Author Topic: Smaller sprocket in front for higher revs !  (Read 2032 times)
Offline Viktor.J
  • Breaking in the forum
« on: September 21, 2013, 02:38:30 AM »
Hi !
I have a thought. Would it be any problem to change to a smaller sprocket in front ?
let me explain why.
I never uses the bikes "full speed" , When riding the highway Im about 4-5000 rpm in fifth gear. These bikes generally goes best above like 3000 rpm and now a days im driving in the city resulting in often rpms below 3000. Therefor I thought of changing to a smaller sprocket in front to rev a little higher at low speed and sacrificing the top speed.
Any problem with this ?
accept the gear chart on the forum is there any where I can quickly calculate the speed at given rpms with different sprocket sizes (without opening my old school books)
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
Offline mAd mOrdigan
Re: Smaller sprocket in front for higher revs !
« Reply #1 on: September 21, 2013, 02:50:06 AM »
We always do this with our newer sportbikes... -1 gear in front and some will also do +2 teeth in the back. Accelerates much better and like you said will sacrifice top speed. But why not just shift later and stay in the lower gears longer.. or am i missing something?
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #2 on: September 21, 2013, 02:55:04 AM »
In a taller gear, you can use a broader range of speed with out needing to down shift due to being a little lower geared. Does this make sense?
I do tasks the most difficult way. My life is interesting.
1978 750K
1978 550K on a table
2009 Ducati Monster 1100
77/78 cool 2 member
Offline Viktor.J
« Reply #3 on: September 21, 2013, 02:59:31 AM »
my "rev window" at low speeds are wuite narrow. 30 km/h in first gear the bike is lugging, 50 km/h in second gear the bike is lugging and first gear around 5500 which is to high for city crusing. By decreasing the sprocket size in front I would widen the window and when driving 30 Km/h in first gear the rev would be at around 3500 and 50km/h in second gear would be around 4000 rpm.
Honda CB750 K2
« Reply #4 on: September 21, 2013, 03:06:17 AM »
Honda originally had a 16 tooth front sprocket but decided it was one of the reasons for chain breakage and went to 17 tooth, might want to think about that
Offline Viktor.J
« Reply #5 on: September 21, 2013, 03:13:01 AM »
18 is stock on a cb750 K2. ( that's what I drive)
It's a god thought, but with a well maintained modern quality chain that wouldn't be a problem, or would it ?
Honda CB750 K2
« Reply #6 on: September 21, 2013, 04:05:19 AM »
Lots of guys go to the 17 tooth on the 750. Not that hard to give it a try and easy to switch back and forth given your riding situation. Should raise the RPM by around 500 compared to the 18 I believe.
« Reply #7 on: September 21, 2013, 08:14:21 AM »
perfect sense
Offline SohRon
« Reply #8 on: September 21, 2013, 08:21:19 AM »
A larger sprocket in back vs smaller front sprocket will net the same results and place less strain on the chain. At least that's what I was told when I asked the same question. Something to consider.
Offline bjbuchanan
« Reply #9 on: September 21, 2013, 02:49:23 PM »
Perfectly fine to switch up the sprockets, tune them for where you ride. Unless you tour a lot the 17 is sounding like the way to go
Offline lucky
« Reply #10 on: September 21, 2013, 10:05:18 PM »
Yes to lower the gear ratios changing the countershaft sprocket to 1 less tooth IS the easiest way.
« Reply #11 on: September 21, 2013, 10:50:27 PM »
17/48 is a good compromise for me. 16/48 is fine around town, but is a bit too low for extended high-speed cruising at speeds of 65-75 MPH in my experience. The smaller the front sprocket, the harder it is on the chain. Chains have a maximum critical speed based on the diameter of the sprocket; my friend and I found out about this fact after his V-8 sidewinder 3 wheeler spit out it's primary chain onto the highway after a quick blast. I just had my book that lists the critical speeds of various chains returned to me, so I will have to look up 530 chain.
« Reply #12 on: September 22, 2013, 05:04:04 AM »
I have a 1972 CB750K2 and a 1974 CB750K4 and they both have 17/48 stock set up. Really is the best way to go as Scottly points out. I can ride on the highway all day with this set up (yesterday was on the K4 for a 364 mile ride to the mountains) with rpms in the 5000-6000 range at 70-85 mph.
In June it was a 3000 mile round trip ride down to North Carolina on the K4 again with no issues on the highway - can pass just fine :). No buzziness/vibrations - helps if you tighten up all those loose bolts once in a while.
When I had the K4 in Europe I was on the German autobahn (no speed limit for most of it) for hours at a time ~100mph for a lot of it with high rpms - again no issues.
Change to 17t on the front you wont be sorry.
Andy
« Last Edit: September 22, 2013, 05:06:49 AM by andy750 »
