Author Topic: New guy questions  (Read 1702 times)
Offline nick5446
New guy questions
« on: September 17, 2013, 11:06:22 AM »
Hi guys,
I picked up a basket case '77 CB750A a while ago and I'm finally getting around to getting it together. Rebuilt the carbs, bought new boots, built an exhaust, built out the frame, etc., etc., but I've got a couple of A-specific questions, as I've never owned, or even seen one, before.
The shift shafts...
There are 3 shafts coming out of the left side of the motor. Correct me if I'm wrong, but from back to front they are: kick starter (which I'll hopefully not need), shifter and kickstand neutral lockout thing? If that's correct, I have some follow-up questions.
What's the shift pattern? N at the bottom, then L and D above that?
I don't plan on running a traditional kickstand; what do I do with that forward-most shaft? I assume it's got two positions, engaged and disengaged, right? Rotate counter-clockwise, or clockwise and then leave it alone? I understand the bike needs to be in N when I start it, so I'll just remember to put it in N when I park it.
I think that's all for now...thanks for your help!
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: New guy questions
« Reply #1 on: September 17, 2013, 01:21:53 PM »
Pretty much all of your answers are found in the Owners/Service Manuals - available here for download.
Three shafts are:
Front -> Back
  • Neutral Return (connects to kickstand); gear shift; kick start.
Normal Shift Pattern:
Bottom -> Top
  • Neutral; Low; Drive
Neutral Return Shaft:
  • Rotated clockwise is the kickstand up position.
The Neutral Return Shaft can stay in the one position forever.  It is a safety feature.
The bike must be in Neutral (gear shift) to allow the bike to start.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline nick5446
« Reply #2 on: September 17, 2013, 01:31:07 PM »
Very cool. I think that's exactly what I needed, thanks!
Offline nick5446
« Reply #3 on: September 17, 2013, 01:32:58 PM »
Yeah, I clicked on the link to download the Owners/Service manuals and it brought me to wiring diagrams. Can you post a link?
  • Moderator
« Reply #4 on: September 17, 2013, 06:22:37 PM »
The Admin is changing the site - moving stuff around.  The files you want are now found here:
http://forums.sohc4.net/index.php?action=downloads
Offline nick5446
« Reply #5 on: September 18, 2013, 02:28:04 PM »
Perfect, thanks!
