Author Topic: Did the old owner FUBAR this fork seal?  (Read 771 times)
Offline swoardrider
« on: September 14, 2013, 09:32:34 PM »
The little spring in the rubber isn't looking too healthy. how important is the spring thingy?
Thanks in advance.
Offline Gordon
  • 750K1, 550K2
Re: Did the old owner FUBAR this fork seal?
« Reply #1 on: September 14, 2013, 11:31:39 PM »
Does it leak?
If yes, replace it.  If no, leave it be.
« Reply #2 on: September 15, 2013, 08:23:53 AM »
+1.
And.... if you do replace it (not the smallest job either) get a piece of PVC pipe to drive the new one back on. Get one from Honda and not aftermarket!
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #3 on: September 15, 2013, 09:29:41 AM »
If you can see the spring from the top the seal is upside-down isn't it?
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #4 on: September 15, 2013, 09:37:49 AM »
Yes.
Offline martin99
  • UK Based, Non-
« Reply #5 on: September 15, 2013, 09:50:40 AM »
IMO - bite the bullet, replace that seal and the other one if it is also the wrong way up. I've known incorrectly fitted seals to fail quickly, and the last thing you want is brake pads covered in fork oil.
Build threads:
1977 CB750 F2
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: September 15, 2013, 09:54:41 AM »
Some seals have a spring on both sides.
Offline robvangulik
  • Honda Fourever
« Reply #7 on: September 15, 2013, 10:15:31 AM »
True.
But they always have a flat top to tap them in their groove! :)
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=ud7ep6963es76bfp3r56dp7qq0&/topic,60973.0.html
« Reply #8 on: September 15, 2013, 10:15:45 AM »
some,, puts 2 smaller seals in..to get sealing from both sides..and (they kosts less standart thing in europa)metric stuff
i hate all this v-w.... vords
Offline robvangulik
  • Honda Fourever
« Reply #9 on: September 15, 2013, 12:10:15 PM »
Yep, they did put in double seals (even I did that, long ago) but modern seals do their work much better. And you also double the stickslip, making the forks much less sensitive on small bumps!
Offline swoardrider
« Reply #10 on: September 15, 2013, 12:30:31 PM »
Thanks guys.  Your knowledge on this forum very much appreciated.  Looks like the brake side fork is starting to leak so I will be replacing both. I'm not surprised, as the PO was a hack, and mickey moused almost everything on this bike.   This summer I've unexpectedly become a slave to the CB750, and this forum is my new bible.
Offline swoardrider
« Reply #11 on: September 15, 2013, 12:39:15 PM »
While on the topic of forks, do all CB750k's have the mounting holes on their right forks for a dual brake set-up?  If so, why did the factory do that?
Offline robvangulik
  • Honda Fourever
« Reply #12 on: September 15, 2013, 01:05:17 PM »
Did you ever see a CR750, or any CB750 racer for that matter, with a single disc?
Well, thats why..... ;)
Offline tlbranth
« Reply #13 on: September 17, 2013, 06:27:54 PM »
Nice catch
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #14 on: September 17, 2013, 06:58:51 PM »
If u do decide to change the seals, you must really polish those fork tubes. If you can feel it with your fingernail, it will leak fairly soon. It is upside down. Honda seals seem to last very well.
