Author Topic: Battery Negative Lead Connection  (Read 1528 times)
Offline clintcd
« on: September 24, 2013, 09:39:01 AM »
Can anyone tell me where the battery negative lead should connect to the frame/engine, On mine it is connected above the battery box because the incorrect style battery has been used and the lead would not reach to the terminal.
Thank you
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: Battery Negative Lead Connection
« Reply #1 on: September 24, 2013, 05:23:27 PM »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline Mr Freeze
« Reply #2 on: September 25, 2013, 04:15:55 PM »
Typically it's sandwiched between the right upper rear motor mount bracket bolt and the frame.
