Author Topic: CB450 Swingarm Rebuild  (Read 6893 times)
fendersrule
« on: August 23, 2013, 09:38:18 PM »
Rebuilding my first swing arm. These parts often get overlooked, so I want to get this done right. Getting the swing arm done will allow me to start mounting more stuff on the bike!
My powdercoater did a great job keeping the powder out of here. Things are still nice and greasy inside. I did spend the big bucks on bronze swing arm bushings that are supposed to replace multiple Honda parts. There are two inner parts that are still left in here on both sides. I suppose the best way is to somehow cut them out so I can get the bronze bushings inside, or are these suppose to stay inside? My friend has tons of presses and other machines in his garage (my garage is a bit more minimal) and he has more ideas than I have. Basically, I would approach this by hacksawing through them until I reach the swing arm, and them bust them out. Any other ideas?
My powdercoater also did a good job and removed these bushings which I already have the original honda parts. Can I use a c-clamp to press the new ones in, or maybe a rubber hammer?
« Last Edit: August 23, 2013, 09:41:19 PM by fendersrule »
Offline tbpmusic
Re: CB450 Swingarm Rebuild
« Reply #1 on: August 24, 2013, 06:46:41 AM »
There are two inner parts that are still left in here on both sides. I suppose the best way is to somehow cut them out so I can get the bronze bushings inside, or are these suppose to stay inside? ................
Those two inner parts are the actual bushings.
If it's K5-K7 the bushings are probably not metallic, usually can be easily broken out.
If they're the earlier metallic type, it can be one of the most miserable jobs ever on any Honda.
I have both types (new) in the shop, the later type are definitely NOT a ferrous metal, not attracted by a magnet.
Lots of beating, pressing, swearing on the older type......some guys use a hacksaw blade to cut them lengthwise, a very tedious job.
The bronze bushings are worth the effort, they'll probably never have to be replaced again, whereas stockers only last about 10,000 miles.
The rubber shock mounts - most rubber parts can be soaked in xylene or even diesel fuel - this softens them, and causes them to swell a bit. That will make them easier to manipulate - they'll shrink back to original size after a day or so.
« Last Edit: August 24, 2013, 06:49:22 AM by tbpmusic »
Bill Lane
Offline Eddie
« Reply #2 on: August 24, 2013, 06:55:45 AM »
Dang... should have taken those parts out before powder coating..
fendersrule
« Reply #3 on: August 24, 2013, 09:27:16 AM »
Thanks Bill.
How would you specifically go about mine? What tools do I need?
Offline tbpmusic
« Reply #4 on: August 24, 2013, 10:55:22 AM »
Thanks Bill.
Plenty of hammers, maybe a slide hammer/press/hacksaw blade, long chisels/drift pins, who knows.
If they're the newer type you should be able to whack on them for a while and they may just disintegrate for you. They're pretty crummy material.
Make sure you test the long "collar" that goes inside the bushings (the rear axle rides inside this collar)  before you put the bushings in the swingarm.
If that collar is distorted it might not fit inside the bushings. If that happens, don't get mad at the bronze bushings, it's the collar itself.
The bronze bushings should just tap into the swingarm - the flange should take up the same space as the old felt washer/grease cover, all that stuff.
Once torqued down (with no shocks yet) the swingarm should be snug but not overly tight - it might not fall by gravity but should at least be movable by hand.
The new setup should have ZERO sideplay. With the rear wheel on, put the bike on the centerstand, grab the wheel and push HARD side-to-side, there should be no sideplay.
Bill Lane
fendersrule
« Reply #5 on: August 24, 2013, 12:12:28 PM »
Thanks bill
It's a k5, so hopefully it should be smooth. I'll grab a punch and a mallet and get to work. I'll take pics along the way.
I assume if I smack the inner swing arm that its not a big deal.
I plan on putting the bronze bushings in the freezer. Maybe greasing them before putting them in?
