Author Topic: MotoGPWerks Pipe CB550 (Jetting and video)  (Read 43042 times)
Re: MotoGPWerks Pipe CB550 (Jetting and video)
« Reply #175 on: May 22, 2015, 09:03:22 AM »
Also I am going to take my pipe off to adjust the fork level. Do I do the test on the center stand? Kind of hard to hold the bike and balance the clear tube.
tube looks good.
IIWY, id do it w/ the carbs off the bike.    makes bowl removal/float adjustment much easier.  ;D
you can do all bowls a the same time, or just reuse one bowl and swap it between carb bodies.
Offline Tews19
  • I am no
« Reply #176 on: May 22, 2015, 09:14:19 AM »
Thanks Fly once again. No I think I ran into an issue. I have carbon deposits where all four pipes meet. This could seriously impede proper settings if I am thinking correctly. I think I should have none here as that would mean there is a leak/hole where the pipes become one???
1970 Honda CB750 survivor.
« Reply #177 on: May 22, 2015, 09:19:47 AM »
2 choices at this point..
work on getting a new pipe, claiming a defect there
or
tune to the decreased back pressure and live with it
..im kinda surprised these pipes arent tested for this, for what you're paying :-\
4 drain plugs in the headers,  an air source in the end, and a quick listen.
doesnt look like there is a merge bullet there either.  one might fill in this space to prevent back flow...
« Last Edit: May 22, 2015, 09:28:16 AM by flybox1 »
Offline Tews19
  • I am no
« Reply #178 on: May 22, 2015, 09:57:23 AM »
I looked closely. There is a plug. Contacted Motogp, left a message and within 2 minutes he called me. Can't beat that customer service. He offered to repair it as he said it's a tiny pinhole. Which I do think it is. Or if I do not want to send back he said I could jb weld it. Yes the pipe is expensive but I will attempt the jb weld first. If it doesn't hold up I will send to get repaired. I can't believe how polite he was. Last time we talked about my order we were bickering a bit.
« Reply #179 on: May 22, 2015, 10:02:21 AM »
Good to hear!  His pipes are often used and discussed on the forum.
Offline Tews19
  • I am no
« Reply #180 on: May 22, 2015, 12:13:48 PM »
Well number 4 is low. But if I wait like 45 secs it gets higher. 1 seems low in regard to the model I was given. Do I pull all now?
How long do I wait before stopping the test and turning the fuel off? First pic is #1 second is of 4 after the same time. Third pic is #4 after about 1 min.
« Reply #181 on: May 22, 2015, 12:21:54 PM »
all of them need adjustment.  fuel levels are lower than i would accept on my bike.
if the fuel level changes(rises) slowly after you start the test, you have a float valve dysfunction
as soon as you turn on the gas, it should rise and stop, right at 3mm
Offline Tews19
  • I am no
« Reply #182 on: May 22, 2015, 12:29:27 PM »
Thanks Fly, pulling the carbs now.
Offline mrfish2
  • I might be a
« Reply #183 on: May 22, 2015, 12:33:08 PM »
So if you have brand new float valves and float needles installed and it's still doing this, then what would you do to remedy it?
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
« Reply #184 on: May 22, 2015, 12:39:12 PM »
change the float height   ;D
float height is not the goal.  correct fuel LEVEL is  ;)
« Reply #185 on: May 22, 2015, 12:42:04 PM »
(Assuming) he measured the floats (and adjusted if needed) to verify the proper height, Tews19's results above back up why this is a valid test.
Especially with new/aftermarket float needle sets, you cant just ride off thinking you're good.  His #4 could have starved that cyl for fuel and run really hot to the point of failure.
« Last Edit: May 22, 2015, 12:50:08 PM by flybox1 »
Offline stewonepot
« Reply #186 on: May 22, 2015, 12:50:31 PM »
hi look into the float bowl vents maybe a blockage
regards Stew
Offline Tews19
  • I am no
« Reply #187 on: May 22, 2015, 02:02:52 PM »
I have a set of unmolested carbs from this bike. Original owner never opened them up. I'm going to swap floats and see how that turns out. If spot on I will leave the floats in. If off I will put the original floats to this carb set back in and adjust per Flybox's advice. Can't beat the assistance here!
« Reply #188 on: May 22, 2015, 02:06:58 PM »
I wouldnt bother.  Adjust yours and retest.
Arent the ones in your carbs OEM's as well?
Offline Tews19
  • I am no
« Reply #189 on: May 22, 2015, 02:09:22 PM »
True. I will adjust and yes OEM.
Offline Tews19
  • I am no
« Reply #190 on: May 22, 2015, 03:34:37 PM »
What a PITA. Been trying #4 all afternoon. It just won't go any higher.
Offline Tews19
  • I am no
« Reply #191 on: May 22, 2015, 03:53:14 PM »
Freaking hilarious. After my post. I adjust again and now it's spot on.
« Reply #192 on: May 22, 2015, 04:24:23 PM »
Beers all around!!!!!! ;D
Offline Tews19
  • I am no
« Reply #193 on: May 22, 2015, 05:20:00 PM »
Thanks man! I got 3 of 4 carbs done. My hands have stopped working so I will finish tomorrow. Thanks again fly. Where are you located?
« Reply #194 on: May 22, 2015, 05:26:56 PM »
Glad you're getting close. ;D
I'm about 30 min N of Seattle.
Offline Tews19
  • I am no
« Reply #195 on: May 22, 2015, 07:55:36 PM »
Oh that's a great area. I was stationed at Ft. Lewis from 01-05. Very expensive area for houses.
« Reply #196 on: May 22, 2015, 08:15:33 PM »
Haha, sweet.  By '08, you coulda had twice the house for half the price ;). Certainly not that way anymore.
I'll be down at JBLM (Joint Base Lewis McChord) next weekend for my kids track meet.
Offline Tews19
  • I am no
« Reply #197 on: May 25, 2015, 01:22:08 PM »
Got all floats level and sync'd the carbs. Bike is rich as can be so I will most likely use 2 or more sets of new plugs. D7EA plugs currently.
Offline riverfever
« Reply #198 on: May 25, 2015, 07:17:07 PM »
Tews my levels were higher than that and I dropped them a lot. Mine are now about 3mm below the flange that the screws sit on. After making that adjustment, I finally was able to keep all 4 cylinders running and not foul out plug 4.
Offline Tews19
  • I am no
« Reply #199 on: May 25, 2015, 07:29:04 PM »
Interesting. I'm fouling the #$%* out of these. Bought 3 new sets of plugs. Rode to a place where I could do a plug chop. My slow jets need to be swapped out. Way to rich. May have to order a.set of 40s. Running 42 now.
