Author Topic: New plugs, caps, cleaned carbs, spark on all 4, one cylinder still down.  (Read 679 times)
Offline Buttmask
Got myself a '75 750F.
The last couple weeks any time I would gun my bike hard, cylinder #2 would go out, let it sit overnight, magically it started working again.
My carbs were cleaned 3 weeks ago. And it hopes of fixing this I installed all new NGK plug cap's and threw some denso plugs in. I have spark on all cylinders but number 2 is not firing.
Any theories?
Re: New plugs, caps, cleaned carbs, spark on all 4, one cylinder still down.
« Reply #1 on: September 19, 2013, 03:43:03 PM »
Have spark but no fire?  HUH??
Run it for 2 min, is #2 head pipe hot?
Offline Buttmask
« Reply #2 on: September 19, 2013, 03:44:02 PM »
Correct, not hot on #2, at any point of running time.
Offline Buttmask
« Reply #3 on: September 19, 2013, 04:52:42 PM »
Problem solved I think, carb bowl empty, looks like I have a sticky float valve.
Offline JDS
« Reply #4 on: September 19, 2013, 04:59:30 PM »
Had the same problem a couple of weeks ago.  There was some crud in the T blocking fuel going to that carb.
