Author Topic: 1972 CB750 Four K2 -- Rebuilt to NEW OLD STOCK -- PIX ON PAGE 50  (Read 244916 times)
Offline edwardmorris
  • Youngish
Re: 1972 CB750 Four K2 -- Project "Ice Cream"-- SLOW ASSEMBLY
« Reply #1100 on: June 09, 2015, 04:36:43 PM »
Turn buzzer spruced up nicely! New sleeving and terminals (last of my samples  :(). I located a NOS one but its outrageously priced for something that will most likely be ripped out by the Future Owner. I wired it entirely separate all the way with its own sleeve throughout so should be easy peasy to pull. This one came from KC_Northstar as well along with the gauges and controls. Looked to be in great shape until installation >:( Lubed up its mounting rubber end with silicone, 3/4th of it slid into place, then the last chunk just craked and fell off >:( >:(. It stays in place pretty well, but for added insurance...... :-[ :-[ :-[.......I used  :-[ :-[ :-[ :-[ :-[........zip ties :'( :'( I'm officially an PO now :-X
Wanted to finish up the rat's nest next so got the headlight shell out of the yamiya body kit packaging. Bought this handy HL mounting kit either form Z1 or 4into1, can't remember. Has all the bushings, screws etc. etc. in one place.
  • Youngish
« Reply #1101 on: June 09, 2015, 04:42:22 PM »
All new everything for the turn signals and their mounting hardware. Sorely disappointed in the signal stems, my rechromed ones outshine these by miles (can't use them coz they were for K4+ and already sent to a member who needed them (traded for smaller aftermaket ones IIRC)). The signals themselves have beautiful chrome, but those pesky DOT Honda stickers made a gooey mess. Had to clean it up >:( >:(
Here we are, nice and clean, but still a damned rat's nest. This took all of 9 miuntes to finish up, which worries me greatly. I think I have it all done right, will go through it again. Everything is accounted for EXCEPT a solid brown wire with a female terminal. There is nothing (besides the three headlight wires) left to go with it. Is this some Euro specific thing?
  • Youngish
« Reply #1102 on: June 09, 2015, 04:46:15 PM »
AND hello search!
No clue who made the replacement harness, but I think I'm looking at this
http://forums.sohc4.net/index.php/topic,110284.msg1236333.html#msg1236333
Offline calj737
  • I refuse...
« Reply #1103 on: June 09, 2015, 04:52:13 PM »
Best way to verify that is with a meter.
  • Youngish
« Reply #1104 on: June 09, 2015, 05:07:26 PM »
I might just get lucky and not need to bother with it. There's only one fuse on the K2, no separate fuses for HL/TL etc. Will wait till Mark swings by and confirms. I'm planning on skipping the fuse box altogether and use the automotive style fuse hooked straight into the harness leads.
Offline jerry h
« Reply #1105 on: June 09, 2015, 08:23:39 PM »
Wow, really looking good!  Your bike will be as close as you can get to a new "NOS" bike.  Very nice! ;)
  • Youngish
« Reply #1106 on: June 10, 2015, 09:33:05 AM »
Thanks Jerry!
So my first guess about that brown wire was right, its a Euro park lamp thing, so leaving it be. Checked tracking on the clutch cover gaskets, they're waiting at my door! Will be closing that up and adjusting the clutch tonight along with finishing up the rear fender, tail light and turn signals. Then do points ugh, I'm struggling to get a hang of that despite all the reading >:(
  • Youngish
« Reply #1107 on: June 10, 2015, 10:37:07 PM »
Should have installed the new gauge cables before installing the headlight dome >:( Got them on there though.
New horn, cable guide and their mounting hardware. Opened up the horn and it came with its own mounting bracket, so saved my powder coated one.
Installed and cables routed. The clutch cable is through the guide too, forgot the pic.
  • Youngish
« Reply #1108 on: June 10, 2015, 10:48:01 PM »
Clutch cover back on, may have gotten a little to tough on the screws :( but its on there nice and even.
New clutch spring.
