Author Topic: 72 cb750 Project,GSXR front end- Version 2.0 coming  (Read 60271 times)
Offline danfr
    • Apollo Motorcycles
Re: 72 cb750 engine rebuild/project/ gsxr front end
« Reply #25 on: September 16, 2013, 01:20:20 PM »
Some options for valve train parts:
http://cbrzone.com/sohc.html
http://www.cyclexchange.net/Engine%20Parts%20Valve%20Trane.htm
Keep in mind a few engine upgrades you may want to consider (unless you already have):
-New primary chains and tensioner
-New HD cam chain and tensioner assembly
-Replace oil pump O-rings
cheers
Dan
I will be doing all of these while I'm in there. Figure I might as well do it right and this engine will last me hopefully another 20 years
Every post ive read about building (from what i can recall) and engine suggests replacing the primary chain and tensioner but they dont say why. What the reasoning behind replacing them beside age?
Primary chains will stretch and wear. Tensioner will become hard and brittle with age, potentially breaking off pieces and causing damage.
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline jojo
« Reply #26 on: September 16, 2013, 03:04:35 PM »
Got it, I didnt know that tidbit of info. appreciate your help 8)
Offline edwardmorris
  • Youngish
« Reply #27 on: September 17, 2013, 08:28:37 AM »
Your pace of progress is very encouraging, following this thread as I will soon be disassembling my 72K2. Would be extremely helpful if you could post a list of everything you replaced within the engine  (gaskets, seals, o-rings pretty much anything....I plan to do this when I open up mine) so that a noob like me can plan ahead and have all the stuff at hand before diving in.
« Reply #28 on: September 17, 2013, 09:31:08 AM »
Since you are going to replace/rebuild the valvetrain, have you also considered porting the head?  Increasing the displacement to an 836?
$190!  Great deal on the GSXR front.  How's the clearance on the brake calipers to the spokes (assume you are lacing up the front)?  Do you need to machine off (shave) material from the wheel side of the calipers?
I like the look of this bike, especially with the blue tank.
Offline jojo
« Reply #29 on: September 17, 2013, 10:22:35 AM »
I thought about it but for now im sticking to the stock setup. Porting and bigger pistons and machine work would be out of my current budget.
I havent been able to mock up the entire front end since I still have to drop of my wheels for powder coating before I lace them. I still have parts coming in so as they start coming in i will start putting it together.  Also, the tank is a greenish color but the filter changed it up a bit but i will be keeping the stock tank
Offline jojo
« Reply #30 on: September 17, 2013, 10:24:33 AM »
Edward- Im still working on this list myself. Once i have the cases back from the machine shop I will let you now. I did get a engine seal kit and complete gasket kit as well. I also bought a hd cam chain, new tensionser setup.
« Reply #31 on: September 17, 2013, 03:58:28 PM »
I am not sure what your plans are for finishes -- whether you are re-painting, but the patina on the tank (as is) looks cool.
Offline jojo
« Reply #32 on: September 17, 2013, 10:25:00 PM »
im actually considering keeping it as is to keep that old look. i really really like the tank the way it is now. maybe just buff it out for a bit more shine
Offline jojo
« Reply #33 on: September 17, 2013, 10:26:50 PM »
Jojo - what hub is that in your earlier picture (I assume its for the front end). And what hub are you planning for the rear?
its for the front, it came of a harley narrow glide wheel. i will be keeping the stock rear hub and polishing it
Offline jojo
« Reply #34 on: September 19, 2013, 09:48:35 PM »
any one know if the original hub and spokes will mount to an excel 4.5" wide 18" wheel?
Offline jojo
« Reply #35 on: September 19, 2013, 10:17:39 PM »
was able to get the fabrication done for a plate that will bolt up on top of the battery tray. I still need to sand down the edges and get it painted but this is where the bolts that will hold the seat in place will be fitted. The seat will have threaded mounts on them and the bolts will go in from underneath.
Uploaded with ImageShack.com
new shocks from dcc came in today.
Offline Tews19
  • I am no
« Reply #36 on: September 20, 2013, 07:28:18 PM »
Damn Jojo, thanks for the invite to the party! Well it's better to be late then never to show up... Subscribed!
1970 Honda CB750 survivor.
« Reply #37 on: September 20, 2013, 07:48:43 PM »
Looks good..   350 seems steep for a front hub.. I may be able to do better than that.
Offline fastbroshi
  • Puppet
« Reply #38 on: September 20, 2013, 09:08:45 PM »
  I'd love to see how you do it if so 754.
Just call me Timmaaaaay!!!
Offline jojo
« Reply #39 on: September 20, 2013, 11:41:32 PM »
Sorry Tews, i still havent gotten around to figuring out how to add my sig.
Offline jojo
« Reply #40 on: September 20, 2013, 11:44:20 PM »
It is, thats why i went with the harley hub. I was able to find a dual disk hub and 19" 2.5" wheel for 160.  All I  need now is to redrill my hayabusa rotors and buy some spacers/bearings and the front will be done. Still need to buy a front fender.
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #41 on: September 21, 2013, 03:18:11 AM »
Please document with details on how you do this. My 07 GSXR600 front end is enroute to my place right now. Planning on going with the hub you quoted earlier. I talked with him in detail about it. Even swapped some numbers over the phone on specs. He told me 320.
I do tasks the most difficult way. My life is interesting.
1978 750K
1978 550K on a table
2009 Ducati Monster 1100
77/78 cool 2 member
Offline jojo
« Reply #42 on: September 21, 2013, 10:17:11 PM »
He may  have dropped the price im not sure. Devins a good guy, its just not in my budget right now otherwise i would do it.  I will take a lot of pictures. You are going to need some hayabusa rotors and some spacers as well.
Offline jojo
« Reply #43 on: September 21, 2013, 10:27:12 PM »
Finished detabbing and grinding the frame.  Then stripped with aircraft remover, finished up with wire brushes then hit with rustoleum rust proof primer and then some coats of semi gloss protective paint. will be doing 3 more coats tomorrow.
cleaned with mineral spirits before primer
primer
then semi gloss
Offline jojo
« Reply #44 on: September 21, 2013, 10:29:42 PM »
I decided to go this route instead of the powder coating simply because I want to be able to say i did as much of this build as possible. Hopefully my prep work was good enough and my primer/paint coats thick enough so that i dont regret this later on.
« Reply #45 on: September 21, 2013, 10:55:22 PM »
I couldnt bring up a pic of that guys hub..pics did not load.
 I suspect itis done by CNC.. I work with manual machines, hub may be a bit plainer looking.
Offline jojo
« Reply #46 on: September 22, 2013, 02:48:09 PM »
As long as it fits, it will be covered up anyways. Inner diameter is 56.25 mm, Outside diameter 69 mm
Offline fastbroshi
  • Puppet
« Reply #47 on: September 22, 2013, 08:06:32 PM »
Offline Tews19
  • I am no
« Reply #48 on: September 22, 2013, 08:29:39 PM »
Fastbroshi, where did you get that from? Is it a direct fit?
Offline jojo
« Reply #49 on: September 22, 2013, 09:01:28 PM »
Its from Devins website cognitomoto.com . He designed it for his build on his 550. He still has them in stock if youre interested.
