Author Topic: What screw to hold tach and speedo cable in place?  (Read 1742 times)
Offline leesfer
  • Noob, learning as I go
« on: September 26, 2013, 02:58:21 PM »
1975 CB750
My bike never came with a tach or speedo cable and now that I am installing them I realize I don't have the screws to hold them into place
Is there a special screw or will something ordinary work to hold them in place?
« Last Edit: September 27, 2013, 09:41:46 AM by leesfer »
1975 CB750
Offline LesterPiglet
  • 1977 CB550F2
Re: What screw to hold tach and speedo in place?
« Reply #1 on: September 26, 2013, 03:02:07 PM »
Cables? Clocks? Be more specific please.
Offline leesfer
« Reply #2 on: September 26, 2013, 03:43:53 PM »
1975 CB750
  • 1977 CB550F2
« Reply #3 on: September 26, 2013, 04:06:29 PM »
So, the screw that attaches the speedo cable to the lower drive on the front wheel and the screw on top of the engine where the tacho cable attaches?
Something ordinairy will work as long as it's metric fine thread (1mm) I believe, and countersunk.
Offline leesfer
« Reply #4 on: September 26, 2013, 05:12:55 PM »
Thanks, are they both the same size screw?
1975 CB750
  • 1977 CB550F2
« Reply #5 on: September 26, 2013, 05:14:38 PM »
I'm not sure as I'm drunk in my bedroom, but I think so.  :P
« Reply #6 on: September 26, 2013, 05:21:36 PM »
No, they are not the same. I got pissed at the speedo screw so I just EZ outed the little bastard  got a hex head at the hardware store. They really only catch a groove so they are not high stress. I think if you go to a Honda dealer site they have parts fiches online and it will tell you the size of the screws.
« Last Edit: September 26, 2013, 06:41:49 PM by BobbyR »
  • 1977 CB550F2
« Reply #7 on: September 26, 2013, 06:05:38 PM »
Any old metric will do then. Just make it fit.  ;D
Not a hard job. I was stuck for a speedo one and knocked something together. Isn't the tacho the same as the engine casing screws?
« Last Edit: September 26, 2013, 06:07:18 PM by LesterPiglet »
Offline leesfer
« Reply #8 on: September 26, 2013, 06:28:44 PM »
Cool, I've got a bunch of bolts, one of them should work in there
Just wanted to confirm it wasn't anything special
1975 CB750
Offline toytuff
  • "watching the pinheads"
« Reply #9 on: September 27, 2013, 04:27:57 AM »
Available from Honda.
tt
 SCREW, OVAL (5X16) speedo.
 93700-05016-0A
SCREW, PAN (5X25) tach.
 93500-05025-0A
« Last Edit: September 27, 2013, 04:32:36 AM by toytuff »
Offline leesfer
« Reply #10 on: September 27, 2013, 09:23:37 AM »
tt
 93700-05016-0A
 93500-05025-0A
Even better! Thank you
1975 CB750
Re: What screw to hold tach and speedo cable in place?
« Reply #11 on: September 27, 2013, 02:25:03 PM »
Another case closed. ;D ;D ;D ;D
