Hello, I am having some issues with my 1971 CB 750. Bike was running fine until one day mid June when the battery began to drain. I kick started the bike and rode it for the duration of the day. The next day I kick started and rode to work, upon my return trip the bike kick started fine and rode fine until about a mile or so away from home when it back fired a few times and power dropped past 2500 rpm or so. So being close to home and living in the city I nursed it home on back roads in 2nd gear. Upon inspection I immediately thought of points/timing. So i opened the cover to the points to discover that the previous owner had converted to an electronic ignition. Therefor this is ruled out, correct? or not? Then I checked the coils which were good. Upon testing and starting it up in vain the backfiring increased and now sounds as though it is missfiring as well. This got progressively worse and now blows the fuse every now and then. I took all the plugs out and checked for spark, all OK.
When I first got the bike it blew a the fuse in the middle of no where at night, for no reason, as i was just going a steady 55 through country roads. Never blew it again. Also sometimes when turning the key from off to on, and then past on it will try to engage the starter for just a second. I also noticed while checking the plugs that when either switching the key from on to off, or the kill switch from on to off the plugs will arc a yellow/oj arc. Is this normal?
So i believe there is probably short somewhere, but whether it is in connection to my current missfire/backfiring problem or a whole separate issue I do not know. Could a short or faulty wiring be the culprit of the miss/backfire?
I looked in my Honda shop manual and Haynes manual and both do not have any information on checking the timing chain. Could this even be the issue at hand? If so how does one go about checking this?
A final note about the bike: it has been bored to 836cc and has an aftermarket camshaft which may make timing issues hopless to check/read.
Any advice or suggestions would be warmely welcomed.
Thank you!
