Yep, well if you haven't pulled the plates out and cleaned them, and given them a soak in some nice fresh oil they might be stuck together, which is common. They could also be warped (common again) and you could even have a broken clutch disc in there.
When Mike brought his bike over to me there was black clutch fibres all through it, they'd made their way into his crank and blocked the oil holes on #3 journal, and caused the new bearing shells to burn out, along with the cam, rockers, etc, and the bits of clutch even blocked the oil tank, what a fcuking mess!
Yours is probably fine, but it won't hurt to pull the clutch cover off, disassemble all the plates and make sure they're all good, installed correctly, then put it all back together and adjust it, and you shouldn't have any problem lightly snicking it into gear, and changing back to neutral at the lights. Cheers, Terry.
