Author Topic: LED blinkers stay solid  (Read 668 times)
Offline Djfob
« on: September 21, 2013, 06:48:24 PM »
Whichever side I flick the switch to they turn on and stay solid. Led brake/running lights work fine.
I have an EP35 flasher setup like this
E - green wire
B - black
L - greyish white
Appreciate any help with this.
78 CB750k
Offline bjbuchanan
Re: LED blinkers stay solid
« Reply #1 on: September 21, 2013, 07:30:32 PM »
I don't know the coding for the flasher but just make sure it is neg for green, pos for black, grey for light/out
Offline matchstikman
  • ask the toecutter! he knows who I am!
« Reply #2 on: September 21, 2013, 08:35:17 PM »
I had a similiar problem when I installed my LED's. I took a quick look at this diagram and found I wasn't grounded correctly. My bikes a 76' 750f. Or you could have a bad relay.
« Last Edit: September 21, 2013, 08:47:46 PM by cptChavez750 »
Stone (1974) Greatest biker movie ever made!
Offline Djfob
« Reply #3 on: September 21, 2013, 10:13:57 PM »
The old grounds for the turn signals in the front. I assume are the green wires attached to the bolt inside the headlight bucket. I cut those and ran them directly to the front turn signals. Not sure if this was right.
78 CB750k
Offline Djfob
« Reply #4 on: September 22, 2013, 07:56:54 AM »
So I was following this but my flasher unit must have been assembled wrong. My earth ended up being +12 input
http://forums.sohc4.net/index.php?topic=124407.0
78 CB750k
