Author Topic: STATOR ROTOR REPLACEMENT  (Read 1861 times)
Jimmy V
« on: August 16, 2006, 12:24:27 PM »
Hello folks! I would be the new guy on the blockĀ  ;D
I have a 1982 cb650sc and it looks like ill be changing the rotor on this bugger
do you need a puller of any type to do this or is there a trick too this task?
any help or ideas would be a plus in my book also i found a rebuilt for 145.00 could they come any cheaper?
Offline 82CB650SC
Re: STATOR ROTOR REPLACEMENT
« Reply #1 on: August 16, 2006, 01:06:59 PM »
You need a puller like this.
http://www.pitposse.com/pullerchart.html
#mp17
Check ebay for the parts I got mine for about $60
Bob  1982 CB650SC
Never force it just use a bigger hammer
Offline Pinhead
  • 1979 CB652-ST
« Reply #2 on: August 16, 2006, 01:10:11 PM »
Yeah, eBay is probably your best bet. The 650s from 79 to 82 all use the same rotor. I believe '79 to 82 750s use that rotor as well. Basically if it's a Honda rotor with "slip rings" it'll work. Just make sure the resistance is around 6 ohms.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline 82CB650SC
Bob  1982 CB650SC
Offline scunny
  • don't call me expert
« Reply #4 on: August 16, 2006, 10:32:29 PM »
you don't need a special puller to remove the rotor on a 650. the rotor has a thread in the middle and you can use your rear wheel axle, just put the bike in gear and screw the axle in and the rotor should pop off.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Jimmy V
« Reply #5 on: August 17, 2006, 08:32:38 PM »
OK scunny
you got my ear with this technique would you mind filling us / me in a little slower?
Offline scunny
« Reply #6 on: August 18, 2006, 05:43:48 AM »
ok hope we are talking about the same bit here, the rotor is on the end of the crankshaft. if your bike is together put it in 1st gear and screw your rear axle into the rotor(same thread) mine came out without much drama. I think the shaft is a taper so once you pop it all is sweet.
All credit goes to Haynes manual page 31 with pics
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
« Reply #7 on: August 18, 2006, 08:09:40 AM »
Rear axle trick doesnt work with All bikes as there are only 2 axle threads but 4 different rotor threads (depending on model--all in same model will be same)
