Author Topic: 71 Honda CB 750.  (Read 2820 times)
Offline ogsmakdade
  • bike newb
71 Honda CB 750.
« on: September 06, 2013, 07:13:55 PM »
Hey everybody, My name is Daryl.  I'm new to bikes, but not new to forums.  I own two 5th Gen honda preludes that are heavily modified, I admin and moderate two prelude forums.
I purchased this bike a few weeks ago from the second owner.  It was jam packed with era correct accessories, but I could see through it all.  I plan on doing a cafe style build, and enjoying this bike for years to come.
Here she is the day I picked her up.
I think she lasted two days before I started tearing the accessories off...
windjammer fairing, highway bars, bags, seat rest, luggage rack, gone!
First real purchase for the bike, a must have IMO
removing the fairing left me without a headlight.  I realized that the headlight mounting rings and hardware were missing, along with the OEM headlight socket.  I purchased them along with a new headlight.
had to fix quite a bit of botched wiring (solder, head strink, OEM pin connectors)
seat was the next on the list, but I had to have something I could fit a passenger on.
picked up this foam and fabric to fit to the stock pan.
after tearing the old cover and foam off the stock pan, I discovered some surface rust.  I did a rust treatment on both sides.
primed and painted the bottom of the pan.
fitted the foam to the refurbished pan
fitted the cover over the foam, and I'm pleased with the results.  p.s. I hate upholstry work haha.
painted the hinges, latch, spring, and installed new stainless hardware to hold it in place.
pic of new seat on the bike.
Parts purchased so far:
-Hanyes CB750 FOUR manual, my new best friend.
-New OEM replica side covers
-NOS OEM side cover bushings
-Footrest, kickstart, and shifter rubbers.
-NOS OEM front turn signal stems.
-NOS headlight socket.
-Deka sealed battery
-NOS rear shock bolts, nuts, washers.
-Male and female wire pins (to fix 40+ years of hacked wiring)
-Aftermarket tri bar, black dot headlight
-NOS headlight mounting bezel and trim ring
-black powdercoated mesh headlight cover
-cafe style seat
-Magnetic oil drain plug
-shock adjustment tool (since the bike already has the $300 progressive rear shocks I was going to buy).
-cafe style handle bars
-Shoei GT Air matte black helmet (most important purchase)
-rear LED turn signals (resistors also)
-rear brake light/ tag holder combo
-Flamenco black pearl paint (for tank, headlight bucket, side covers)
-Hella retro style horn
-new OEM air filter (until the pods are purchased)
Soon to be purchased:
-clutch and brake levers (shorter handles)
-slimline clutch master cylinder
-bar end mirrors
-hand grips
-Firestone vintage deluxe champion tires
-new 4-1 header
-K&N individual pod filters
-front and LED turn signals
-correct 69-71 gas tank (the one on the bike is a 72)
-more responsive throttle control
Maintenance to be performed:
-spark plugs
-coils
-oil change
-new brake pads and shoes
-brake fluid flush
-possible clutch replacement (on the original still, seems to be acting up a bit)
I'll be updating soon, feedback and comments appreciated!
« Last Edit: September 09, 2013, 06:19:06 PM by ogsmakdade »
Everyone thinks Chuck Norris is bad, but Chuck Norris has not meet Lucky either.  Lucky will round house kick Chuck back to 1969 and pop a wheel with the 1st sandcast while shotgunning a PBR!
My "build" http://forums.sohc4.net/index.php?topic=126537.0
Offline ogsmakdade
  • bike newb
Re: 71 Honda CB 750.
« Reply #1 on: September 06, 2013, 07:31:47 PM »
found some NOS side cover emblems, notice the little "HM" right below the wing, the only way to tell if they are legit as far as I know.  They'll look good with the red metallic in the new paint.
I plan on plastic welding and flushing out the top emblem recess and only have the red diamonds.
new reproduction side covers, nos emblems, and bushings to install them.
new bars, to be installed once I acquire the new controls, grips, mirrors.
headlight gaurd....  most likely going to tint the stock headlight yellow and install it on that light...  I like having options.
paint should be in by next week.
still trying to source the appropriate 69-71 tank (to replace the 72 that is currently on the bike.)
rear LED turns, tail light w/ license plate bracket in the mail.
next pictures should be the tail light and turns or the modified side covers.
