Author Topic: crappy idle  (Read 1053 times)
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
crappy idle
« on: September 12, 2013, 12:01:07 PM »
Anything beside slow jets that would cause bad idle or is this to vague of a question,runs fine mid range just at idle and slow speed
Offline Elan
    • Vital Motor Parts
Re: crappy idle
« Reply #1 on: September 12, 2013, 12:04:02 PM »
It is too vague :)
you just got points didnt you? Timing?
What do your plugs say?
Have you gone through the carbs? Stock idle jets?
engine mods?
76 750k
Offline neilc
Re: crappy idle
« Reply #2 on: September 12, 2013, 01:02:24 PM »
ya have gone to points,plugs are soot,running 120 main jets,middle clip position,valves set,4 into 2 exhaust,pods,i am runnings used points and condensors,timimg and point gapes all seem to be okay also did a carb sync with mercury gauges,bike runs fine just idle is the issue,maybe inline filters to carbs i have is restricting flow,every time i turn open pet i can see gas flowing intoo the lines
Re: crappy idle
« Reply #3 on: September 12, 2013, 01:09:45 PM »
slow jets(what size are yours?)
mixture screws
idle screw setting(too low)
incorrect float setting
timing
valves
clogged emulsion tubes.
post a picture of your plugs.
Offline neilc
Re: crappy idle
« Reply #4 on: September 12, 2013, 01:41:10 PM »
40 slow jets,26mm float height, valves and cam chain tensioner set,2 full turns on air mixture seems to like it their funny thing is every time i pull carbs and clean then reinstall the bike runs great including idle
Offline lucky
Re: crappy idle
« Reply #5 on: September 12, 2013, 01:45:26 PM »
Three important facts missing.
Year of the carbs.
Type of exhaust.
Type of intake.
Offline neilc
Re: crappy idle
« Reply #6 on: September 12, 2013, 01:57:56 PM »
How do find out year of carb the motor is 1971 k1  7a j1 carbs  exhaust was stock buut po cut them and welded on tips pod filters i' post pics
Offline lucky
Re: crappy idle
« Reply #7 on: September 12, 2013, 08:45:28 PM »
Do you have a photo of the carbs?
Pod filters.
Exhaust ? Photo? Do they have baffles?
Offline neilc
Re: crappy idle
« Reply #8 on: September 13, 2013, 05:42:48 AM »
took pics with my i phone but can't get the size down to post,
Re: crappy idle
« Reply #9 on: September 13, 2013, 05:50:14 AM »
Rust in your tank getting into carbs after they have been cleaned? Even with your inline fuel filter it may not be enough. Id check inside the tank. Same thing happened to me when i swapped fuel tanks - idle was crappy but bike ran ok (not great but ok).
Good luck!
Andy
