Author Topic: Rotor swap  (Read 1611 times)
Rotor swap
« on: September 08, 2013, 07:51:01 PM »
 Since I have the dyno cover off my 836 to degree the cam, and there is a partial F2 motor on the floor does it make sense to swap the rotors? I read the F3 rotor is lighter. A guy I know snapped one off at the crank. He thought I should lighten it.
Re: Rotor swap
« Reply #1 on: September 08, 2013, 08:08:43 PM »
From what I've read, there were two rotors; the early ones had a flange, and weighed over a half pound more the the later style. I don't know when the change was made, or if the F3 was lighter than any previous rotor. If I recall correctly, a K7 rotor weighs about 4 1/2 pounds, while a K1 rotor was about 5 1/8 pounds. I can get you an accurate weight on the K7 rotor, down to the gram, if you like; I have it written down somewhere..
Re: Rotor swap
« Reply #2 on: September 08, 2013, 08:33:42 PM »
Run the lighter looking one if you have two different..
 Unless you are in a drill team,  run two up mostly with lots of. Baggage , or pull a trailer
Offline Dream750
Re: Rotor swap
« Reply #3 on: September 08, 2013, 08:56:53 PM »
I “borrowed” this pic from Cycle X when I did my K1/811 build – note the weight differences:
Re: Rotor swap
« Reply #4 on: September 08, 2013, 09:39:10 PM »
Those weights must include the starter clutch assembly? My weights were without the clutch. My cut-down K1 rotor ended up at 4 pounds.
Re: Rotor swap
« Reply #5 on: September 08, 2013, 09:44:12 PM »
Found my notes: stock K7 rotor = 2079g (no clutch).
Offline Dream750
Re: Rotor swap
« Reply #6 on: September 08, 2013, 09:48:57 PM »
Yes, with the starter clutch. I never ran a cut down rotor, how do you like your 4 pounder?
Re: Rotor swap
« Reply #7 on: September 08, 2013, 09:55:10 PM »
The cut down rotor works fine, but I didn't notice as much difference as when I first swapped from the K1 rotor to the K7 rotor. I've also remembered a member's previous post that stated the early rotor was 1.234 pounds heavier, and how it was an easy number to remember. ;) That jives with the cycle-x numbers.
Re: Rotor swap
« Reply #8 on: September 08, 2013, 10:00:12 PM »
Here is a pic of my cut-down rotor along with a K7 rotor:
Re: Rotor swap
« Reply #9 on: September 08, 2013, 10:02:59 PM »
I checked with a caliper, the F2 looks the same to me as the K4. Thickness and width wise. Hmm. I just read the black motors had a lighter rotor, maybe not.
Re: Rotor swap
« Reply #10 on: September 08, 2013, 10:07:26 PM »
Thanks for the picture.
Offline Dream750
Re: Rotor swap
« Reply #11 on: September 08, 2013, 10:09:13 PM »
Thanks Scott. I was too cheap to have my K1 rotor lightened and went with the stock late style - year unknown. Been wondering about that decision ever since.  :-\
Re: Rotor swap
« Reply #12 on: September 08, 2013, 10:16:03 PM »
A prudent decision on your part, IMHO. I had a lathe and the time and the K1 rotor, so I thought what the heck? If I screwed it up, oh well, I still had the K7 rotor. ;D I'm still curious just when the rotors changed? ???
Re: Rotor swap
« Reply #13 on: September 09, 2013, 12:43:26 AM »
Heavy ended in 72
 I like the lightened rotor, really handy when slipping clutch off the line if you start to bog, easier to control rpm and recover.
 In traffic if i am at the bottom of second gear, i do not always down shift, just as easy to use the clutch and slip it, save shifting twice.. You need a strong clutch..
