Author Topic: Cam Positioning  (Read 1566 times)
Offline nivlac
  • Old, bold and startin' to mold
Cam Positioning
« on: August 22, 2013, 08:00:58 PM »
I'm trying to get my cam positioned on my 79 cb650. I'm having trouble getting the sprocket holes to align with the threaded cam holes. Once the cam is positioned I can't get enough slack on the chain to position the sprocket. I'm sure I'm doing it wrong. Any ideas?
Offline goldarrow
  • one day, i'll be an
Re: Cam Positioning
« Reply #1 on: August 22, 2013, 08:04:21 PM »
You're probably on the right track. Try to inch worm the chain tooth by tooth on the sprocket. But then I never worked on a 650 though.
CB550 K0
Re: Cam Positioning
« Reply #2 on: August 22, 2013, 09:05:20 PM »
What goldarrow said, jump the chain a tooth over the gear and try again. Then if you  did it like me, jump it two teeth the right direction and try that.
Offline tomkimberly
Re: Cam Positioning
« Reply #3 on: August 22, 2013, 09:17:20 PM »
Make sure you're not 180 degrees off. Or that you installed the gear backwards.
Tom
Re: Cam Positioning
« Reply #4 on: August 22, 2013, 10:09:10 PM »
Retract the cam chain tensioner all the way before trying to install the chain. That usually helps.
Offline nivlac
Re: Cam Positioning
« Reply #5 on: August 23, 2013, 07:36:18 PM »
To retract the cam chain tensioner would I loosen it or tighten it?
Re: Cam Positioning
« Reply #6 on: August 24, 2013, 04:40:19 AM »
you read the manual to see how it works first!!
