Author Topic: Keihin PC 46A stock needle setting?  (Read 7555 times)
Offline cmyoch
« on: September 10, 2013, 10:54:44 AM »
So far, everything I've read on slide needle settings state that the factory settings are dead center. When cleaning my carbs, I noticed that the needles are set to the second position from the top. I do not know the history of this bike but it still had the original exhaust and stock air box. I don't know if this was set from the factory or what any PO may have done in the past. The bike barely ran when my brother bought it but that was due to gummed up carbs.
Any thoughts?
Offline lucky
Re: Keihin PC 46A stock needle setting?
« Reply #1 on: September 10, 2013, 10:58:33 AM »
Any thoughts?
Something is wrong with your information.
What year is the motorcycle?
IS it a CB550 or CB750?
78   CB550K  had    PD46C  carbs. Those had non adjustable needles.
No PC46A's.
Have you actually seen the needles?
If they(slide needles) are adjustable with 5 grooves, then it could b a late 1977 CB550
« Last Edit: September 10, 2013, 11:04:16 AM by lucky »
Offline cmyoch
« Reply #2 on: September 10, 2013, 11:33:37 AM »
Sorry, it's a 1977 cb550. I removed the needles for cleaning last night.
Offline lucky
« Reply #3 on: September 10, 2013, 04:27:00 PM »
Sorry double post.
« Last Edit: September 10, 2013, 04:30:36 PM by lucky »
Offline lucky
« Reply #4 on: September 10, 2013, 04:29:40 PM »
There were two main differences between the 77 and 78 CB550.
The 1977 was
77 CB550K X46A   14.5 float height 90 main jet 38 idle jet    3 needle position
The 1978 was
78   CB550K   PD46C  12.5 float height   90 main   42 idle   NA(not adjustable)
Look at the numbers again. What are they,do you think?
Use a magnifying glass if needed.
« Last Edit: September 10, 2013, 04:31:55 PM by lucky »
Offline cmyoch
« Reply #5 on: September 10, 2013, 04:55:31 PM »
I went ahead and took photos. Is this the stock needle position in your opinion?
Offline cmyoch
« Reply #6 on: September 10, 2013, 05:00:07 PM »
...a shot of the clip position.
Offline lucky
« Reply #7 on: September 10, 2013, 08:47:46 PM »
No that needle clip position would not be right.
Since you have an adjustable needle it would be the 1977 version. 3rd groove down.
What size is your idle jet?
Do your carbs have the accelerator pump on carb #2?
Could you look on the ID plate of the frame headstock, Left and right side and see what it says as far as the year?
« Last Edit: September 10, 2013, 08:53:54 PM by lucky »
« Reply #8 on: September 10, 2013, 10:13:48 PM »
Do note that the carb spec apply to stock configured bikes.  The ones with the stock exhaust and induction.  If either of those have changed the stock carb specs won't be appropriate.
Below is the from the Honda service booklet.
Offline Deltarider
  • I'm back
« Reply #9 on: September 11, 2013, 12:12:16 AM »
Is there a stamped on number on the needle?
The Honda Shop Manual for the 500/550 mentions on p.178: needle E2349F for the CB550K3 and 3rd groove. It doesn't say the carb. number however. I don't know this is of any help because that same page denotes a Date of Issue: July 20, 1977.
Usually not many people ever changed needle positions and float heights. They left them alone, as they were always right. Main jets were changed more often when airfilters or exhausts were non stock. Members of this forum seem eager to experiment with every academic possibilty. But this is just my impression. On the other hand, I remember there were complaints about the 550K3's driveability (and the 550F2's for that matter) running a bit too lean.
Did you have the impression your carbs were opened before?
The 500K3 and the 550K3 certainly had superior silencers. They were amazingly quiet, produced a nice turbinelike sound and it's a shame you can't find them anymore. If you have them, my advice would be: no short rides. If you make long rides only, they go a loooong way. Enjoy!
