Have been for a couple rides now. Just local so I can check on things when I get back, a total 38 miles so far and no oil leaks. Did however have a fuel leak out an over flow after about 5min sitting, it was the first time I hadn't turned the fuel off after grtting of the bike.
The clutch seems a bit sticky after its been idling for a bit and struggles to find neutral. It will find neutral when you first pull up.
I am not sure about how noisy these things are supposed to be, I have read about them being a bit noisy at rattle and Jeff comented on that as well, all the chains are all new, I will reset the cam chain tensioner but there isn't much I can do about the primary chain.
There also seems to be a bit of tappet niose at iddle but again not sure how much is normal.
I don't think the carbs are still quite right. It doesn't always return to a consistent idle and occasionally crackles and pops at idle. The exhaust system has what I would call a straight through baffle and has a nice note but would be giving very back pressure which might be part of the problem. It crackles a lot when down shifting.
Out today for its longest ride, meeting up a few from the club and heading down to TT motorcycles annual BBQ.
