Author Topic: CB 750 Project 1 - Rides Well but a few tweaks needed  (Read 113508 times)
Re: CB 750 Project 1 - Electricals Done, now the exhaust
« Reply #675 on: October 21, 2016, 02:55:57 AM »
If it's a good fit don't worry about it Tim, a lot of pipes didn't have clamps purely because they didn't need them. The Pipemasters pipe on the cafe racer I'm building doesn't have one for instance, and that's common, they only really need them if they use dissimilar metals, like alloy mufflers on steel headers etc. as long as there's a bracket to bolt your muffler to your frame, that's all you need. Cheers, Terry. ;D
Offline disco
« Reply #676 on: October 21, 2016, 03:50:38 AM »
Hi Tim,
Nice project that you've got happening there.
Can you please elaborate on the comment of cutting of the frame a bit further forward? I have a Weldless kit which i will install very soon so want to get it right.
"Yes there is clearance between the carb linkages and the frame kit, but I wish I cut the frame a bit further forward."
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline timbo750
« Reply #677 on: October 21, 2016, 03:28:31 PM »
Terry, thanks. It is a good fit and is the same material, I just hope its quite enough for a road worthy.
Also can you confirm where the oil vent tubes run. The one from the valve cover goes to the air box and from the rear of the case goes near the chain.  Or do they both go the air box.
Sent from my SM-G920I using Tapatalk
Offline timbo750
« Reply #678 on: October 21, 2016, 03:31:26 PM »
Disco. That comment was made before I realised I had the carb boots at the wrong angle causing the carbs to sit about 5mm too high. I would however still put the clamp near the carbs a bit further forward.  If you want I can take some photos with more detail and and also put up what measurements I would suggest for next time.
Offline disco
« Reply #679 on: October 21, 2016, 04:01:17 PM »
Hi Timbo,
Some more pics & your reasoning/recommendations would be great.
« Reply #680 on: October 21, 2016, 11:02:25 PM »
Hey Timbo, can you remove the baffle? You can buy fibreglass packing material at some auto parts places, and probably hardware stores and boat shops too? The venting changed a bit as the mighty CB750 evolved, but on my early K1-2's, the rocker cover vent hose actually runs over the top of the air box and just vents to the atmosphere, but the bottom hose runs up into the back of the oil tank. Cheers, Terry. ;D
Offline timbo750
« Reply #681 on: October 21, 2016, 11:15:22 PM »
Terry, thanks.  There is no hole for the tube from the rocker cover to go into the air box and I have also people use little vent filters. I didn't expect the tube from the case to the oil tank as they are different sized fittings.
« Reply #682 on: October 21, 2016, 11:19:20 PM »
You've either got an early oil tank or a late engine Tim, or vice versa. I have a K6 engine in my K1, the K6 had the bigger fitting, so I had to make an adapter in my lathe so I could have a small dia hose from the back of the oil tank into the adapter, then a larger hose to the engine fitting. ;D
Offline timbo750
« Reply #683 on: October 21, 2016, 11:20:43 PM »
Thanks Terry, I will work out something
Offline timbo750
« Reply #684 on: October 22, 2016, 08:41:19 PM »
Terry, getting back to the exhaust, the baffle does have 2 screws holding it at the end but I can't get it to move. Must admit I have been a little soft in efforts so I don't damage anything . It almost needs to pulled out but there nothing to grab a hold of.
Offline maduncle
  • Don't confuse me with a
« Reply #685 on: October 22, 2016, 09:40:31 PM »
Tim, can you put the muffler end down on a piece of carpet or some rags and give it a good (but not to hard) tap down onto the carpet/rags? I have done that a couple of times to free up a sticky baffle and get it to then slide out.
As for muffler "wool" the AMX stores sell it - I bought some from the Bayswater store, in sheet form and ready to cut and wrap.
CB750K2 (only slightly modified)
Offline timbo750
« Reply #686 on: October 22, 2016, 10:30:44 PM »
Cliff, will have to try something,  at the moment it is straight through the baffle so I expect it will too load for a road worthy.  Should good though.
Did get some of the shelf fittings to sort the different  vent tube sizes.
