Author Topic: Exhaust leak causing backfire flame? [Update: fixed]  (Read 2423 times)
Offline Chachi
« on: August 27, 2013, 05:53:43 PM »
I pulled my pipes today to remove my DIY BBQ paint job. I also had the 'flare' cut off the end of pipe. Pipes are from the 70s (I think) and they turned out after the baffle. I did not cut into the baffle area as you can see in the pics. I just removed the last few inches that turned out so the pipes are 'straight' at the end. I also removed old copper gaskets and installed new OEM copper gaskets. I remounted everything and I'm getting some backfiring and flame from 3-4/right pipe.
-See pic attached: a small section of the header pipe lip from #3 came off during removal, just fell off. Is that enough to cause this?
-If that is not enough, maybe I just need to remount and try again?
-Did I possibly disturb spark wires?
-Just trying to determine what to chase, this was not happening before.
« Last Edit: August 28, 2013, 01:54:17 PM by Chachi »
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Chachi
Re: Exhaust leak causing backfire flame?
« Reply #1 on: August 27, 2013, 05:56:16 PM »
It's a 4-into-2 set up by the way...
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline KJ790
« Reply #2 on: August 27, 2013, 05:59:24 PM »
Yes, if you have an exhaust leak where the header meets the cylinder head then that can cause the pop you are experiencing. It doesn't take much of a leak to cause this problem either.
Offline Chachi
« Reply #3 on: August 27, 2013, 07:34:37 PM »
Think that header lip piece can be welded back on?
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline trueblue
« Reply #4 on: August 28, 2013, 02:50:06 AM »
Probably be better off building it up then grinding it to shape.
1979 CB650Z
Offline Chachi
« Reply #5 on: August 28, 2013, 04:47:08 AM »
I'm going to take it back up to the metal shop that cut my flares and see what they can do.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Chachi
« Reply #6 on: August 28, 2013, 01:53:59 PM »
My metal shop hooked me up. Took the pipe back up there with the header lip section that came off and they were able to cleanly weld it back on. They also hit a few pinholes on the underside I had too.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline lucky
« Reply #7 on: August 29, 2013, 02:56:59 AM »
It sounds like you are going to need some new pipes.
Welders should be telling you that instead of chasing pin holes around.
IF you do not have the money I understand, but the welding repairs cost money that could go into some new pipes.
You probably already know this.
Offline Chachi
Re: Exhaust leak causing backfire flame? [Update: fixed]
« Reply #8 on: August 29, 2013, 12:38:50 PM »
Hey lucky, I totally agree about throwing $ at bad pipes vs. buying new. My metal shop took care of me though. I went to them for a purely cosmetic change (cut the flares off) and they charged me $50, their minimum. In the process of pipe removal, a section of the lip from header #3 fell off and that was what causing my leak and backfire. I took the pipe back to them and they fixed the header lip and went ahead and hit a few small pinholes I had too - without charging me anything additional. The shop does great work and with the pin holes taken care of, I think the pipes should still have plenty of life left. So for $50, I'm good.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
