Author Topic: 78' CB750F It's finally done!  (Read 1870 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« on: September 14, 2013, 11:52:18 am »
Got this about a year ago. Looked to be in pretty good shape, thought I could "flip it quick" so there aren't any "before" or "during" picts. Turned out ALL the electrical connectors and switches needed a complete cleaning, inspection, and some replaced. Calipers (3) and master cylinders (2) rebuilt, rebuilt forks, new tapered steering stem bearings, new (aftermarket) seat cover, rebuilt carbs, new tires and tubes, new battery, Dyna-S ignition, new o-ring chain and sprockets, new petcock w/filter, little paint here and there, all cables lubed and adjusted, new rubber at the rear fuel tank rest, new rear wheel bearings, new shocks, numerous stripped/broken/missing bolts corrected, and addressed a couple of oil leaks. The seat, grab rail, headlight bucket, and rear fender had to be sourced since the ones that were on it were not model/year correct. Overall, I'm happy with it, would ride it anywhere, and am going to go ride it now just to watch the odometer roll 24,000.
No idea what possessed the P.O. to paint the cases grey. I'm a fan of the "Black" motors. Verified the engine serial #'s just in case, and the engine is indeed specific to the 1978 "F" series. The frame and engine #'s are close, so I'm inclined to think this is the motor that it came with.
Oh yeah, picts or it didn't happen!
« Last Edit: September 14, 2013, 11:58:48 am by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: 78' CB750F It's finally done!
« Reply #1 on: September 14, 2013, 03:02:22 pm »
Looks real good Wilbur, nice job.  Are those stock F bars, look a little higher?
Offline lwahples
« Reply #2 on: September 14, 2013, 03:26:30 pm »
Looks Sweet! Nice job cleaning the bike.Wish my F was as clean.
« Reply #3 on: September 14, 2013, 04:34:20 pm »
Definitely not stock bars. They are a lttle bit higher and they are substantially "swept back" more than stock. I did not care for them at first, but I really like the way they look and they are actually starting to grow on me.
TAMTF...
Wilbur
Projects:
Offline Robbo22
« Reply #4 on: September 15, 2013, 06:09:39 am »
Wilbur,
Bike looks great!
A couple of questions - I have the same bike.
Where did you get the seat cover?
Who made the windshield?
What exhaust did you use?
Good luck on the sale.
Rob
« Reply #5 on: September 15, 2013, 06:29:54 am »
The seat cover is the Saddleman seat cover from Dennis Kirk. I put new upholstery strips around the inside lip of the seat pan so I was able to remove the extra material on the Saddleman cover that is used for the "drawstring". This extra material is stitched on so removal involves cutting the stitches, not the material.
The windshield came off my K8 and I've had it so long I can't remember where it came from. I have seen similar ones online, I really like the all clear, small profile windscreens. they don't overwhelm the bike's profile, and I usually just need something to knock the blast off the torso on longer rides.
The exhaust was on it when I got it and looks like a Mac 4 into 1.
TAMTF...
Wilbur
Projects:
