Author Topic: heffay's 75/77 cb400f race project pix and the onslaught of questions  (Read 34448 times)
Offline GroovieGhoulie
  • I have to return some videotapes.
Re: 77 cb400f project start date pix and the onslaught of questions
« Reply #25 on: April 25, 2006, 10:16:36 AM »
F2 stuff looks like the parts in the photo they use the same mounts on the frame by the looks of things but I've never seen one, I think looking at your photo you have a F frame with a F2 tank, it looks like you have no loop for the rear footrest  ???
US spec bikes never had the loop on the left side.  We always had our pillion pegs on the swingarm.
Offline heffay
« Reply #26 on: April 26, 2006, 11:11:04 AM »
ok... so you've seen the list.  since plans change, it will be a racebike!  what should i consider?  where should i start?  make it a project i want to continue by making it look good first or get it running?
this summer might be when it gets to happen as i may have access to a garage.   ;D
i'm thinkin:
remove some heaviness
seat/side covers/fairing
engine work!
oil cooler
tach
tires
better brakes or rebuild
anyone?
supersport_CB400F
« Reply #27 on: April 26, 2006, 11:31:20 AM »
Honda really give the US a bum deal on the 400 from what I’ve read about your models, footrests on the s\arm if you have a pillion makes those showa shocks go from bad to dangerous.
Offline heffay
« Reply #28 on: April 26, 2006, 11:53:51 AM »
yes... but, as i plan to race the bike... there will not be many passengers :P
good 400f race parts?
do you have any?
where should i look?
terry... hows about a trick little oil pressure guage and cooler?  he's probably not listening anyway.
should i make the fairing and seat/tail?  if i'm gonna build a bike i should just build it right?
let's say my 400 motor is fried, which it very well could be... is it sacrilege to use my spare 350f motor.
Offline tsflstb
« Reply #29 on: April 26, 2006, 12:14:37 PM »
http://www.ttr400.com/
More billet parts than you can shake a stick at.
Offline heffay
« Reply #30 on: May 04, 2006, 10:57:02 AM »
my ebay scores for the week:
a one dollar 400f tranny (excellent shape) 15 dollars shipping
a one dollar set of 4 exhaust collars (ok shape, need beadblast) 15 dollars ship
a shifter for a few bucks too... totalling about 13
i think i did allright  ;D
supersport_CB400F
« Reply #31 on: May 04, 2006, 11:42:57 AM »
Keep at it heff, one day you may own a proper bike  ;D
« Reply #32 on: May 04, 2006, 12:10:17 PM »
I think the 400 was really intended as as solo machine only with the pegs added in case of emergencies.  It's like calling the Porsche 911 a 4-seat car when the only people you care gonna get in the backseat are 6-year olds.  I don't think the swingarm-mounted pegs are really a problem.  Besides, it allows the passenger's legs to help the already-underpowered Showas with shock absorption, making it arguably the first bike with Active Suspension!!!  ;D ;D
The 400 keeps getting cooler and cooler!!!  ;D ;D
I do like the smaller UK winkers and taillight though.  And the ability to turn the light off.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: 77 cb400f restore start date pix and the onslaught of questions
« Reply #33 on: May 04, 2006, 02:21:00 PM »
Prior to 75 was the 74 cb350F four, and cb450k twin.  The 75 cb400F was basically a modified 350F that replaced the 350 and 450.
      Chris, I have to say I was going along until you mentioned the CB450K, because in 75', the 74' CB450K7 became the CB500T(and was also produced in 76' in the states, not sure about overseas).
which was a 450 with a longer stroke, different spacing  ratio-wise through the gears and a few other
differences in the motor, frame, forks, gas tank, seat and electrical for sure. Visibly, the motor appears the same from the outside view. Just thought you should know. After 76' I don't know what was considered to be the replacement for it. Later on, Bill :) ;)
Member # 1969
Offline Gordon
  • 750K1, 550K2
« Reply #34 on: May 04, 2006, 02:31:03 PM »
Okay, let's see here...
$1 + $15 + $1 + $15 + a few more bucks = $13
I'm just glad you don't work in the payroll department at my job. ;D ;)
Did you ever get the brake light issue worked out with the 350?
Offline heffay
« Reply #35 on: May 05, 2006, 01:03:59 AM »
no, no, no the shifter cost 13.
and well, the front brake switch is now working so, i back burner'd the rear brake light problem
Offline heffay
« Reply #36 on: January 01, 2007, 02:20:36 PM »
can't remember if i told you about this somewhere else...
i got a supertrapp to fit to the stock headers.
now that i've had some time to think about what i want the bike for it will definitely be a racer but, where should i start.  recommendations on every thing from bearings to brakes i would appreciate.
i think i'll make the seat and rear cowl.
oh! this might be a good time to mention that i'll be receiving my last financial aid check for college so... if you have 400f parts to get rid of   ;)
oops... just looked over at my thanksgiving thread and there's my supertrapp  :-[  see inside of motor there too  ;)
suggestions from successful builds... 1,2,3, go!
