Author Topic: 1972 CB750 Four K2 -- Rebuilt to NEW OLD STOCK -- PIX ON PAGE 50  (Read 293091 times)
Offline jerry h
Re: 1972 CB750 Four K2 -- Project "Ice Cream"-- ENGINE TEARDOWN
« Reply #350 on: February 17, 2014, 10:04:09 PM »
Hi Ed,
Sorry I didn't go back to re-read everything, but is that bearing bad, or do you have some reason to think its bad?   I know you spent some money to get the special bearing grooves cut etc, but sometimes one can do more damage fixing stuff that's not broken.  Don't ask me how I know this. ;D
Offline Kickstart
« Reply #351 on: February 17, 2014, 11:34:14 PM »
EDIT:   Ah... here you go.  CycleRanger has a post with pictures on how he removed his with a GearPuller:
http://forums.sohc4.net/index.php?topic=97244.0
Thanks Chris, I did see that thread during my hours of searching, and the only problem with that approach is that I already have the cases apart and blasted clean. I suppose I have no other way than to button it back up with the main shaft in and try using a gear puller. Again, thanks for the reply!
Lots of snow yet again, and lots of work, still tearing down and cleaning itty bitty parts here and there as I find time in between. Painfully mind numbing tasks (especially cleaning small parts and electrical stuff), but they're coming off the to do list so no complaints.
I don't think you need to put it back in the case to use the puller... try to find a large socket with an OD that's about the same as the primary gear spline section... but smaller than the basket spline/teeth.  Then put the puller on that to push against.
At least, that sounds good in my head... not sure how easy that would be to do :)
- Chris
75' CB750F Orange flake (rider)
75' CB750F Blue (Project)
75' CB750F Painted black (Project)
No Reserve Racing #171 AHRMA
Offline edwardmorris
  • Youngish
« Reply #352 on: February 22, 2014, 05:15:14 PM »
OK, so few updates to post, I'll start with the micro polished crank. I took it to the shop and they were able to use an electric impact to get the stubborn bolt out, then Gordon's rotor puller worked like a charm to get the rotor off. Took it apart, everything looks good, little to no wear, but that's my novice eye.
  • Youngish
« Reply #353 on: February 22, 2014, 05:19:14 PM »
Had to use the big fat impact driver to get it apart, and notice the flat hammered marks on the countersunk screws. Do I need to impact tighten them? I have it put back together after cleaning.
I asked my machinist if he had a good bearing puller that he could loan me, and he just offered to pull them out for me. I told him about the stuck clutch bell and he said he had tools to get it out. And sure enough, I have it all apart now. How do these gears and dogs look?
  • Youngish
« Reply #354 on: February 22, 2014, 05:21:32 PM »
More. Needle rollers are gone too.
« Last Edit: February 22, 2014, 05:25:40 PM by edwardmorris »
  • Youngish
« Reply #355 on: February 22, 2014, 05:24:22 PM »
Cleaned up the kickstarter and final drives.
While cleaning the alternator, I noticed pic3, is this bolt made of plastic???
« Reply #356 on: February 22, 2014, 10:59:11 PM »
Those gears look happy, no troubles there. :)
« Reply #357 on: February 22, 2014, 11:03:53 PM »
Are you referring to the little plastic "locker" bit on it? Some of the bikes have a little nylon lock nib bored into the side of the bolt. These are sort of like the nylon-lined "locking nuts" you can get for bolts. This feature is interestingly on some of the engines and not others, over their years. The early sandcast engines had some history of loosened bolts that led to electric starter problems (no grip) which then damaged the tapered end of the crank. This was an expensive warranty repair, which led to bigger bolts, then bolts that were Loctited in real tight, and once in a while, bolts with the nylon lock nib in the side of it. That's why they are so #$@! hard to get out.
« Reply #358 on: February 23, 2014, 12:28:36 AM »
Looks fine Ed, as far as your gears go, they look good, but there's no real way of saying that the dogs are OK unless you've ridden it, as they wear pretty evenly. If it continually slips out of gear under power, they're worn out.
You can get them under-cut by most good machine shops, here's a youtube vid for your entertainment pleasure............ ;D
Under-cutting dog gears.
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #359 on: February 23, 2014, 04:45:35 AM »
Ed, those dogs look good to me as well. I don't see rounding, chips, or wear on any of them. Undercutting has it's ugly side too. Forget about finding neutral and shifts require even more pressure to get the dogs to turn loose. The same angles that "pull" the gears (dog ears and holes) together now want to keep them there. That slight friction between the clutch plates caused by the oil transmits small amounts of energy to the gears to load them against the dogs. For the street and non-race use, I would never again have a transmission undercut. Only if every 1/10th second counts and you don't mind killing the engine to find neutral does undercutting really make sense for me. Count on increased wear of the shifter, the drum, and the shift forks too - more force means more wear.
Things are looking good! Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
  • Youngish
« Reply #360 on: February 23, 2014, 09:49:12 AM »
Yikes! It makes more sense that its a nib, I thought the whole bolt was plastic/nylon because at the point of the nib, the zinc plating is starting to peel out, much like chrome in a can spray for plastic toys does. I'll have to remember to tighten this back up lie a #$@! as well, to the right torque.
  • Youngish
« Reply #361 on: February 23, 2014, 10:11:53 AM »
As for the gears, thank you all for the input.
Here are some pix of the countershaft (page 9 of this build thread)
http://forums.sohc4.net/index.php?topic=126735.200
Please review again since its been a while. I am not sure if I need to get it undercut, especially since the cost is prohibitive to just do 1-2 undercutting. I don't plan on racing so I'd rather save the cash for something else.
