Author Topic: 1976 Honda 550 F  (Read 1291 times)
Offline anji mehra
1976 Honda 550 F
« on: September 22, 2013, 11:35:07 PM »
Hi
A little confused an how to set the float heights. My areas of fogginess are;
1) Is the height as measured from the carb main body where the float bowl sits 26mm or 22 mm.
2) Is the height checked when the tab touches the pin or when the pin is fully compressed against the spring. I cant see any means of checking the actual fuel level
3) Does one need to increase main jet size if using K&N cone filters? Is so, how much
Thanks guys
Anji
Pune, India
Re: 1976 Honda 550 F
« Reply #1 on: September 23, 2013, 12:08:06 AM »
measure from the gasket surface to the lower edge of the float,dont depress the spring just let it touch it.
Offline anji mehra
« Reply #2 on: September 23, 2013, 12:33:30 AM »
Thanx Dave, but need to know if its 22 or 26 mm. Ive seen both on the net
Anji
« Reply #3 on: September 23, 2013, 01:56:36 AM »
22mm.
Offline anji mehra
« Reply #4 on: September 28, 2013, 04:43:47 AM »
Thanx Dave
Offline Bru-tom
« Reply #5 on: September 28, 2013, 09:51:55 AM »
could this help?
make sure, as dave mentions, not to compress the little needle that is circled.i used a vernier as can be seen in the pic.
« Reply #6 on: September 28, 2013, 10:24:25 AM »
Main jet AND slide needle height position.