« Last Edit: September 09, 2013, 06:21:25 PM by ogsmakdade »
Offline ogsmakdade
  • bike newb
« Reply #2 on: September 06, 2013, 08:10:18 PM »
new tail light, tag bracket combo.  Goodbye rear fender!
paint has finally arrived........ I guess I can start working on some parts
Flamenco black pearl 97-98 prelude color, and a catalyzed hardening clear coat.
« Last Edit: September 09, 2013, 06:22:02 PM by ogsmakdade »
Offline Kevin D
  • SE Michigan
« Reply #3 on: September 06, 2013, 10:59:01 PM »
Hey Daryl, welcome, and you are off to a flying start.
Make sure you start a thread in the project shop to track your progress.
I believe that Hondamans book would serve you very well:
http://forums.sohc4.net/index.php?topic=65293.0
When/where are you going to sell those take off parts? I'm a K1 luggage rack away from some serious road miles.
Too bad for Dale that he had to part with his CB. :)
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Johnie
« Reply #4 on: September 07, 2013, 07:08:43 AM »
That sunflake tank looks mint...is it? Would you sell it?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline ogsmakdade
  • bike newb
« Reply #5 on: September 07, 2013, 07:54:54 AM »
Thank you sir!  My wife is not happy about the amount of time and/or money I'm spending on this project, but forward progress full steam ahead.
I'll try and dig the luggage rack out today and take some pictures, it's yours if you want it.  the bags are also for sale.
Dale's wife bought him a brand new honda cruiser for christmas last year.  it's huge and beautiful, but not my style.  I've been updating him on the progress of his old bike.  I guess I got excited and started a build thread in my intro lol.  I'll be sure to transfer the info over to the "shop progress" section.  thanks!
Offline ogsmakdade
  • bike newb
« Reply #6 on: September 07, 2013, 07:56:03 AM »
I responded to your PM.  I'm going to hold onto my faded ruby red tank for the time being, but you have first shot at it when/if she goes up for sale.
Offline Johnie
« Reply #7 on: September 07, 2013, 07:59:06 AM »
OK thanks Daryl...she came across as orange on my screen. She looks like a great project.
Oshkosh, WI  USA
« Reply #8 on: September 07, 2013, 12:55:45 PM »
Welcome Daryl......nice purchase and progress.  Add spark plug caps to your purchase list, about $3 each.
Very nice work on the seat too.
Offline WrenchMonkey
« Reply #9 on: September 07, 2013, 03:10:55 PM »
Welcome!  Your K1 Is a lot shinier than mine is right now.  Looks great!
John
Jack of all trades, master of none.
'71 CB750 K1
Offline ogsmakdade
  • bike newb
« Reply #10 on: September 07, 2013, 09:38:21 PM »
Thanks Johnie, I'm enjoying this bike every step of the way  :)
Thanks Stev-o!  I felt lucky to find this bike in running condition.  She has a lot less original parts than I initially thought, so I don't feel so guilty changing her appearance.  ;D
I actually shorted out one of my xs performance coils today, so I'm replacing it along with my spark plugs, wires and caps.
Thanks man.  The bike is not bad, but the pictures dont show all the dirt, grime and rust.  I love these bikes, no matter the shape!
« Reply #11 on: September 08, 2013, 03:30:04 AM »
Love the seat!
Any plans for the luggage rack?  I might take it if you want to sell.
Welcome, btw :)
Offline ogsmakdade
  • bike newb
« Reply #12 on: September 08, 2013, 07:03:27 AM »
Thanks, I'm happy with how the seat turned out.
I gotta give first shot at the seat to Kevin D, if he passes I'll let you know.
Offline Lazerviking
  • I need help
« Reply #13 on: September 21, 2013, 02:58:43 PM »
Looking good! My bike was also "fully loaded" when I got it. Fortunately she lost some weight since then.
Offline ogsmakdade
  • bike newb
« Reply #14 on: September 21, 2013, 07:55:41 PM »
Thanks!
I'll have to take a look at your build thread.  I'd like to see pictures of your fully loaded bike and its progression.
Here's my build thread.
Offline Lazerviking
  • I need help
« Reply #15 on: September 22, 2013, 04:24:09 PM »
I'll definitely toss you the link once I get my s*** together and get my build thread up and running.
Offline ogsmakdade
  • bike newb
« Reply #16 on: September 22, 2013, 06:08:35 PM »
I'll be looking for the link, Thanks
Offline tool14
« Reply #17 on: September 23, 2013, 05:06:06 AM »
welcome
Offline ogsmakdade
  • bike newb
« Reply #18 on: September 23, 2013, 07:49:07 AM »
thanks.  this site has a wealth of knowledge, glad to be here
