Author Topic: Float bowl overflow lines  (Read 2751 times)
Offline Scott S
« on: August 27, 2013, 05:18:02 PM »
 Where are you guys finding the correct size/length overflow lines for the float bowls? All the vacuum line at the auto parts store is too big O.D., ugly, etc.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline harisuluv
Re: Float bowl overflow lines
« Reply #1 on: August 27, 2013, 05:43:45 PM »
How much you need?  I should have enough for you.
Offline Scott S
« Reply #2 on: August 27, 2013, 06:13:09 PM »
 Check your email.
'71 CB500 K0
'81 Yamaha XS650
Offline bjbuchanan
« Reply #3 on: August 27, 2013, 08:07:45 PM »
3/32 windshield line tubing. After all you "shouldn't" have anything going thru it. Occasional overflow is negligient, it won't swell. I use it for the float bowls and for the vents up top
It is nice and thin and flexible, plain not gaudy
« Reply #4 on: August 28, 2013, 03:48:37 AM »
Local John Deere dealer - they use is them  in weed whackers.
« Reply #5 on: August 28, 2013, 06:51:24 AM »
+1
and its cheap, if it hardens after a year or two.
« Reply #6 on: August 28, 2013, 09:01:09 AM »
+1
It does swell, even if only from the gas vapors.  Takes longer than if immersed.  But, vacuum hose will still deteriorate.
The auto parts store counter man convinced me to give it a try, so a bought a couple feet of vacuum hose.  It was cheap for me and profitable for him.
This was 7/32" ID off the spool.  I stuck an inch of it in a jar with a little pump gas last year.  The ID is about 3/8" or 1/2" now.
Offline SohRon
« Reply #7 on: August 28, 2013, 06:10:46 PM »
BikeBandit has the real deal:   426032-9 BULK HOSE (3.5X3000).  $10.25 for more than enough hose to do the overflow and vents.
Offline Dimitri13
  • 1974 CB550K
« Reply #8 on: August 28, 2013, 06:29:51 PM »
That should be about 10 ft?
Seems like BikeBandit would be the best choice, after googling 3.5mm fuel hose. Most the stuff available is braided and really expensive, since VW/Mercedes/Volvo seems to use it.
Offline buckett
« Reply #9 on: August 28, 2013, 06:46:22 PM »
partzilla also has the real deal and a little cheaper
http://www.partzilla.com/parts/detail/honda/HP-95001-35003-60M.html
Offline Scott S
« Reply #10 on: September 06, 2013, 11:52:13 AM »
 So, what's the correct LENGTH of the overflow hoses for a CB550?
'71 CB500 K0
'81 Yamaha XS650
« Reply #11 on: September 06, 2013, 12:44:56 PM »
someone will have to measure an original for you, but you'd be OK with running them rearward over the case and down between the case and swingarm.  I cut them longer than needed and then zip tie and cut them all the same length once installed...
