Author Topic: Rockers hitting caps  (Read 6773 times)
Offline wally550k0
« on: September 15, 2013, 06:08:48 AM »
After adjusting the valves last night I noticed it was still quite noisy on the top end.  While probing I found a lot of noise on the caps themselves and when backed off it went away.  I pulled one, swapped it with an original and got the same results.  The rocker is perfectly centered on the valve stem tip, so I don't think they're offset from having the cam cover off.  The picture below shows how the rocker has chewed away at the edge of the cap.  Irrelevant but this is from the intake #1 valve.
Offline OT7
Re: Rockers hitting caps
« Reply #1 on: September 15, 2013, 07:13:37 AM »
You need.
Offline lucky
« Reply #2 on: September 15, 2013, 07:17:27 AM »
I hear this complaint all the time on this forum.
It is a known issue.
Offline wally550k0
« Reply #3 on: September 15, 2013, 03:26:16 PM »
You need.
Thanks, I'd add this to the wish list of all things unobtanium.  Surely it's out there somewhere...
Offline wally550k0
« Reply #4 on: September 15, 2013, 03:28:01 PM »
Assuming the seller is honest and knowing the rest of the bike reflects the odometer reading, do you think the cover wear is possible at only 5.3K miles?  It should only be barely broken in.
Offline OT7
« Reply #5 on: September 15, 2013, 04:20:25 PM »
My 1976 CB550F went bad at 10,200 miles.
Also had to replace camshaft and 4 rocker arms.
Got the improved cylinder head cover set under warranty.
« Reply #6 on: September 15, 2013, 05:16:23 PM »
You need.
Was this the barn find bike you bought in Austin?
Offline wally550k0
« Reply #7 on: September 15, 2013, 05:56:28 PM »
You need.
Yes, it is.
Offline wally550k0
« Reply #8 on: September 15, 2013, 05:58:31 PM »
Wow, that early?  I guess that answers my question.  Something tells me warranty won't cover mine...
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #9 on: September 16, 2013, 10:33:50 AM »
Something tells me that a different valve cover won't fix it either. Could you post a pic of one of the offending openings showing the adjuster screw and locknut?
MCN DTF
Offline wally550k0
« Reply #11 on: September 16, 2013, 05:19:32 PM »
I'll let the following pics speak the obvious...
Intake 1 rocker:
Exhaust 1 rocker:
Intake 1/2 rocker shaft:
Exhaust 1/2 rocker shaft:
If anyone know who stocks the bits please post up.  I haven't had much luck so far.
Thanks to all for the advice and information.  I'm new to these old Honda bikes and I really appreciate it.
« Last Edit: September 16, 2013, 05:42:24 PM by wally550k0 »
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #12 on: September 16, 2013, 05:44:39 PM »
Wow, that 1/2 side is BAD.
« Reply #13 on: September 16, 2013, 10:27:53 PM »
I wouldn't be surprised if you can get a new rocker cover from Honda.  But, be ready to spend $350.
Check out ebay for a 77-78 Cb550 rocker cover assembly.  And see if you can't get the cam to go with it.  With the wear your's shows, I'd be wary of the existing cam lobes.
This one is listed as a 76, but is the newer style.    I can't tell about the condition.  I'd ask for more detail of the defects and a picture of the rocker follower faces.
http://www.ebay.com/itm/1976-HONDA-CB550-CB-550-VALVE-COVER-HEAD-ENGINE-MOTOR-/390343513170?pt=Motorcycles_Parts_Accessories&hash=item5ae2495452&vxp=mtr
« Reply #14 on: September 16, 2013, 10:37:02 PM »
Cant these just be re bushed?
« Reply #15 on: September 17, 2013, 09:51:20 AM »
Sure.  That was my first thought, as well.  It is a matter of economics.
Find/make 16 bushings for the 11.5mm shafts.
Align bore the cam cover to the bushing o.d. over a depth of of about 8-10 inches, maintaining parallel geometry with the camshaft.
Press in the 16 bushings sequentially.
The results still allow the shafts to turn and wear the bushings, rather than the rocker pivot steel and the shaft hard coat on steel.
How much would that cost?  A few years ago, I found 77-78 cam covers for $40 on Ebay.  I certainly understand that when parts become scarce enough, the above process will be economically viable.
I understand why Honda pinned the shafts of the improved cover.  It was cheaper than tightening the bore tolerances so the shafts couldn't turn and scrapping existing stock.
Offline EkiF
« Reply #16 on: September 17, 2013, 10:32:53 AM »
Does 350/400F share the same problem of the wearing cam cover as 500/550F?
My 400 four has quite noisy valve train especially when the motor is cold. With the warm engine the valve train sounds almost good but there's a little tapping noise that makes me worried. I have checked valve clearances and synchronized carbs.
-77 CB 400F-
Offline wally550k0
« Reply #17 on: September 17, 2013, 04:56:16 PM »
Score!  I think I got the last one in the Western Hemisphere.
« Reply #18 on: September 17, 2013, 05:40:46 PM »
Is this the one for the pinned rocker shafts?  Or, the older style?
If older, do something to prevent the rocker shafts from turning.  Perhaps orings pushing on the shafts between the shaft ends and end plugs.
« Reply #19 on: September 17, 2013, 05:50:35 PM »
Great!  Where?
Offline wally550k0
« Reply #20 on: September 17, 2013, 09:41:54 PM »
This is the newer style with the pinned shafts.
Offline wally550k0
« Reply #21 on: September 18, 2013, 05:45:02 AM »
Offline wally550k0
« Reply #22 on: September 20, 2013, 07:42:45 PM »
My favorite brown truck visited today.
Time to get her back on the road, there's a vintage show and movie night at Moto Liberty in Dallas.  Peter Starr himself will be there showing one of his movies.
« Reply #23 on: September 20, 2013, 08:44:31 PM »
Get familiar with the "rubber band trick" before you install that new beauty.
http://forums.sohc4.net/index.php?topic=124110.0
Offline wally550k0
« Reply #24 on: September 21, 2013, 06:22:24 AM »
Since my lash adjustment were starting from nothing I backed them all off to the max and it went on quite easily.  Next time I pull it I'll band it so it's less work.  Thanks!
