Author Topic: CB 836cc f1 turbo - spoked kickstart street turbo  (Read 81567 times)
Offline TurboD
Re: CB 836cc TURBO ... and lots of other mods!
« Reply #175 on: July 13, 2016, 07:34:24 AM »
How much boost does the stock Kawi 750 turbo make? 5-7 PSI? Sorry if it seems like I'm flogging a dead horse. ;)
The ones I've owned have been 8 to 9 psi.
« Reply #176 on: July 13, 2016, 07:07:48 PM »
Dave, what do you think the minimum gap should be for 65mm rings with 15 PSI boost? My best guess is .016".
Offline TurboD
« Reply #177 on: July 13, 2016, 09:38:26 PM »
Good guess, .016 is what I would shoot for. On turbo and nitrous engines, I will set the top ring end gaps at .006 per inch of bore.
Offline Ilja
« Reply #178 on: July 15, 2016, 05:59:05 AM »
I'm running the kawi up to 20psi... with the stock pistons.
Got it set at 15psi most of the time, as it's already pretty crazy at that boost level.
Lots of people run 15psi without problems on those pistons. :)
And a lot of people install the forged wiseco 810cc turbo kit after they mess up the stockers.
(with 0.065mm piston to cylinder clearance, not wiseco spec.)
I found out Dynoman has a forged 8.5:1 turbokit for the CB750... flat tops like the crusinimage... but quite expensive.
It will cost me around 675 dollars + another 20% on customs to get them to the Netherlands...800 something..  :( :o
The cruzinimage cast ones are only 150 dollars inc shipping and with nothing extra from customs...
I also didn't want to run the increased bore clearance and oil consumption since I ride the bike a lot...im not racing it... and crusinimage pistons are cheap, so I'm going to give them a second chance.  ;)
Should be fine once it doesnt detonate.  ;D
« Last Edit: July 15, 2016, 06:22:52 AM by Ilja »
« Reply #179 on: July 15, 2016, 09:34:22 PM »
I'm willing to bet a beer that the kawi had a lot more than 1500 km's on it before you jacked up the boost level, and likely had greater ring gaps than when it left the factory. ;) I like the idea of high power using cheap pistons! ;D
Offline Ilja
« Reply #180 on: July 16, 2016, 01:29:31 AM »
Ok on with the beer then! ;)
I installed new rings and gapped them according to spec.. bought the engine in pieces and completely rebuilded it with new shells and rings and stuff.
Offline Ilja
« Reply #181 on: July 16, 2016, 09:00:28 AM »
Yay.. closing up the engine at the moment. Spend the whole afternoon removing old gasket material, cleaning out 40yr old oil crud and replacing bearings.
Found my old oem pistons... it looks like they also had some detonation issues.  :o piston looks glas beaded and eroded in some spots.
« Last Edit: July 16, 2016, 09:02:12 AM by Ilja »
Offline Ilja
« Reply #182 on: July 16, 2016, 10:31:06 AM »
Toight chains!
These are the 45 euro per piece audi HD chains.  8)
« Last Edit: July 16, 2016, 01:20:40 PM by Ilja »
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #183 on: July 16, 2016, 12:21:29 PM »
move one of your chains forward 1 link
...Save a tree, eat a beaver...
« Reply #184 on: July 16, 2016, 07:47:35 PM »
Hmm, new rings in worn bores. Gapped according to spec means less than the .7mm limit? ;D
Offline Ilja
« Reply #185 on: July 17, 2016, 12:26:00 AM »
Bores werent worn...not even a bit. I always measure cylinders with micrometer. :)
Offline Ilja
« Reply #186 on: July 17, 2016, 12:28:28 AM »
Case closed.  ;)
Offline Ilja
« Reply #187 on: July 17, 2016, 12:40:07 AM »
Chains are so much tighter then the old ones...9mm shorter. :o
« Last Edit: July 17, 2016, 12:46:34 AM by Ilja »
Offline Ilja
« Reply #188 on: July 17, 2016, 12:45:23 AM »
Heres my kawasaki turbo a few yrs back.... with fckd up clutch... slipped like hell so no wacked throttle here:
« Last Edit: July 17, 2016, 12:47:43 AM by Ilja »
Offline Jim F
  • go baby go
« Reply #189 on: July 17, 2016, 06:42:49 PM »
What kind of waist gate are you using
I need to replace the one that came with
System from ATP
Thanks
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Ilja
« Reply #190 on: July 18, 2016, 01:21:24 AM »
System from ATP
Thanks
Jim
My Honda is using the stock internal wastegate in the garrett turbo, with a 0.5 bar stock actuator.
