Author Topic: 630 D.I.D. chain reviews? Mine is crap.  (Read 1125 times)
Offline Thousandson
  • Ride, Fix, Repeat
« on: August 21, 2013, 06:04:12 PM »
So i found the lowest price i could find and it looks like I'm paying for it.
I found a D.I.D. 630 x 88 link chain on amazon, for $54. Good price, next lowest price was $74, trying to save as much money as possible. I purchased the chain, I just finished replacing my rear wheel bearings, and now putting my rear chain in tension. It was squeaking, at one position dead on tension, move ten links the chain is tight as a drum, no slack at all. Fearing that my axle might be bent, hub is off, sprocket bent, bearings not aligned or frozen.
I found out three links are almost frozen, shot some wd-40 to loosen them up, add some chain grease. Still pretty stiff. What are people's experience with new rear chains? I installed the rear chain, gave it a few good shots of grease(spray on rear motorcycle chain grease)  and I've ridden less then 500 miles.
Cheap chain?
Improper install, and pre-greasing instructions?
Current ride: 78' Cb750F
Offline 2wheels
Re: 630 D.I.D. chain reviews? Mine is crap.
« Reply #1 on: August 21, 2013, 06:59:35 PM »
2 years ago I bought the same NOT o ring chain as you.  Over last summer I had serious stretching in one area, so bad i had to replace the chain.  With less than 5000 miles.
I'm no newbie to chain maintenance so I don't know what happened.
I replaced it with an O ring DID chain and it has been fine all summer.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #2 on: August 21, 2013, 07:33:30 PM »
got a new 110 link DID oring chain off ebay for 60 bucks earlier this year.  havent had any issues with it.
MATT
