Author Topic: Headlight ground wires  (Read 353 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« on: September 24, 2013, 10:46:46 AM »
When I take my headlight out, I see the green ground wires on the headlight bolts. Are they imperative to keep attached there, or can they be disconnected? I would assume they can be disconnected.
--Evan
1975 CB750K "Rhonda"
Offline LesterPiglet
  • 1977 CB550F2
Re: Headlight ground wires
« Reply #1 on: September 24, 2013, 10:57:17 AM »
They are probably for the front signals. Not much point removing them.
Offline iron_worker
« Reply #2 on: September 24, 2013, 11:06:25 AM »
Yes, the signal lights need them. The headlight bucket is isolated to the fork ears by rubber bushings and the fork ears are isolated from the rest of the bike by rubber bushings between it and the forks themselves. This means that the only path to ground that the signal lights have is through those wires.
IW