I'm using a HDI "ball&spring" boostregulator kit with a 2/3 electronic valve to switch between stock actuator pressure and adjusted pressure.
When on adjusted pressure, when the boost reaches the setting the boost seems to peak slightly around 2psi and then smooth out again.. might need some fine tuning but works ok. (btw..Be carefull with these cheap manual regulators, a lot of them are "bleed off" types and don't work.)
My Kawasaki is using an aftermarket 38mm external wastegate of a Nissan Skyline. These wastegates have two connections, one on the bottom and one on the top. If you leave the top one open it runs on stock spring pressure. I've connected the boost reference line to the bottom one and a pneumatic pressure regulator to the top one, so I can adjust the boost pressure... works very stable, a lot better then the HDI regulator. :)
« Last Edit: July 18, 2016, 01:31:04 AM by Ilja »
Offline Jim F
  • go baby go
« Reply #191 on: July 18, 2016, 03:48:11 AM »
I need a replacement waistgate for the ATP system
Are you running the ATP on your Kawasaki?
Does the 38mm bolt up or did you have to make
An adapter
Thanks for your time
Jim
Offline Ilja
« Reply #192 on: July 18, 2016, 10:25:30 AM »
New MLS gasket for the cb... 63pounds via UK inc shipping... (for europe guys ...;) )
Jim.. im running the kawasaki stock system combined with my homebrew turbo system... pipes collectors turbo and everything is made by me so I made the wastegate to fit.
Unfortunately I dont know that much about the atp system... :(
« Last Edit: July 18, 2016, 10:27:12 AM by Ilja »
Offline Jim F
  • go baby go
« Reply #193 on: July 18, 2016, 11:21:34 AM »
WOW very nice
I will have to make some calls to the turbo guys over here
and see what they suggest and thanks for the info
Jim
Offline TurboD
« Reply #194 on: July 18, 2016, 02:57:33 PM »
Jim What is wrong with your ATP gate?
Offline Jim F
  • go baby go
« Reply #195 on: July 19, 2016, 05:37:34 PM »
It's still at the shop were the dyno is
I'll get it home this week and see what's going on
When I turned the screw in I didn't get any boost.
It and the turbo was rebuilt by terry Kizer (mr turbo)
And he said everything was in good shape
So not sure what's going on
Will keep all posted
Offline Ilja
« Reply #196 on: July 23, 2016, 07:40:32 AM »
So I bought this ebc cb750f clutch kit. (Ck1220)
It has 6 normal plates and 2 wide flanged ones with the different profile.
My old clutch had 6 normal ones and 1 wide flanged one...
What should it be? I'm thinking 7 in total and not 8, right?
Offline Ilja
« Reply #197 on: July 23, 2016, 10:19:41 AM »
Got the clutch fitted... seems like the kit had two spiral plates but only 1 was needed. Strange!
« Last Edit: July 23, 2016, 10:22:46 AM by Ilja »
Offline Ilja
« Reply #198 on: July 31, 2016, 09:06:43 AM »
Small change of plans... I now have a F2 head for the turbo engine... yay!
-Valves and especially exhaust ports are way bigger.
-Combustion chamber around valves is more free, no deep pockets.
-Stronger valve springs
-And the chamber volume is around 27.5-28cc versus 21cc on the old f1 head!
This brings me to a compression ratio of 8:1.. which is perfect!
Many thanks to Rob/ Voxonda for helping me!  :)
« Last Edit: August 10, 2016, 10:07:58 AM by Ilja »
« Reply #199 on: July 31, 2016, 09:31:35 AM »
Sounds like an easy solution and an ideal solution with the larger valves.