I'm very glad that the mainshaft looks good (here) and if the countershaft ones look good too, then I'm going to skip the undercutting. Hopefully by using the right weight oil + additives, the shifting will be smooth for a daily rider.
« Reply #362 on: February 23, 2014, 07:41:10 PM »
Of the gears, this was the only one I was concerned about:
http://forums.sohc4.net/index.php?action=dlattach;topic=126735.0;attach=246876;image
This is the C5 gear, the first one out of the countershaft hole. It's mate, the C2 "female" side, has slots to accept the dogs. I see some real shiny rounded edges on it in the photo (hard to tell from pix unless they are close-up and well-lit), and this one is the worst in these gearboxes.
The way to tell if it has an issue is: look closely at the dogs to see how far they engage to the mating gear. It must be 3mm MORE than the rounded edge, or it will have a tendency to jump out of 2nd gear when hot and under power.
The "cheap fix" back in the day was to set the C2 (female) gear flat on a mill and touch up the working edges of the 3 slots to a nice 90 degrees on their working edges, to reduce their taper. This taper is what tries to squirt the dogs back out of the slots under power, especially if the inside of the C2 gear is worn a little, letting the gear tilt away from the C5 dogs when under power. The more complete "fix" is to have the slots back-cut in a slight taper and the dogs similarly tapered to match. This method was called "pull cutting" back then, as you needed to only partly engage them and when the clutch was let out it finished the shift itself. For racing, this was a must past 10k miles or so, but for street use, not so much. It can tend to make the shifting notchy, especially when cold.
In the end, the worst that can happen with badly rounded dogs here is: you may find the need to 'skip' 2nd gear on occasion. I know many 750 riders (tourer-commuter) who did this for years after they bent the L fork in a street contest, but didn't want to tear it all down to fix it. On my own 750, when I got the new oils w/o zinc in them (since 2005 or so), I had to do this in 100+ degree days of traffic myself, even though the dogs on mine are not very worn.
On the flip side, I've also seen round-dog gears that were "fixed" by installing a straight (or re-straightened, but not by me) L shift fork, as the new fork just inserted the gear dogs deeply enough that it passed the rounded edges. This is an adequate fix, even at that. Often the L fork gets a bit bent and begins the whole rounding process by inserting less than 3mm of dog: just check yours with the cases open to make sure the dogs are fully meshing when 2nd gear is being made.
It's pretty easy to measure the mesh depth: spin the C2 gear by hand while slowly turning the drum, until the dogs begin hitting the slots. stop and note the distance between the gears. Then finish the shift and measure how far the C5 continued to move: that's the total insertion depth. Then, estimate the dogs' rounded edge depth (like, 0.5mm or 1.0mm) and subtract that from the total insertion depth. If you get less than 3.0mm mesh depth here, they need some help to be solid. ;)
  • Youngish
« Reply #363 on: February 24, 2014, 08:55:19 PM »
Thanks for the detailed post Mark, I will definitely check it out once I start putting it together (soon hopefully). In the mean time, I'm trying to procure something in better shape than these.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #364 on: February 28, 2014, 08:32:21 PM »
Edward ,here you go
backside
its mate
other side
another
again
last one
Let me know ,I sell all gears $25.00 each plus shipping,will ship for $12.95 Medium Flat Rate Box, so $62.95 total.  ;D Bill
Anyone else needing gears, forks, drums, shafts, got em all! ;D 8) Bill
BentON Racing Website
BentON Racing Facebook
Offline tweakin
  • tear down
« Reply #365 on: February 28, 2014, 08:34:40 PM »
If Ed doesn't take them, I will...  Always good to have solid spares...
    • BentON Racing
« Reply #366 on: February 28, 2014, 09:39:31 PM »
K, you next in line! Got more, if he wants them. 8)
  • Youngish
« Reply #367 on: February 28, 2014, 09:56:52 PM »
Thanks Bill, I'll take them, PM sent!
« Reply #368 on: March 01, 2014, 03:30:25 AM »
That's me, I don't use 2nd on the K0 anymore, it jerks too much.  Just holding tight till I have the F running to tear into K0.
Offline Powderman
« Reply #369 on: March 01, 2014, 11:04:12 AM »
Here are a couple of switch housings I restored ( www.CreativeCandy.org) for Ed. Tuscan Black Matte with Flame Red and Gloss White. Everything is powder on these. Don't know why pic is distorted, click on pic for proper orientation.
« Last Edit: March 01, 2014, 11:50:01 AM by Powderman »
« Reply #370 on: March 01, 2014, 11:08:40 AM »
cool...how did you do the lettering in powder?  What do you charge for something like that?
  • Youngish
« Reply #371 on: March 01, 2014, 11:10:36 AM »
Thanks Marc! I'm blown away! Can't wait for these babies to return home so I can finish rebuilding them.
Offline Powderman
« Reply #372 on: March 01, 2014, 11:11:01 AM »
Trade secret. Actually I just "spoon" the powder into the recesses and wipe it off with a damp finger. I get $35 each to do this.
« Last Edit: March 01, 2014, 11:45:49 AM by Powderman »
« Reply #373 on: March 01, 2014, 11:31:30 AM »
Trade secret. Actually I just "spoon" the powder into the recesses and wipe it off with a damp finger. I get $35 a pair to do this.
not bad at all...I got a metric #$%* ton of ugly faded ones sitting around the shop.  Still can't convince myself to put forth much effort to have a nice set...but if I ever do, I'll be calling you.  Nice work.
Offline Powderman
« Reply #374 on: March 01, 2014, 11:47:36 AM »
I miss typed, they are $35 each (housing), not pair (unless you consider the 2 pieces a pair).