Offline MadDogMcq
  • WEB : www.mcqart.com
    • My Personal Website
« Reply #37 on: January 01, 2007, 03:32:16 PM »
7 months between posts Heff?? Has the bike not progressed any then?  :)
Accepting sweets from strangers since 1958
Offline heffay
« Reply #38 on: January 01, 2007, 03:35:17 PM »
its come apart more  ;D
Offline heffay
« Reply #39 on: January 14, 2007, 07:54:49 PM »
i got up this morning and, if memory doesn't serve, i sleepwalked over to the computer.
i woke up shortly after noon when i noticed on craigslist a cb350... runs good, title, recently tagged and insured, 300 dollars.  it was listed today and sold before i ever even read the post....   aaarrrrrrrrg
but, on the other hand i've had a good run of luck lately and thought i'd brag a bit.
a few minutes ago i won an ebay auction dyna ignition for the 400 and yesterday got a TIA oil cooler in the works and i can't forget the front fairing to be fitted thanks to mkramer.
all this fun stuff to play with and school starts back up in 2 days  :'(
but still, its a very exciting time  :)
Offline heffay
« Reply #40 on: January 18, 2007, 07:04:01 PM »
received the fairing yay!
got pods yay!
 ;D ;D ;D ;D ;D ;D ;D ;D
Offline heffay
« Reply #41 on: March 11, 2007, 09:04:56 PM »
and another score   8)
(used to be an ebay seat link, dead now k)
hopefully, i didn't snipe someone from here at the very last 21 seconds.
i figure... while i'm getting it running, it won't hurt to have a seat  :)
« Last Edit: October 11, 2008, 03:39:54 PM by heffay »
Offline wardmoto
« Reply #42 on: March 12, 2007, 09:37:22 AM »
Perhaps a master's degree and more aid checks might be in order...
03 Suzuki SV 1000S
86 Suzuki GS 550ES
72 Honda CB 350K
72 Honda CB 350F
72 Honda Cb 350F cafe
Offline heffay
« Reply #43 on: March 15, 2007, 06:32:55 PM »
precisely... except for the first part.  NO MORE SCHOOL
i've been going off and on (mostly on) for 25 years now.
maybe when i'm 40.
here's the new seat... and some other bikes  ;)
it makes pretending a whole lot more fun  ;D
Offline heffay
« Reply #44 on: March 15, 2007, 07:44:31 PM »
but now that there is a handlebar and seat... the forks definitely seem bent.  cross your fingers  :-X
Offline heffay
i've been holding off on the project for all sorts of reasons and i think i might finally be ready.
school, parts collecting on a budget, thought we were gonna move  :-\, etc... all kept me from digging in...
finally started carving up the old ebay seat.  will need to have someone sew a seat cover for it as the shape is too complex for a simple 1 piece cover.
here's the old version of the seat(also in the previous picture too)... stock type, very bulbous and odd looking.
and the reshaped version...
3 layers of batting overlayed and glued on the front portion to smooth rough shaping
1 layer of batting on the rear just to hide any from showing thru the cover.
Offline heffay
Re: heffay's 75/77 cb400f project pix and the onslaught of questions
« Reply #46 on: April 06, 2008, 05:16:19 PM »
if you haven't caught on from this or other threads... it will be a vintage racer.
what i had in mind for the rear fender stays that stick out under the seat was to either cut them off in an upward sweep OR use the holes to fashion a number plate holder for each side... since i can't stick numbers on my fancy new carbon fiber side covers... i'm leaning toward making some number plates.   :)
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: heffay's 75/77 cb400f race project pix and the onslaught of questions
« Reply #47 on: April 06, 2008, 05:29:42 PM »
Lookin' good heffay  :)
It's gonna look good beside that sweet 350 of yours.
 Matt.
Gallery at:
Offline heffay
« Reply #48 on: April 06, 2008, 05:33:13 PM »
girlfriend says: santa claus would be proud.   ;D
thanks matt!
Offline heffay
« Reply #49 on: April 06, 2008, 05:38:26 PM »
here's a thought i had after a few beers yesterday...  ;)
that active suspension we talked about on page two (passenger foot pegs on the swingarm)... anyone ever put rear sets back there w/ "swingable" linkage to the brake and tranny?
probably wouldn't be good for a track bike but might come in extremely handy at, oh say, bonneville... remember the fastest indian when he raises his head up to regain better control?
anyway...  8)
