Author Topic: 1976 CB500/550 Project "Squirrel"  (Read 298669 times)
Re: 1976 CB500/550 Project "Squirrel"
« Reply #1775 on: August 07, 2018, 04:05:29 PM »
Weld tab to exhaust.  Bolt to passenger peg bracket.  [NOTE: this is not a MGP pipe in the first photo]
You might be able to persuade Chris to weld you a mount tab, or send you one to weld to your pipe.
On my 550
image_zps7yl1pqmu by Donald Leonhardt, on Flickr
On my 750
imagejpg6_zps4ef56750 by Donald Leonhardt, on Flickr
imagejpg9_zps4fa08746 by Donald Leonhardt, on Flickr
photo5_zps2e1a0bc4 by Donald Leonhardt, on Flickr
« Last Edit: August 07, 2018, 04:12:26 PM by SOHC4 Cafe Racer Fan »
Offline riverfever
« Reply #1776 on: August 07, 2018, 08:35:29 PM »
Don't be shy with the questions Tom. There's some content in these 80 some pages but there's also a lot of tomfoolery. I believe Cal uses a spring to help support the end of the exhaust. For some reason, my exhaust hits the swingarm pretty hard (pushes into the side of it). It's not an issue with how Chris made it. I actually think it has more to do with the end pipe needing to be rotated a bit when slipped on the collector but every time I install it the thing ends up exactly the same way. So because of this and because of the front fender (I'll get to this in a second) I needed something robust to pull the exhaust out to the side of the swingarm but also up a bit. Chris says that the pipe is built to be able to run the full front fender. My fender hit the header under hard breaking. He thought the forks needed to be rebuilt and he was right. I installed progressive springs and slightly thicker fluid to stiffen things up and it still hit slightly. I wanted to run his exhaust the day I bought this project but I also wanted that full fender. So Cal's idea was to come up with something to pick up on the back of the exhaust (and this would actually rotate the headers back a bit and give me more room). So this is what I did. I used a hunk of aluminum, shaped it, polished it and mounted it up. It was simple. Here are some pics of it. Let me know if you would like some measurements.
E2BC465E-439A-4B82-91FA-822A25CE6DCC by cneumann2000, on Flickr
AD578A0C-A6C8-4368-BF7D-0B82B42F9870 by cneumann2000, on Flickr
0187B4C6-7D69-42ED-BD0A-AA835DA7C28B by cneumann2000, on Flickr
Offline riverfever
« Reply #1777 on: August 07, 2018, 08:39:07 PM »
Also wanted to point out that, and I think this is the case on all of his exhausts) there is a welded on piece on the back (you can see it in my pics) that is threaded so no need for a tab.
Offline flyinelvis
« Reply #1778 on: August 08, 2018, 06:27:40 AM »
Ahhh yes, I see now.  I can see my idea working (leaving the lower horizontal passenger tube - removing the rest - see pic) as a mounting point.  This may all be moot once I have the rear sets installed (I'm considering Cognito Moto's) and I can probably do something similar to what Cal has suggested.
Yes, my exhaust can has the threaded bung (pic) in place and will afford me some mounting options.
I work in the auto race industry and am a huge believer of proper support of any parts, especially those that vibrate and could initiate a fatigue failure (ie the exhaust studs).
I will be installing a GSXR front end, so I have no idea about possible wheel/fender/exhaust header interference.  Guess I'll cross that bridge when I come to it...
Speed is your friend, but should never be confused with talent.
Follow me on Instagram: @flyinelvis
Offline flyinelvis
« Reply #1779 on: August 08, 2018, 06:40:02 AM »
And while we're talking exhausts, check out this fresh fabrication of a high mount exhaust on my Hawk that was fab'd by one of my co-workers.  A one-off piece of stainless artistry.
Now back to our regularly scheduled programming...
Offline slikwilli420
  • Master of Disaster
« Reply #1780 on: August 08, 2018, 08:21:32 AM »
No way you should ever run something like that just off the exhaust studs. Its just bad fabrication to do such a thing. Here is how I did mine, but I have also seen them go to a bung or two welded to the frame up near the triangle.
« Reply #1781 on: August 08, 2018, 04:47:50 PM »
Agreed.  Why risk broken exhaust studs?!  What a PITA to remove.
« Reply #1782 on: August 08, 2018, 04:48:59 PM »
Love those old Hawks.  Good cheap track bikes!
Offline flyinelvis
« Reply #1783 on: August 09, 2018, 04:54:00 AM »
Lovely pipe there, Elvis. Did he make the mid pipe?
Yeah, I purchased the merge and various elbows and Radar sliced and diced, weaving his magic to curl around behind the rearsets and master cylinder.  Beautiful welds.  One of a kind for sure.  Looks, sounds (Danmoto) great...
Mine was anything but cheap (and definitely not a track bike), probably be in the neighborhood of what I'll lay out on the 550.