« Last Edit: September 11, 2013, 12:28:44 AM by Deltarider »
CB500K2-ED Excel black
Offline lucky
« Reply #10 on: September 11, 2013, 01:38:56 AM »
The OP said he has the stock exhaust and the stock intake.
That means the bike probably has not been messed with.
cmyoch is doing the right things.
Still waiting to hear what size the idle jet is because that is a good clue to
nail down the year. But right now it does look like a 1977.
Almost no one changes needles.
They may raise the clip up or down, but they do not change needles.
Lets not get side tracked.
« Last Edit: September 11, 2013, 01:44:35 AM by lucky »
Offline Scott S
« Reply #11 on: September 11, 2013, 03:40:39 AM »
The 1977 was
The 1978 was
 My '78 550K has the PD46C carbs and it has adjustable needles. I need to dig around and find it, but I have the needle and slide #'s somewhere.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
« Reply #12 on: September 11, 2013, 03:41:47 AM »
 And, BTW, that pic show the stock setting for the PD46C carbs.
'71 CB500 K0
'81 Yamaha XS650
Offline ANDY W
« Reply #13 on: September 11, 2013, 06:46:48 AM »
My PD46C carbs also had adjustable needles and the clip was in the second position from the top when i took them apart. Its tough to find the correct info on PD46A and C carbs
Offline cmyoch
« Reply #14 on: September 11, 2013, 06:53:26 AM »
Thanks for the input guys! I didn't get a chance to look at the jet sizes late last night. I'll get the numbers and report back this evening. I'll also get the number off of the needle for you. The more I look at the carbs the more I believe that these were untouched. Unfortunately, I only have the carbs. My brother has the rest of the bike so the specs off the tag on the neck is not readily available. I was only adjusting the clip position due to the fact his jet kit called for the adjustment due to his intake/exhaust modifications.
I started another thread last night stating that the screws holding the arm to the slide barrel on the #4 slide stripped which put this project at a stand still. I considered switching the #1-3 back to the original position (second from the top) and only replace with the jets provided and hope that adjustments to the air mixture screws would solve any lean/rich issues. The only way I can now adjust the #4 slide position is to either drill out the screw which scares the hell out of me or search for a replacement slide and arm set up.
Offline Deltarider
  • I'm back
« Reply #15 on: September 11, 2013, 07:45:04 AM »
My guess is differences in the 550K3-4 needle clip position correlate with the size of the slow jet and the float level used in that particular carbmodel.
Offline ANDY W
« Reply #16 on: September 11, 2013, 07:47:05 AM »
If he changed the intake and exhaust the you'll definitely want to be able to move the needle position. An EZout would work but I don't think you'll have the room. The only way I can think of is to drill it out, if you get a left handed drill bit it might back out while you are drilling
Offline Scott S
« Reply #17 on: September 11, 2013, 07:51:17 AM »
 FWIW, these carbs aren't as lean as everyone thinks.
 I went with a 1.00mm over bore, mild port and polish on the head, match ported manifolds, CB650 cam, UNI filter in stock air box and Jardine 4-1 exhaust.
 I started out raising the needles and going fat on the mains and the bike didn't like it. No top end, wouldn't reach redline.
 After going back and forth with needles and jets, timing, mixture screws, etc., I ended up at near stock settings, with only slightly richer on the idle mixture screws and a 95 (instead of 90) on the main. This is the best the bike has ran.  Try leaving the needles in the stock position if you have one screwed up.
 Exactly what changes has he made?
'71 CB500 K0
'81 Yamaha XS650
Offline cmyoch
« Reply #18 on: September 11, 2013, 08:47:17 AM »
I wish I was home right now to report exactly what size jets I'm putting in. I'll definitely report what was originally in the carbs and what was given to me to install. I'm still leaning towards going back to stock needle heights and try to compensate with the mixture screws.  I don't know his riding style but I think this is going to be more of a cruiser than
I have a '78 Yamaha XS650 that at one time I planned on going all custom with. I did a complete 180 and stuck with the original air box/exhaust setup and only customized the bike with a flatter seat and new bars. Performance ended up being more to my liking than how bad ass I looked on the street. Plus, I didn't want to keep yanking my carb set to make adjustments to get her to run right. Just my two cents.
