Author Topic: #2 plug isn't firing properly if at all  (Read 442 times)
Offline SouthernFriedCB
  • New rider, but long time gearhead.
« on: August 23, 2013, 03:42:04 PM »
What's been done:
Replaced whole points plate with good tec unit, static timed, and then put the timing light to it and it's dead on as far as I can tell. Fresh plugs, properly gapped. Tested the coil it's good and checked plug wires for continuity, good across all four there too. But, #2 isn't firing with the rest. The other 3 will strobe the timing light consistently, but #2 intermittently fires when it feels like it. I am waiting for a fresh set of plug caps, anything else I can check while I wait?
Offline Vinhead1957
Re: #2 plug isn't firing properly if at all
« Reply #1 on: August 23, 2013, 04:46:58 PM »
You can try swapping the cap with a good cylinder
« Reply #2 on: August 23, 2013, 06:23:23 PM »
Or swapping the spark plug with one from a firing cylinder.
Or, examining the spark lead for cracks and allowing an electrical path to frame/motor.
« Reply #3 on: August 23, 2013, 06:36:10 PM »
Yep, if #3 is consistently sparking, it'll be either the plug, the cap, or the lead. ;D
« Reply #4 on: August 24, 2013, 09:51:54 AM »
Thanks for the ideas guys, run thru all that today.
« Reply #5 on: August 24, 2013, 03:10:31 PM »
Thank you mailman! Got my plug caps today, and now that it's finally running on all 4,it runs like a stabbed rat. :-)