Offline timbo750
« Reply #687 on: October 22, 2016, 10:39:14 PM »
Vent tube fitted.
Offline timbo750
« Reply #688 on: October 22, 2016, 10:41:55 PM »
Have another issue now. Was readjusting the rear brake and getting it right befoe the exhaust went on and whilst leaning on the brake pedal to make sure it return to the stop I bent the return spring. Are these springs normally weak/soft or have I got a fatigued spring.
« Reply #689 on: October 23, 2016, 02:30:12 AM »
You've got a stuffed spring mate. Hey that pipework from the top of your oil tank isn't connected to the vent at the back of the engine is it?
If so, you misunderstood what I was saying Tim, that hose from the top of the oil tank just runs down the back and vents into the atmosphere, the small dia hose from the back of the engine should be connected to a similar sized pipe at the back of the oil tank. (at right angles to the two main oil hoses)
If still not sure, do a search for CB750 lubrication system, there are plenty of diagrams out there. Cheers, Terry. ;D
Offline timbo750
« Reply #690 on: October 23, 2016, 02:35:18 AM »
Terry, clearly I misunderstood. I have an aftermarket tune up manual that may show that. I will also order a new spring.
« Reply #691 on: October 23, 2016, 03:46:22 AM »
No worries mate, had you run it like that you would have pressurised your oil tank and you would have had the mother of all geysers of oil coming out of the oil filler, think of James Dean in "Giant" (if you're old enough to remember that movie) and it'd be close. Actually it wouldn't have been that bad, but I do like to dramatise where possible........... ;D
Offline timbo750
« Reply #692 on: October 24, 2016, 02:56:59 PM »
Ordered a new spring for the brake pedal so have to wait before fitting the exhaust. Sorted the vent hoses thanks to Terry. Now that the electricals are sorted the head could finally close up the head light
« Last Edit: October 24, 2016, 02:58:43 PM by timbo750 »
Offline timbo750
« Reply #693 on: October 26, 2016, 02:47:57 AM »
Decided to fit the headers whilst waiting for the other parts to arrive.  Although the exhaust I have looks to be made reasonably well, it doesn't leave enough room at 3 pipes to fit the standard clamps. When attempting to slip them past the frame 1 went past with no issue 2 have caused scrathes in the powder coat and 1 has no hope of getting past. I am hoping now to find an alternative clamp that won't look out of place.
« Reply #694 on: October 26, 2016, 02:54:36 AM »
Hold the clamps over the exhaust ports (you might need an extra pair of hands) and just push the headers into 'em Tim. Cheers, Terry. ;D
Offline timbo750
« Reply #695 on: October 26, 2016, 12:50:22 PM »
Thanks Terry.  That might get one of my kids out of the house for 20 min. Also do you or have fitted oil pressure gauges to your bikes. If so do you know where to get one locally?
« Reply #696 on: October 26, 2016, 01:32:59 PM »
G'Day Tim, any 0-100 psi guage will work, don't use an air compressor guage as it's not designed for rapid pressure fluctuations and if not oil damped, the needle will just fly off. The more difficult issue is finding an adapter to mount it, so really, eBay is your best friend. Cheers, Terry. ;D
Offline maduncle
« Reply #697 on: October 30, 2016, 01:18:14 AM »
Hi Tim,
I bought the Joker Machine oil pressure gauge and adaptor mount, its a good gauge and easy to read from the riding position.
http://www.jokermachine.com/products/cb750-oil-pressure-gauge-assembly.html
« Reply #698 on: October 30, 2016, 01:41:41 AM »
That gauge looks great, if I didn't already have one, I'd buy it myself! ;D
Offline timbo750
« Reply #699 on: November 01, 2016, 10:16:35 PM »
Rear brake parts arrived so that is now all sorted. Found out though that the exhaust is resting against one of the sump bolts. Its hard to know much extra clearance I need,  so I am going to change the socket cap acrew for a hex head bolts which should give me about 1mm. I will also put a little bit of heat on the collector and push it a bit. I don't want to distort the exhaust or weaken it.
Also can someone tell me which kick starter is the correct one.