I usually put this stuff on every metal touching component:
http://m.motorcycle-superstore.com/2/9/197/56455/ITEM/Silkolene-PRO-RG2-Grease.aspx?SiteID=Google_PLA197&WT.mc_ID=10012&esvt=0-GOUSC&esvadt=9-0-3886819-1&esvaid=30548&kw=%7Bkeyword%7D&gclid=COefvsHklrkCFfFDMgod6y0Ayw
fendersrule
« Reply #6 on: August 24, 2013, 01:02:01 PM »
Had to get innovative on the shock bushings since I don't have a press.
My friend has a press if I need to drive them in further. The c-clamp feels like it can't go anymore at this point...are they suppose to stick out a tiny bit? (it's consistent on both sides).
I'm heading to the hardware store to get some long punch tools to beat on the inner bushings.
fendersrule
« Reply #7 on: August 24, 2013, 03:56:40 PM »
This is absolutely bull#$%*. F(#*ing bull#$%*. 3 hours of sweat, and nothing.
I've tried everything. Chisels, punches, hacksaw. Inserting a socket through one end and trying to bust out the other end. Ruined three of my tools so far. The only thing i haven't tried is heat.
Wish I didn't mess with it in the first place. Now it's a garbled mess. Honda obviously didn't intend on this EVER being removed.
Really don't know what to do anymore. The stupid #$%* bushing is so soft it doesn't feel like it wants to "break".
Offline tbpmusic
« Reply #8 on: August 25, 2013, 08:14:31 AM »
Well, can't say I didn't warn you - "......If they're the earlier metallic type, it can be one of the most miserable jobs ever on any Honda....."
I've spent entire days beating/slide-hammering  on those things to no avail.
No advice other than to keep at it.
When you're ready to surrender, you can always send it to HondaMan, who will make it good as new.
Or a good machine shop with proper equipment.........
Not so, but they have been in there for 40 years after all.........it's a common but unpleasant (and totally necessary) task for 450 owners.
I feel your pain, brudda'.........
« Last Edit: August 25, 2013, 08:17:28 AM by tbpmusic »
Bill Lane
fendersrule
« Reply #9 on: August 25, 2013, 08:59:07 AM »
Went over to my friend's house with it. He's a peterbuilt/cat mechanic.
After us working a little more on it, he decided to just take it into work on Monday. He said he'll press them out with his shop press.
Offline Eddie
« Reply #10 on: August 25, 2013, 11:00:59 AM »
all that old grease turns into concrete/ glue. On mine I soaked it pretty good with acetone to soften the old grease for probably 2 days. Applied heat and it tapped right out... gotta watch out for the old grease when it fires up..
Offline tbpmusic
« Reply #11 on: August 25, 2013, 05:05:51 PM »
Quote from: fendersrule link=topic=125891.msg1432130#msg1432130 date=137744634...... He said he'll press them out with his shop press.
[/quote
Frankly, that's what I'd have done in the first place, once you figured out they were not coming out easily.
A couple of experiences with that job convinces you to just Pay The Man, no shame in that.......a good machinist wouldn't have much problem.
Bill Lane
fendersrule
« Reply #12 on: August 25, 2013, 05:10:57 PM »
Luckily for me it's going to be a no-charge deal. I'll need to grab him a bottle of whiskey, at least.
Offline tbpmusic
« Reply #13 on: August 26, 2013, 08:47:52 AM »
Be sure he does the swingarm first, THEN give him the whiskey.........
Bill Lane
fendersrule
« Reply #14 on: August 26, 2013, 09:17:43 AM »
Haha!
He asked me if I wanted him to press the bronze bushings in. I told him there shouldn't be a need as I should be able to get them in just fine.
He said he'll even clean up some burrs that I made.
When we both were hammering on it, we actually got one of the bushings to move down in the swing arm an inch. That was the most substancial thing i have seen all that day from 4 hours of hell...I was excited.
Never again. This is something to "pay the man" for. The hardest thing I've ever tried to do on a bike, by far, no contest.
If someone were to try this on their won, I would recommend to cut first. Hacksaw a few slots in each of the bushings. Don't do anything else before cutting slots. Soak them bushings, and then try every means necessary to get them out. Then pray.
fendersrule
« Reply #15 on: August 28, 2013, 10:16:38 PM »
He got those suckers out.
