Author Topic: Carb sync question  (Read 2881 times)
Offline gregripko
Carb sync question
« on: September 02, 2013, 07:13:44 PM »
Ok so I did a carb sync and my throttle screw is way too tight.... Is there a better method to carb sync that would give my throttle screw a little more play?
Offline goldarrow
  • one day, i'll be an
Re: Carb sync question
« Reply #1 on: September 02, 2013, 08:00:07 PM »
when that happens, I back out the idle screw and adjust each carb so the bike stays idle, then fine tune. Carbs synch tool still hooked up the whole time.
CB550 K0
Offline gregripko
« Reply #2 on: September 02, 2013, 08:31:03 PM »
Good method.... Guess I'll have to resync.... Oh btw I noticed that when I tighten the carb screws down it throws the carb sync off (using carb sync tool that holds the screw while tightening the nut) is my goal to sync it perfect and tighten them down and however they end up fine or should I have them be perfectly syncd when the nuts are tightened down?
Offline goldarrow
« Reply #3 on: September 02, 2013, 08:35:59 PM »
When the nut is tighten down, it will change the reading also.  It works the same way as adjusting the valve tappets.   Just have to play with them.   And I think this is the hard part if carbs synch.
CB550 K0
Offline lucky
« Reply #4 on: September 02, 2013, 09:46:03 PM »
What do you mean "throttle screw"?
Depending on the year of the carbs it can mean different things.
Offline gregripko
« Reply #5 on: September 02, 2013, 09:47:28 PM »
"Idle set screw"
« Last Edit: September 02, 2013, 10:16:24 PM by gregripko »
Offline gregripko
« Reply #6 on: September 02, 2013, 09:54:20 PM »
If I back out the idle set screw the engine will die though.... Does screwing all the carb adjustment screws down increase rpm....allowing the engine to remain idling while keeping the idle screw looser?
« Last Edit: September 02, 2013, 10:16:43 PM by gregripko »
Offline goldarrow
« Reply #7 on: September 02, 2013, 11:16:12 PM »
Yeah.  Adjust so that the bike idles.
CB550 K0
Offline gregripko
« Reply #8 on: September 02, 2013, 11:44:39 PM »
Ok cool Ty
Offline gregripko
« Reply #9 on: September 03, 2013, 09:13:49 AM »
The bike idles..... Is there a good average spot to have the idle set screw so it had decent play?
Offline goldarrow
« Reply #10 on: September 03, 2013, 09:30:31 AM »
Idle screw is set when warm and forget, and it only takes very small adjustment to change the rpm when idle.  I guess set it to where it works for you???
CB550 K0
« Reply #11 on: September 03, 2013, 09:38:27 AM »
yes, i reset the position when I do mybench sync.  Iturn it so it just touches the tab, and then in another two full turns.
this sets it at the beginning of its adjustment range, and allows the slides to still fully lower and close when turned out.
Offline gregripko
« Reply #12 on: September 03, 2013, 11:44:58 AM »
Ok so my issue is that the spring is super tight when the screw touches the tab...
« Reply #13 on: September 03, 2013, 11:48:27 AM »
is it the spring, or the gunked up threads of the idle set screw  ;)
Offline gregripko
« Reply #14 on: September 03, 2013, 11:56:13 AM »
Not sure.....by the time the spring touches tab the spring is super tight making it almost impossible to tighten....either the tab has to move forward or something else that i'm missing.....unfamiliar territory for me
« Last Edit: September 03, 2013, 12:00:00 PM by gregripko »
Offline lucky
« Reply #15 on: September 03, 2013, 12:06:47 PM »
I have a fear it is a mess.
Anyway....
When you sync the carbs the idle screw should be backed off all the way.
Make sure all throttle slides are closed.
Make sure when you start to open the throttle that all 4 slides start to open at the same time.
You can put your finger in the opening of the carb and actually feel when the slide starts to lift up.
Then start the engine and turn the idle screw just enough to keep the engine running.
Sync the idle on the carbs with vacuum gauges.
After you sync the carbs the idle can be a little high, so you can back off the
IDLE SCREWS a little.
Matter of fact when you are syncing the carbs if the idle does not want to go down keep checking the idle screw to make sure if is backed off enough.
This is what is going on.
There is a shaft connected to all of the carbs and when you pull the throttle cable,
it pulls open ALL of the carb slides.
And so when you adjust the IDLE SCREW it turns up the idle, BUT the idle on one of the carbs could be higher or lower than it needs to be because all of the carbs are connected to that same shaft.
So when you sync carbs what you are doing is getting all of the carbs connected on that shaft to all be open the same amount.
THEN you can control the idle with the IDLE SCREW. See what I mean?
« Last Edit: September 03, 2013, 12:11:24 PM by lucky »
Offline lucky
« Reply #16 on: September 03, 2013, 12:10:19 PM »
Great photo.
That idle screw needs to be backed way off so that only about 1/4 inch is sticking out of the bracket.
But this is the important question.
When the idle screw is turned this far IN (excessive), the carb slides must be open when the throttle is supposed to be closed.
When the idle screw is backed off all the way all of the throttle slides should be CLOSED. Are they?.
« Last Edit: September 03, 2013, 12:12:57 PM by lucky »
Offline gregripko
« Reply #17 on: September 03, 2013, 12:13:38 PM »
Another shot disassembled
Offline lucky
« Reply #18 on: September 03, 2013, 12:14:45 PM »
BTW if you tried to tighten that idle screw anymore it would rip the threads out of the plate it is mounted on. Do NOT tighten it any more!
Offline gregripko
« Reply #19 on: September 03, 2013, 12:21:44 PM »
I didn't
Offline gregripko
« Reply #20 on: September 03, 2013, 12:23:15 PM »
I'll check on the slides
« Reply #21 on: September 03, 2013, 12:28:46 PM »
Classic error during vacuum sync is to adjust all four individual adjusters.  This skews the slide positions to where the idle knob can't do it's job.
The idle knob raises all slides at once.  The individual adjusters raise or lower each slide individually, driven from the same arm that the idle knob positions.
The mechanic is to chose which carb is master, (usually highest vacuum reading) and then adjust the other three carb t whatever the vacuum level the master has during adjustment.
If the carbs have been apart, part of the bench sync is to ensure the slide can reach the "floor" with the idle knob backed out, and using the individual slide adjusters.
The idle knob is now reaching the end of its adjustment range because ALL the individual adjusters have biased the actuator arm's position for proper idle.
Offline gregripko
« Reply #22 on: September 03, 2013, 12:35:31 PM »
Can this be fixed through vacuum sync and without ripping apart carbs? Thanks two tired
« Reply #23 on: September 03, 2013, 12:48:51 PM »
Yes, it can.  But, you have to be smart about it.  In essence you have to put one of the carb sync adjusters back to factory position and then adjust the others to it via vacuum readings.
Offline goldarrow
« Reply #24 on: September 03, 2013, 12:51:11 PM »
Yes.  Idle knob at that position indicating very high rpm. You can adjust individual carb to bring up the rpm, then work your way down on the idle know and readjust each carb again. Keep repeating until you reach the level you feel is right on the knob
CB550 K0