Offline Scott S
« Reply #19 on: September 11, 2013, 09:53:28 AM »
 XS 650 carbs are much more forgiving.
 And FWIW, the mixture screws only come into play at idle and just above.
'71 CB500 K0
'81 Yamaha XS650
Offline lucky
« Reply #20 on: September 11, 2013, 10:34:12 AM »
Good info Scott.
The OP said in the first post on this thread "stock intake and exhaust."
Now he says, "I was only adjusting the clip position due to the fact his jet kit( from who), called for the adjustment due to his intake/exhaust modifications."
I believe Scott and Award 50 know what they have and they must be right about that clip position.
But we still do not know what carbs the OP has.
The information is still not solid cheeeessshhh!!!
I keep forgetting it is a CB550.  IT is isn't it?
Carb PC46A????
Now I want to see a photo of the bike and the carbs.
« Last Edit: September 11, 2013, 10:36:31 AM by lucky »
Offline lucky
« Reply #21 on: September 11, 2013, 10:40:02 AM »
"I wish I was home right now to report exactly what size jets I'm putting in."
Seems like a strange statement that you do not know what size jets you are putting in.
I wish you would tell us the whole story from the beginning.
Are you in the military?
Are you overseas?
Wish we could help more.
Offline cmyoch
« Reply #22 on: September 11, 2013, 12:16:30 PM »
Lucky, I plan on posting as much information as I can to help answer my questions. I'm at work right now and I'll post info on the stock jet sizes, jet sizes that were in the kit, and the origin of the kit. I'll look back at my original post to see if I stated the origin of this project.
My brother acquired a 77 CB550, bone stock, barely running. He is doing some sort of custom project with it cosmetically along with pod filters and 4 into 2 exhaust which I believe are straight pipes. Given I resurrected and restored my '78 Yamaha XS650 and most recently a '76 GL1000, he asked that I help him with the carbs. He ordered the jet kit and handed me that kit and the carbs and that was it. I'm not in possession of the entire bike, just the carbs, kit, and instructions on the kit. I understand your frustration that I didn't post every bit of information early on and I apologize for that. Please don't convey to the entire board here that there's something fishy going on or that I'm somehow incompetent. I never paid attention to jet sizes because they were already ordered, it's not my bike, I really didn't have any reason to open the package until I'm ready for assembly.
I'll take photos of what I have to help you guys to help me out. I did take a pic of the carb body number and posted earlier in this post. I just looked and I whole heartedly apologize that I posted the wrong info. It's a "PD", not a "PC". In my haste to type up the post, I misspelled. Based on what has been given to me so far, I believe that the second to last clip position is the factory setting here. Unfortunately since the last slide I worked on stripped out, I'll have to figure out how to extract those screws if you guys think that a needle adjustment is necessary based on the jet sizes that I'll post later on today.
Again, I appreciate all the help I'm getting here. If it wasn't for the XS650 forums and the GL1000 forums, I wouldn't be where I am today with my bikes. There's more value in all of these groups than one can ever imagine!
Offline cmyoch
« Reply #23 on: September 11, 2013, 03:48:04 PM »
Okay, I'm home from work and the information I neglected to post earlier.
Jets I removed were all 90's
Jet kit comes from 6 Sigma Racing
Jets in the kit are 105s for the two outer cylinders and 107.5 for the inner two cylinders
There are also 2 102.5s and 2 110s which I assume are included in case it still runs too lean?
The kit called for the slide needle clips be moved one position down to heighten the needle.
The needle number is E23501 (Barely legible even with a bright flashlight and a magnifying glass) The E could very well be a B.
Anything else I may be missing to help troubleshoot this?
Offline Scott S
« Reply #24 on: September 11, 2013, 08:19:48 PM »
 Why all these big changes?
 What intake, exhaust, etc., are you running? What makes you think that you need to make BIG changes on the jetting?
'71 CB500 K0
'81 Yamaha XS650
