Author Topic: Top end job on my '75 CB750  (Read 7335 times)
Offline Ira
« on: August 22, 2013, 07:51:31 AM »
Hey guys, I'm starting this thread to document the process of sorting out my engine.  I got it as a replacement two years ago with unknown miles. At that time I tested compression (it was acceptable, though I don't recall the numbers now), dropped it in the frame, and rode it for a season.  I believe I put 2k miles on it last summer, but it began leaking oil badly from the front (cam tower pucks?) and there was a little bit of white smoke in the exhaust on acceleration.  It's sat all of this summer because I recently completed an 81 Suzuki GS550 to ride around town, but I'm really missing the big Honda!
Last night I pulled the engine, with the help of two strong buddies.  It's resting in a homemade work stand, which I believe is the work of Big Bob (of this forum and ChiVinMoto fame).
I'm going to post about what I'm doing and hopefully get some pointers in the right direction.
Re: Top end job on my '75 CB750
« Reply #1 on: August 22, 2013, 11:42:28 AM »
I'm always interested in seeing detailed engine builds, probably because I am not adept enough to undertake one alone.  Are you planning on simply refreshing it, or modifying it for improved performance (big bore kit, port and polish head)?
Offline Ira
« Reply #2 on: August 22, 2013, 12:36:39 PM »
At this point, the minimum goal is to keep the oil in ;)  However, I won't know how much needs to happen until I crack it open and measure everything.  I don't have a large budget, but I'm willing to invest some time and do things right.  At a minimum I'll be replacing all of the top end seals and gaskets.  I'm hoping to not do this again for a few years, so I want to hone the cylinders and replace the rings while I'm in there.  Who knows what else I'll find?
Offline BCBarker
  • Hey
« Reply #3 on: August 22, 2013, 12:49:03 PM »
watching this with great interest as my 77 is leaking from the top end too and I've finally decided to just fix it this winter. post away!
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #4 on: August 23, 2013, 07:31:11 AM »
Also watching with interest. Same motor, same year. I have a sneaky suspicion that maybe my oil pucks are bad, or a bad head gasket seal. They can look the same (oil on the top fins), but nice pics of a teardown will be helpful!
--Evan
1975 CB750K "Rhonda"
Offline Ira
« Reply #5 on: August 23, 2013, 10:53:19 AM »
Thanks guys.  Now that the motor is out, it should take another evening to pull the top end apart.  I only have one bike night per week, so bear with me...
Offline Ira
« Reply #6 on: August 28, 2013, 07:49:23 AM »
I started on the tear-down last night.  This is what the valve cover and hardware looked like.
I freed nearly everything with an impact driver.  The breather cover screws were gnarly beyond belief (covered in rust and filth) and i had to cut slots in two with a dremel.  All of the rest came out fine.
Offline Ira
« Reply #7 on: August 28, 2013, 07:52:00 AM »
The gasket peeled off in one piece.
Offline Ira
« Reply #8 on: August 28, 2013, 08:00:21 AM »
I've removed a valve train before, so this was quick.  I was alarmed to find two of the cam holder bolts were finger tight, and one came out with either stripped threads or part of a helicoil on it.  It appears I'm not the first to have my grubby hands inside this case :(
I stored all of the hardware in a sheet of cardboard (a trick I read about here) with grid drawn on it.  I reassembled the valve train on my bench to make sure all of the bearing surfaces stay correctly matched.
I wrapped a piece of wire around the cam chain to keep it in place.
Offline Ira
« Reply #9 on: August 28, 2013, 08:05:48 AM »
The cam tower pucks, as expected, were brittle plastic.  There's one hanging out on the far left.
You can see my wired cam chain at the bottom.
All of the nuts came off the studs (pinggg!) and I stored them in a parts case.  Removed the 6 remaining bolts, all came out easily.  There was a lot of crud and gravel in all the recessed spots, but fortunately none in the case.
Offline Ira
« Reply #10 on: August 28, 2013, 08:12:09 AM »
It took some persuasion to separate the head from the cylinders.  I put a block of wood against the head and tapped with a big hammer. Again, the gasket came off in one piece.
This valve was completely black.  The others were white.
There's a #$%*load of carbon on everything.
Offline Ira
« Reply #11 on: August 28, 2013, 08:34:11 AM »
The next step is to disassemble the head, then clean and measure everything.
That's it for one night!
Offline evanphi
  • Apparently I'm an
« Reply #12 on: August 28, 2013, 09:16:54 AM »
bravo! Great pics. Really shows nice detail.
--Evan
« Reply #13 on: August 28, 2013, 10:18:33 AM »
Thanks for the detail. Great progress for one night!
Offline Ira
« Reply #14 on: September 05, 2013, 07:52:47 AM »
I took a close look at the pistons in my engine.  They're not OEM, but I'm not sure what they are.  They are domed and say "AP" on the side.  Any ideas?
I haven't measured the bore yet.
Offline Ira
« Reply #15 on: September 05, 2013, 07:54:44 AM »
I also noticed someone attempted to port the head.
« Reply #16 on: September 05, 2013, 08:43:02 AM »
I believe - and I was wrong before - that those are late pistons, such as 77/78K or maybe even 78 F pistons.  My F3 pistons are domed and have a cut out for valves.
Hopefully somebody will pitch in with more info.
Offline Ira
« Reply #17 on: September 05, 2013, 09:06:07 AM »
They are not '77K pistons, I know that much.  They also don't have "Honda" cast into them.
« Reply #18 on: September 05, 2013, 09:52:28 AM »
Here are 78F pistons.
Offline Ira
« Reply #19 on: September 05, 2013, 09:54:43 AM »
Yeah, they're something else. The valve cutouts are different, and they don't say Honda.
« Reply #20 on: September 05, 2013, 10:13:22 AM »
Something was going on in that #4 cylinder judging by the piston crown and outer area of the chamber.
Offline SF
  • I burn gas very well
« Reply #21 on: September 05, 2013, 10:24:39 AM »
interested
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline BPellerine
« Reply #22 on: September 05, 2013, 11:47:09 AM »
is it stock bore .bill
1978 CB 750K ard and webers
another anfob
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #23 on: September 05, 2013, 12:52:42 PM »
Subscribed!
Offline Ira
« Reply #24 on: September 05, 2013, 01:21:44 PM »
i haven't measured the bore yet.  doing that this weekend.
