Author Topic: MotoGPWerks Pipe CB550 (Jetting and video)  (Read 44473 times)
Offline riverfever
Re: MotoGPWerks Pipe CB550 (Jetting and video)
« Reply #200 on: May 26, 2015, 04:41:09 AM »
The huge difference for me is that I live at 8500' elevation so the motor was stupid rich to begin with. Where most have to up the jets, I've had to think the opposite but I'm finally getting close.
Offline Tews19
  • I am no
« Reply #201 on: May 26, 2015, 08:44:58 AM »
Now I am chasing issues. Now I have what some have described as when letting off the throttle it will die if I and riding. Actually even when i pulled back into my garage. I gave it a good throttle twist and once the rpms dropped the bike died. I installed the 38s and it idles well. The bogging isn't as bad as prior. No popping on decel. I need to find the thread of the person who did the 605 kit and what their settings are. I did get 110s so I am going to order 105s
1970 Honda CB750 survivor.
« Reply #202 on: May 26, 2015, 09:18:37 AM »
so with the 38's, does your bike still die when you let off the throttle?
your last post wasnt clear if the 38's cleared it up.
your WOT plug chop should have been the first to be done.  did the plug color indicate a change to 105's?
Offline Tews19
  • I am no
« Reply #203 on: May 26, 2015, 09:48:42 AM »
Yep. I did as you stated. Went with 2 sets of fresh plugs. Drove out to get to operating temperature. Swapped 1 set of plugs. Bike ran like cap on the 1/4 and half way. Part that makes me concerned is rereading this thread. Gold dude posted 110s and 38s were great. I've yet to see it but I will try to get one more ride in and another plug chop. I got it to wide open throttle w new plugs. Hit the kill switch and checked the plugs. They were still sooty.
Offline Tews19
  • I am no
« Reply #204 on: May 26, 2015, 09:52:54 AM »
Another kick in the nuts is that Sirius has only 3 105 mains! Lol. This may be on hold for a while.
« Reply #205 on: May 26, 2015, 10:00:36 AM »
hit up jetsrus.com.
Offline Tews19
  • I am no
« Reply #206 on: May 26, 2015, 10:14:07 AM »
Duh, I forgot about them. Order just placed. As Lucky stated many times though how does the main jet effect the low end stumble?
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #207 on: May 26, 2015, 10:24:17 AM »
Because of this thread, I have 105's from jetsrus ready to rock after my carb cleaning. Hoping they are the ticket for the MotoGP install so I don't have to do much messing around. I'm running 087a's in which stock mains are 100. Curious, what are your stock mains, Tews? I see you and I are at about the same elevation.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #208 on: May 26, 2015, 10:34:01 AM »
overlap.
once you hit 1/4  throttle (and above) the main jet begins to pull fuel from the bowl.
Offline Tews19
  • I am no
« Reply #209 on: May 26, 2015, 11:53:32 AM »
Stock mains for 069a carbs are 98. I have 110 now. I thought 110 would be the key due to me boring out the 550 to 605 and the 650 cam.
I will continue this process. Also I have a Dyna electronic ignition. I set it at 2500 rpms per Dyna suggestion. Could this be a culprit to low end running poorly?
Offline Tews19
  • I am no
« Reply #210 on: May 26, 2015, 12:39:40 PM »
I'm thinking the mains need to be dropped to 105. Maybe my fuel level is to high. It doesn't spew out though.  Hopefully I get the mains before surgery. Once surgery the bike maybe on hold for a few weeks.
« Reply #211 on: May 26, 2015, 12:45:51 PM »
The 3-4 mm fuel level information was passed on to me by Hondaman, years ago when working on my 350F
He indicated it was a level standard across all SOHC Honda CB's as it adequately covers all jets during any riding situation.
Once remedied on my 350Fs carbs, and on my current K8F's carbs, the bikes ran as expected, so I have no reason to doubt the information.
My levels as of last Friday
« Last Edit: May 26, 2015, 12:50:17 PM by flybox1 »
Offline joeyvans
  • Definitely not a
« Reply #212 on: May 26, 2015, 12:50:12 PM »
Remind me, fly.... Does the 3-4mm refer to 3-4mm below where the bowl mates to the body?
