Author Topic: and so it begins, cb550k under the knife  (Read 42239 times)
Re: and so it begins, cb550k under the knife
« Reply #50 on: February 12, 2015, 06:00:34 PM »
There's a vendor that makes replicas but Honda will not provide a replacement.
Offline DMcD
« Reply #51 on: February 17, 2015, 03:04:30 PM »
Got the stand brackets completely removed today.  As mentioned before, there was a lot of rust underneath, but it ground off, leaving clean metal behind.
95% of the grinding finished.
I had been looking forward to doing some welding on the frame.  I have said already that I am only a hobby welder, and tidying up the welds with the tig proved more challenging than I had hoped.  Some of the welds were ok, but others proved quite difficult due to what I think was rust/dirt/moisture in the joints, which is a bit of a no no for tig.
Oh well, at least most of the crappy mig welds, are now masked by crappy tig welds  ???
Offline DMcD
« Reply #52 on: February 18, 2015, 09:09:53 AM »
Made some patterns for the rear gussets using some tin.
Will hopefully get some made tonight using heavier metal.
Do they need to be done on the inside and outside of the frame, or is one side sufficient?
Offline DMcD
« Reply #53 on: February 18, 2015, 09:11:07 AM »
Some of that is impurities, some of those air bubbles is from tapped gas and heat. Slow down perhaps, and only TIG a smaller section at a time and let the metal cool. That helps a lot with keeping the beads from blowing out.
Aye, its a black art isn't it.  Cheers for the advice.
Offline DMcD
« Reply #54 on: February 18, 2015, 02:01:47 PM »
Got the rear gussets welded in.
I'll have to search the forum for pics of the swing arm and headstock bracing, if someone can point me in the right direction?
« Reply #55 on: February 18, 2015, 02:20:49 PM »
That's some robust bracing.  Some folks also do an X brace on the back side of the frame below the carbs and a cross-brace at the bottom of the down tubes.
« Reply #56 on: February 18, 2015, 07:25:19 PM »
Above the swingarm pivot.... ;)
Offline Bluegreen
« Reply #57 on: February 19, 2015, 09:32:06 PM »
This project is rad!
Offline DMcD
« Reply #58 on: February 20, 2015, 01:47:12 AM »
Thankyou Bluegreen, your encouragement is appreciated.  I grew up in the 70s and 80's in Northern Irelands fantastic real roadracing heyday, and I am kind of going for a "home made" look, and wasn't sure if people would "get it".  I used to marvel at people going out to risk their lives on bikes that had obviously been made in a shed!
http://rutube.ru/video/35300bbe810d83decfe636bc9d7e6527/#
« Last Edit: February 20, 2015, 02:16:01 AM by DMcD »
Offline DMcD
« Reply #59 on: February 20, 2015, 01:50:42 AM »
Called at my local engineering company today.  They estimated £120 for the rebore to take the chinese 601 pistons.  He said one cut is £80, but they would probably have to do 3 cuts.  I thought it was quite cheap, but I think he recognised me from getting previous work done there.
« Reply #60 on: February 20, 2015, 02:49:00 PM »
Thank you so much for that link, DMcD.  I had never seen or heard of that movie although Joey Dunlop is a hero to me...Very cool to see something about his roots and his less famous peers, who are now just as much of hero's as him.
Offline DMcD
« Reply #61 on: February 20, 2015, 03:34:47 PM »
I wondered if anyone would click on the casually dropped in link
Offline Restoration Fan
  • My wife will never call me
« Reply #62 on: February 20, 2015, 03:36:15 PM »
Yep.  I watched about 20 minutes of it this morning and plan to watch the rest tonight when I have more time.  Enjoyed it very much so far.
Offline DMcD
« Reply #63 on: February 20, 2015, 03:44:48 PM »
Haha classic, although I have owned and watched it many times, strangely the Russian youtube film Was the first time I saw the Directors comments at the end!
Offline DMcD
« Reply #64 on: February 20, 2015, 03:58:19 PM »
Ground off, and filled the steering lock.
Welded the steering head rivetted section, front and back, remembering not to weld round the bottom.
I have a friend with an old milling machine, so got some billet aluminium off ebay for £12 to try making footrest hangers.
Offline DMcD
« Reply #65 on: March 04, 2015, 02:59:02 PM »
Got a couple of wee bits made on a friends lathe last night including an m8 threaded boss for my Chinese adjustable and rebuild able steering damper, which I tigged on tonight.
I should have measured this before I took the engine out, I hope it clears the head.......
« Reply #66 on: March 04, 2015, 03:00:41 PM »
Nice dimes on that weld!  :)
« Reply #67 on: March 04, 2015, 07:13:41 PM »
I'm concerned your damper clamp is going to limit travel. In case you haven't yet, with the fork fully extended, measure from the top of the forkleg to the underside of the lower triple clamp. Then remove a forktube cap, take a spring out of one fork and fully lift the leg. You'll then see how close the top of the forkleg comes to the underside of the lower triple. Measure the distance between the same two points when fully compressed.
Obviously the difference between measurements is your total travel. (depending on the model forks 115mm or so?) Especially on the track at speed you'll want to tune your forks to use as much of the travel as possible, less 10mm or so.
Could the damper clamp go upside down above the triple?
Offline DMcD
« Reply #68 on: March 04, 2015, 11:11:11 PM »
I think so, but there is a slight restriction in the ball joint at that angle, I'll try it tonight.  I should probably have put the engine back in to check it too before welding.....
« Reply #69 on: March 05, 2015, 03:58:50 AM »
Check your fork travel first, maybe it can be moved closer to the clamp & still be ok.
Offline DMcD
« Reply #70 on: March 05, 2015, 10:03:55 AM »
Yip, looks like I'll have a few options.
Offline DMcD
« Reply #71 on: March 14, 2015, 11:11:41 AM »
Think that's the majority of the frame fabrication done now, still footrests to sort out, but took some pics today just in case anybody wants to learn from my mistakes if this all goes wrong ;-)
Offline DMcD
« Reply #72 on: March 16, 2015, 04:43:37 PM »
Made up a footrest hanger tonight, bit agricultural looking, but I will be lightening them on a milling machine.  I will also need to find pics of a rear brake cable setup.
« Reply #73 on: March 16, 2015, 04:54:29 PM »
Can you post a photo of where you plan to attach your aluminum mounts to the frame?  They look pretty robust.  Any particular reason to form them at a 90 degree angle?
Offline DMcD
« Reply #74 on: March 17, 2015, 12:49:13 AM »
I saw that the passenger footrest mounts are at 90 degrees, and it was also the easiest angle for me to replicate accurately.
Mounting to the frame will just be welded on lugs.
