 PM »
Wish I could think of what the advance is on the 78.
