Author Topic: Need Carb rack Dims for 77-78k 750  (Read 870 times)
Offline Elan
    • Vital Motor Parts
« on: September 23, 2013, 11:10:08 PM »
Can anyone help me out with this? I need the below dims.  The earlier K's have (A) 37.5mm, (B) 38.5mm, (C) 43.5mm.
I suspect the 77/78k's have 3mm less distance on Dim C, but need to confirm. And if you can measure the outlet OD of a 77-78k carb that would be a bonus!!
As for the head intake spigots, it appears they did'nt change from early k's to late k's huh?
Working on bringing back the 77-78k insulators, so its for the greater good!  ;)
Thanks!
76 750k
Offline harisuluv
Re: Need Carb rack Dims for 77-78k 750
« Reply #1 on: September 24, 2013, 02:14:53 PM »
A: 41.9 mm
B: 34 mm
C: 39 mm
Offline Elan
    • Vital Motor Parts
« Reply #2 on: September 24, 2013, 02:27:47 PM »
Thanks dude!!!
76 750k
« Reply #3 on: September 24, 2013, 02:38:18 PM »
Elan KO. Intake spigots are a different length, shorter I think..
Offline Elan
    • Vital Motor Parts
« Reply #4 on: September 24, 2013, 02:41:02 PM »
ok cool. Im using a mystery head for mockups- I dont know what year its from, but its definately not a KO. Its wierd, where there's usually the model stamp, theres just a "3". The 77-78k insulators fit nicely on it. Just needed to confirm spacing.
76 750k
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #5 on: September 24, 2013, 02:43:56 PM »
interesting.  nice to know this vast difference after i installed my 76 F carbs and rubbers on a 78 F head with no issues whatsoever.
MATT
« Reply #6 on: September 24, 2013, 03:13:37 PM »
If you look from side of head into the fins and see three oblong bars, the head is 73 and up.
« Reply #7 on: September 24, 2013, 07:38:33 PM »
I have a K7 motor sitting under a bench, with the carbs already removed. If you need any measurements of the spigots, like length or spacing let me know.
Offline Elan
    • Vital Motor Parts
« Reply #8 on: September 25, 2013, 05:16:16 PM »
Thanks Scottly! I might take you up on that, just to make sure im working with the right head...
76 750k
Black 750K8
« Reply #9 on: September 25, 2013, 06:29:54 PM »
check your PMs ;)
Offline Elan
    • Vital Motor Parts
« Reply #10 on: September 25, 2013, 07:56:56 PM »
Hey Scottly,
WHen you get a sec, can you see if you have the same dims? Its measured from the inner edge.
Thanks!
 ;D
76 750k
« Reply #11 on: September 25, 2013, 08:10:25 PM »
I'll check tomorrow. You do already have a set of K7/8 insulators to work from, correct?
Offline Elan
    • Vital Motor Parts
« Reply #12 on: September 25, 2013, 08:12:17 PM »
I do, special thanks to Dan (jayhawk)  :)
76 750k