1976 CB550 K2
« Reply #213 on: May 26, 2015, 12:52:30 PM »
Yes
Offline Tews19
  • I am no
« Reply #214 on: May 26, 2015, 01:06:55 PM »
When I adjusted the floats for more fuel I will say there was no hesitation when up in the rpms. I will keep them for now and swap to the 105s first then go from there
Offline Tews19
  • I am no
« Reply #215 on: May 27, 2015, 12:39:51 PM »
I can't just sit around if i know I can putz with my bike. I went back to 2.5 turns with the air mixture screw. Now there is no hesitation at all??????? Actually drives pretty freaking awesome. I will do a plug chop but most likely won't be until tomorrow. It does smell a bit rich so I am thinking of swapping out the plugs and putting in new ones before I take a ride. the 105's should be here by Saturday and if that ends up being when they do the bike has to sit for a week.
« Reply #216 on: May 27, 2015, 12:49:56 PM »
Yeah...i have the same desire to ufck with stuff while waiting for parts to come in  ::)
Wait to make any other changes to your carbs until your 105's come in.  Because the main jet starts to pull fuel early in throttle position, any mixture changes you make now wont be valid once you get your 105's in.
There's always something to clean, or electrical to make (look) cleaner (wire run tubes, shrink tubing, etc)  ;)
Offline Tews19
  • I am no
« Reply #217 on: June 01, 2015, 06:47:40 AM »
I did a plug chop with 105's yesterday. First time i tried I ran out of gas! DOHHHH! Second time later in the afternoon the plugs showed improvement. Not sooty black anymore. A little hesitation still but nowhere near as bad as prior. Popping on decel so i may put in the 40 slows to test them out. I am currently 2 full turns on the Air mixture screws which continues to assist with the burble at low end. More results to follow
« Reply #218 on: June 01, 2015, 09:00:26 PM »
What do you estimate the increased HP is with the bored engine and Mikes head work? 10% increase?
Is it noticeably quicker?
Offline Tews19
  • I am no
« Reply #219 on: June 02, 2015, 05:51:35 AM »
I can't really give a false amount of HP gains. It's more cognitive than anything for me. Just knowing i had the work done makes it seem faster. It will hit redline much faster and stronger. Much more to go but i do not want to blow the engine up. I hit 90 plus around 6k so i know i can easily do over 100... Not verified by the trusty 40 yr speedo, wife's mini van helped with the verification process.
Offline mrfish2
  • I might be a
« Reply #220 on: June 02, 2015, 05:56:35 AM »
I would think you could easily reach at least 115 with all that work done because stock they'll do the high side of 105 (or at least that's what my mechanical speedo has said  ;) )
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline hellraiserDLX
« Reply #221 on: June 02, 2015, 08:38:41 AM »
Im gunna schedule  a head to to head with Tews against  my 77cb550 with a 650 swap in it. Details will be provided shortly after :) my bike should be out today!
« Reply #222 on: June 02, 2015, 10:00:26 PM »
...wife's mini van helped with the verification process.
So it's faster than a mini van now?! Wow!
Offline Tews19
  • I am no
« Reply #223 on: June 03, 2015, 03:43:27 AM »
LOL Honda Odyssey's are nice mini vans Steve! Plus 90 isn't that fast for that MINI VAN!
Update: I met up with Eric and the 650 stock is faster. I drove his and yep, much more torque. I think mine hits the RPM's faster but overall his is the beast. I am now a real fan of the 650 engine and my next project will be a 650 in a 550. We both hit around 102 in 4th. I was at around 6k or 8k rpms. I need to get the jetting sorted out on mine still. Pops on decel. Slight burble and the plugs are now rich... Not sure if it was the hard riding or not to have that effect on the plugs.
« Reply #224 on: June 03, 2015, 05:33:32 AM »
LOL Honda Odyssey's are nice mini vans Steve! Nice Minivan is an oxymoron
Plus 90 isn't that fast for that MINI VAN! Youre right, it's way too fast for a minivan. Especially a Pilot being piloted by a woman! Yikes!
Ha!
