Author Topic: Drive chain adjustment on cb650  (Read 455 times)
Offline Moffman
  • 1979 Honda CB650
« on: August 24, 2013, 06:19:41 PM »
Is it true the rear suspension needs to be loaded for the specs given in the manual on slack to be accurate? Reading the factory manual it mentions nothing of it and just says put it on the center stand and the slack should be 5/8 to 1 inch of play. Measuring my slack I'm coming up at almost 2 inches at the tighest spot and I'm not getting any noises or chain slap so I'm a bit confused.
Offline lucky
Re: Drive chain adjustment on cb650
« Reply #1 on: August 24, 2013, 08:40:30 PM »
"Is it true the rear suspension needs to be loaded for the specs given in the manual "
Which motorcycle?
Black 750K8
« Reply #2 on: August 24, 2013, 08:48:46 PM »
If you are measuring correctly 2" is way to much and yes it should be loaded so both sprockets are in a straight horizontal line. Also you should not have loose and tight spots.
Offline Moffman
  • 1979 Honda CB650
« Reply #3 on: August 24, 2013, 11:03:57 PM »
Which motorcycle?
79 CB650
