Author Topic: 77 Honda 750f Super Sport Rear Shocks  (Read 2138 times)
Offline reliv77
« on: September 08, 2013, 02:31:45 PM »
First time with a Passenger on my 77 750F. Felt the Rear Shocks bottom out on bumps. Are there New Shocks to replace them? And NO, she wasn't 300 pounds.
Offline Short shins
  • New Zealand
Re: 77 Honda 750f Super Sport Rear Shocks
« Reply #1 on: September 08, 2013, 06:17:22 PM »
Try cranking up the pre load a notch or two.
I recommend Hagon as a replacement
Your welcome
I love sleep. My life has the tendency to fall apart when I'm awake, you know?”
Ernest Hemingway
Offline krusty
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #3 on: September 09, 2013, 01:16:49 AM »
Had this happen too when I had my good lady on the back. It wasn't her fault either, but that didn't stop me letting her think it ;D
Anyways, fitted Hagons and problem solved.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline reliv77
« Reply #4 on: September 09, 2013, 04:35:20 AM »
Can you tell me how to "Try cranking up the pre load a notch or two."
Anyone know what Hagon Shocks fit a 77 750F Supersport? Looks like they have a lot of options.
Offline hillcountrymac
« Reply #5 on: September 09, 2013, 08:04:58 AM »
Just got a set of Hagons for my 1977 750K.Just google Hagon USA and give them a call.They are very knowledgeable and helful with the set up.They'll ask how you ride,1 up 2 up,weight etc.....Then help you select the shock,you buy direct from them,I didn't have a problem and the bike rides much better than with the 35 yr old stock shocks that were on it. Definitely the way to go.
Offline mono
  • Definitely no
« Reply #6 on: September 09, 2013, 08:08:29 AM »
if you look at your shocks, there are tiered notches on them which you can use your spanner wrench to move to your desired selection of pre-load.
« Last Edit: September 09, 2013, 08:13:01 AM by mono »
Offline reliv77
« Reply #7 on: September 09, 2013, 11:09:23 AM »
Thought I would try and adjust them first. They look like they are adjusted to the "Highest Notch Setting." Maybe Factory Setting? Anyone tell if they adjusted to the max in one direction or another?
Offline david 750f
  • 1976 CB750F
« Reply #8 on: September 09, 2013, 12:26:17 PM »
Reliv, if I am seeing that photo correctly the shocks are set to the softest setting. Try turning the collar clockwise so it increases preload.
1976 CB 750F
« Reply #9 on: September 09, 2013, 12:56:27 PM »
+1
crank that sucker clockwise!
Offline reliv77
« Reply #10 on: September 09, 2013, 01:51:39 PM »
Looking fora Spanner Wrench. Local Mechanics do not have any. I see them on line. Anybody know what size Spanner Wrench I need. No other way than using a Spanner Wrench?
Offline david 750f
  • 1976 CB750F
« Reply #11 on: September 09, 2013, 02:07:30 PM »
If you have a centre (center) stand you should be able to do it by hand..
1976 CB 750F
Offline Pat_at_APE
    • APE Race Parts
« Reply #12 on: September 09, 2013, 02:12:29 PM »
You can still order the spanner wrench from Honda.  OEM p/n:  89215-404-670
The online sites show pricing under $4 before shipping.
Regards,
Pat at APE
