Author Topic: Front axle question  (Read 1897 times)
Offline Swede
Front axle question
« on: August 12, 2006, 09:13:22 PM »
I was looking over my front wheel today and I noticed that on the left hand side there was a gap between the axle and the bottom of the fork tube.  I pulled the wheel off and there seems to be some kind of shim that has been put in there which prevents the axle from seating completely.  I haven't noticed any problems while riding the bike but is this normal?  ???
Offline mrbreeze
  • Not your average
Re: Front axle question
« Reply #1 on: August 12, 2006, 09:28:29 PM »
Yes,it is normal.The gap should be towards the rear of the bike and I believe if you look on the bottom of the cap,there should be an arrow pointing forward.If I am not mistaken,the early models didn't have the arrow.Anyone else...correct me if I'm wrong.
MEMBER # 257
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #2 on: August 12, 2006, 10:47:40 PM »
My `72 & `73 have an "F" for Front stamped on them.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline jaknight
  • ....Round Town Ride......
« Reply #3 on: August 12, 2006, 10:50:01 PM »
     Yes, there should be a gap to the rear of the fork/axle caps.  I am told some had directional arrows and others have the letter "F", without the qoute marks, indicating to the FRONT.
     I cannot recall info about a shim though........ :-\ :-\
     ~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
Offline mrbreeze
  • Not your average
« Reply #4 on: August 12, 2006, 10:56:37 PM »
Yeah,never heard of a shim.
MEMBER # 257
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: August 13, 2006, 03:04:29 AM »
On my K0 there is no indication of front (either F or arrow) on the axle caps.
DeLuxe
« Reply #6 on: August 13, 2006, 04:39:05 AM »
My CB400f has the 'F' (raised in the casting, not stamped) in the clamps - I've been told to tighten the Front bolt first, then the rear ones before final torquing - same as for the handlebar clamps.
Sorry - no shims in there, just plain faces to the fork ends and the clamps.
BTW, I have to squeeze the forks together to 'clamp' the wheel - I guess this is what the peg end with the hole in it is for - I put a number 3 phillips though the hole and lever the RHS fork against that to close the gap.
Offline Swede
« Reply #7 on: August 13, 2006, 10:08:06 AM »
I took some pictures last night sorry about the bad quality.
Offline angeldeville
  • You meet the nicest people on a Honda!
« Reply #8 on: August 13, 2006, 01:02:05 PM »
yeah there shouldn't be any type of shims in there, they may have been placed there by an uninformed PO.
if there are no markings on the cap just look at the cap and you will see one side is higher than the other, this is the front side.
Always tighten the front side first, then the back, this will leave a gap in the back.
it is my understanding that if it is not done this way, the studs on the fork legs can break off.
76' cb750f custom
69' cb750 sandcast
69' CT90
Amen Saviour 750 Chopper frame
and enough parts to build about 6-7 more bikes
Offline Swede
« Reply #9 on: August 13, 2006, 03:06:50 PM »
I didn't think that it should be there but I thought it best to check the forum and see if anyone else has seen this.  I guess tonight I will see if I can knock the shim out of there (unless anyone knows of a reason that i shouldn't) and see how it handles.  Thanks for the responses.