We hammered in the bronze bushings. Didn't take much effort at all.
Seems like the bushings got a bit tighter or something once they went into place. I wire-wheeled and sanded the axle. I also sanded the edge of the bushings to remove any lips that were potentially made when we drove them in...did this with my mini-rotary tool.
The axle now pushes into place by hand. There's some slight resistance here and there, but nothing that would require pushing with much force.
Should there be no resistance, even slight resistance when the axle goes into place? I haven't greased anything yet. I assume that I want to use whatsever in the grease gun that I got from Harbor freight to grease the axle.
Should I be sanding  a little bit more to remove any resistance, however slight it may be?
Offline tbpmusic
« Reply #16 on: August 29, 2013, 06:49:10 AM »
Probably the long collar, not the bushings.
A light greasing when you put the axle in is all that's required. You don't need to pump it full of grease, ever again.
Bill Lane
fendersrule
« Reply #17 on: August 29, 2013, 08:05:16 AM »
Really? No future greasing?
Of that's the case ill use my waterproof stuff.
Should all slight resistance be gone?
« Reply #18 on: August 29, 2013, 08:12:12 AM »
If you can assemble it, you are good.  Any residual resistance will be gone after it sets itself in.
Offline tbpmusic
« Reply #19 on: August 29, 2013, 08:17:40 AM »
If those are Bob Franzke's bushings, he's written that the need for frequent greasing over time is not indicated.
He recommends a small amount to install, that's it.
I guess if you felt safer pumping that whole thing full of grease, go for it.
Remember, the swingarm shaft doesn't actually ride in the bushings, it rides within the collar (which rides in the bushings).
That collar can get deformed inside and out. It's NLA, of course, though you can have a new one machined - specs are in the Manual.
At any rate I wouldn't worry a lot about a small amount of effort to tap the shaft through - you did put sticky grease on it, and it's old. Tapping lightly with a hammer is acceptable.
Though it's a shaft with bushings and all, nothing really rotates very far, it's a stability thing.
Bill Lane
fendersrule
« Reply #20 on: August 29, 2013, 08:57:44 AM »
I really appreciate the help you guys have given me. The good news is that I'm able to provide pictures to help anyone in the future who does this themselves.
Bushings installed
You guys have confirmed it, so it's ready to go in.
After some light greasing, it's ready to go in. That's what she said.
No hammer necessary. Just a little press towards the very end.
The next question:
What else do I need now to hook it up to the frame? Do I simply take it as-is and hold it up, run the "grease bolt" (that's what I call it, but I'm sure it's has a different name) through it, and I'm done?
« Last Edit: August 29, 2013, 08:59:43 AM by fendersrule »
Offline tbpmusic
« Reply #21 on: August 29, 2013, 05:46:51 PM »
Yep, pretty much - the flange on the bushings should make up for the space formerly taken up by the dust cover, felt washer, etc.
It should fit snugly into the frame - put the bolt through, torque it to specs.
Push the swingarm HARD, side to side - there should be zero sideplay.
Ride and smile.......
Bill Lane
fendersrule
« Reply #22 on: August 30, 2013, 12:50:08 AM »
I read on the Honda twins forum that ill still need #13 and #21
http://www.carlscycle.com/fiche_section_detail.asp?section=2449537&category=Motorcycles&make=Honda&year=1972&fveh=131042
So I placed an order. For some reason I didn't locate these parts in my bags. Must have trashed them.
Offline tbpmusic
« Reply #23 on: August 30, 2013, 06:38:04 AM »
The geniuses at HondaTwins don't know everything.
#21 is just the washer that goes with the nut.
I didn't need the other crap (dust cover, felt washer) - there wasn't enough room for them anyway.
Try it first......
Bill Lane
fendersrule
« Reply #24 on: September 02, 2013, 11:37:59 AM »
I did confirm that #13 is still nessesary before installing the swingarm, to attach on both sides of the swingarm.
Ive created quite a thread on steering bearings on the twin forum. Lots of opinions in that topic. That's my next step.
