Author Topic: OIL LIGHT 75 HONDA CB550 FOUR  (Read 1014 times)
Offline JACKOCASTER75CB550K
« on: September 06, 2013, 12:58:41 PM »
Hi I ran my bike low on oil not knowing and the light warned me so I topped it off and now the light comes on anything below 2,000 rpm...any info would be much appreciated..
Re: OIL LIGHT 75 HONDA CB550 FOUR
« Reply #1 on: September 06, 2013, 01:33:41 PM »
anyone?
Offline Tews19
  • I am no
« Reply #2 on: September 06, 2013, 01:35:22 PM »
I will buy it since the engine has issues!
1970 Honda CB750 survivor.
« Reply #3 on: September 06, 2013, 01:36:43 PM »
Yeah nice try...I luv it to much already..Thx though
« Reply #4 on: September 06, 2013, 01:52:26 PM »
oil pressure switch hard to replace?
Offline Elan
    • Vital Motor Parts
« Reply #5 on: September 06, 2013, 01:58:58 PM »
No its easy. It just unscrews out of the case. PM me if you need one
76 750k
Offline cabrala
  • Super Duper
« Reply #6 on: September 06, 2013, 02:07:09 PM »
No not hard at all. I'm not sure about the the 1975 but I'll assume it's placed in a similar location on top of the oil pump under the sprocket cover. When mine went bad though it tripped at high engine temps and high revs, when the oil was thinned. I believe the light would stay on once the sensor is blown completely.
I'm wondering if your oil pump is going, due to not pumping well enough at low RPM but pumping well enough at higher RPM. Please wait to get other opinions on that diagnosis.
« Last Edit: September 06, 2013, 02:10:37 PM by Crush »
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Need a better, newer points cover gasket? How about rubber washers for the headlight bucket? Click the link below:
http://forums.sohc4.net/index.php?topic=122308.0
Offline Johnie
« Reply #7 on: September 06, 2013, 02:22:43 PM »
You could take the switch out and check the little hole. It maybe is getting plugged. Worth a look see.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #8 on: September 06, 2013, 02:43:00 PM »
Ill check that... Is there a way to test or clean the pump as well?
Offline cabrala
  • Super Duper
« Reply #9 on: September 06, 2013, 02:59:49 PM »
You can open the pump but the internal o-rings are hard to source so keep that in mind. If you do try to find new rubber make sure that all dimensions, particularly the cross-section is exact.
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