Adjusted the clutch following instructions in the manual, and I really hate instructions like "turn till you feel a slight resistance".  I turned it out loose as far as it went, then back in till first resistance, then half turn back again. Got it to a point where it "feels" right and there's just a little slack. The locknut is in place and the adjusting screw sits out about 2 threads proud. Look and sound about right?
Offline Davez134
« Reply #1109 on: June 10, 2015, 10:50:03 PM »
Now that looks right
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #1110 on: June 11, 2015, 07:06:14 AM »
Closer and closer! That tach cable bracket is some shiny!
--Evan
1975 CB750K "Rhonda"
Offline Davez134
« Reply #1111 on: June 11, 2015, 08:53:19 AM »
Is that some sort of corrosion or dirt I see on clutch arm? Unacceptable!? ;D
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #1112 on: June 11, 2015, 09:20:28 AM »
Dave,
Did you also notice the 4 mashed up screw heads????
One above the kickstart and the other 3 around the clutch cable exit point??
He needs to get one of those JIS screwdriver kits from Gordon.  Sheesh.  :)
I think Rafi needs to start over again from the ground up with pictures to make sure this is a good resto.  ROFL
I mean, how can we possibly nominate this bike for BOTM in this condition????  :) :)
Charlie
Offline calj737
  • I refuse...
« Reply #1113 on: June 11, 2015, 10:13:20 AM »
Never fear, Edward will be on of those POs we've all come to hate in how their ham-fisted methods of hacking up a perfectly good bike bring us such frustration.
What a newbie- Can we vote him off this forum? Embarrassing  >:(
Offline Davez134
« Reply #1114 on: June 11, 2015, 11:13:39 AM »
unsubscribed
  • Youngish
« Reply #1115 on: June 11, 2015, 02:09:59 PM »
Holy crap what happened here!? There's NO RUST, that's the gold/yellow chromate shine bouncing off the clear/blue one dude  ;D ;D ;D (I gotta ditch my cell phone and get a real camera).
Everybody, chill, new screws are on their way 8). Hate to say it, but the yami ones are essentially one time use only >:(
I actually used zip ties and fessed up earlier, yet I'm gonna get booed off the forum for some yellow chromate shine and mashed screw heads :o :o  :P :P :P
Some pix of NOS 341 ought to calm things down I hope ;)?
Offline calj737
  • I refuse...
« Reply #1116 on: June 11, 2015, 02:15:29 PM »
Oh! Well, that's very different. Never mind.  ;)
Offline oldhatt45
« Reply #1117 on: June 11, 2015, 02:27:59 PM »
Well, it's been 3+ hours and no 341 pics.
Natives getting restless.  :))) :)))
Charlie
  • Youngish
« Reply #1118 on: June 11, 2015, 02:37:33 PM »
Charlie
Bear with me, us old folks are slow when it comes to heavy boxes :P :P :P :P
  • Youngish
« Reply #1119 on: June 11, 2015, 08:35:21 PM »
Well, ain't karma a b%&$^?. All my old man jokes I bet. Lower back spazzed out after work, things on hold till I can move freely again :( :(
Offline calj737
  • I refuse...
« Reply #1120 on: June 12, 2015, 03:43:49 AM »
Sucks getting old, huh, Young Gun?  :P
Offline Restoration Fan
  • My wife will never call me
« Reply #1121 on: June 12, 2015, 04:09:09 AM »
Rafi, sorry to hear that.  You do know that everyone was just enjoying messing with you because you have done such an incredible job on this bike, right?  Sorry to hear you're going to be down for a while...we'll have to get our bike porn fix from other threads now.
Rest up and get better quickly.
Offline calj737
  • I refuse...
« Reply #1122 on: June 12, 2015, 04:14:21 AM »
That's the problem with the youngsters these days, thin skin and can't recognize the cultural jokes (Rosanne Rosanna Dana).  ::)
I am sorry to hear you're laid up Rafi, ice that back and get well. You have much work left!
Offline oldhatt45
« Reply #1123 on: June 12, 2015, 04:31:08 AM »
Rafi,
Get better soon.
Charlie
Offline evanphi
  • Apparently I'm an
« Reply #1124 on: June 12, 2015, 05:09:32 AM »
Get better soon, from a young'un who also has a bad back...
--Evan