This bird is going to have some nice, upgraded Joker LED turn signals mounted up soon!   ;)
Offline BradyN
« Reply #1784 on: August 21, 2018, 09:38:44 AM »
Are those the stock wheels on the Hawk? Great bike, love the color.
1978 CB550K
Offline flyinelvis
« Reply #1785 on: August 21, 2018, 10:11:12 AM »
Hate to derail the Project Squirrel build thread, BUT, the front wheel is a stock Honda 2009-ish CBR600RR (as is the front end) and the rear is a circa 1991 VRF wheel, mounted on a modified stock Hawk spindle (to accept the 4-bolt lug pattern).  Single sided swingarm (an ELF/Honda collaboration) is a work of art.
I have an '07 Honda Element SC (is there a pattern here?) that is the same Root Beer Metallic Brown.  Beautiful color, pics don't do it justice...
« Reply #1786 on: August 21, 2018, 02:13:56 PM »
Ok, back to the Squirrel.  Hey Chris, how are you plans coming for new ergos and wiring?
« Reply #1787 on: August 21, 2018, 03:47:35 PM »
Where is River Dude?  Gone fishin!!
« Reply #1788 on: August 21, 2018, 11:45:17 PM »
School started up last week.  I'm sure he's busy putting together individual lesson plans, meeting with parents, etc.
Offline riverfever
« Reply #1789 on: August 23, 2018, 06:02:19 PM »
I'm still alive. Wish I was fishing. Don's right. School is back in session. It's going to be an interesting year. Our enrollment has been on the rise for the last 5 years and it's worse every year. It's great job security but I've never had my own classroom and I share an office with 3 other people so it's frustrating at times, hard to get anything done, and tough for studednts. We are a 6-8 building and now have a little over 1200 students. Class sizes are approaching 40 and the number of challenging special education students moving into the community is alarming. We allow choice here in CO so if parents want to transport their child to our school and their application is accepted then we take them. We no longer take SPED students by choice because it's impacting the services we can provide to our neighborhood students. I have an enormous amount of behaviors this year. Yesterday and today I ran around all day when I wasn't teaching dealing with a student barking at teachers during class, kids that were MIA (not skipping just didn't know where to go so sitting in the hall or bathroom seemed like a good idea), one that insisted that he wasn't himself but his binder was and demanded the teacher call on his binder, refusals to work, hands on, and more. A new middle school is being built and is scheduled to open next year and then the boundaries will get redrawn and we'll finally get some relief.
I haven't done squat with the squirrel. Depending on the weather, I may start taking it apart over Thanksgiving and seeing if the cables and brake line are still going to work with the 400 bars. Pretty sure I have enough supplies left over to do the actual rewire but still need to order some stuff like the gauge mount and breakout box.
Offline SF
  • I burn gas very well
« Reply #1790 on: August 23, 2018, 08:30:35 PM »
My wife is an ECE and looks for learning disabilities so as to correct/teach them new ways to keep up, focus.
Good on you man.
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #1791 on: August 24, 2018, 10:06:46 AM »
Chris has more patience than I can muster.  I am so glad he is there for these kids.
« Reply #1792 on: August 26, 2018, 06:41:53 AM »
Can understand how busy can be, but you you better ride that bike now when possible.  I was in CO last weekend and it's already getting into the upper 40's at night.   Fall comes quick up there and the snow will be falling soon.
Back in TX, I can't wait for temps to fall....
Offline riverfever
« Reply #1793 on: September 09, 2018, 03:59:59 PM »
Yes....we've already had some snow up high so I'm sure my days are numbered. I'd really like to start installing the new gauge but I also hate to waste any days left with the bike down. The Motogadget mount for the gauge arrived. Today I made a tab to mount the speed sensor.
5D91E1F7-CD74-4150-BE6E-2C9805668FBD by cneumann2000, on Flickr
E56DB091-0FB0-4736-9AAA-9C1179792F70 by cneumann2000, on Flickr
I need to find some small enough washers and then I'll use a bit of Loctite on the sensor threads and it should be fine. Still need to buy a breakout box.
« Reply #1794 on: September 09, 2018, 06:41:33 PM »
What are you going to use to adhere the magnet to the rim?
Offline riverfever
« Reply #1795 on: September 09, 2018, 06:52:10 PM »
I was going to use epoxy.
« Reply #1796 on: September 09, 2018, 08:00:42 PM »
polyurethane glue is stronger than epoxy, just messier when it foams up...
smooth chrome, epoxy...hmmm
 might want to buy an extra magnet(s) just in case.
Offline riverfever
« Reply #1797 on: September 09, 2018, 08:14:48 PM »
I have an extra one that came with the gauge and now I’m rethinking things. I guess I was just thinking that wheel weights are held on so this magnet shouldn’t be difficult. I don’t want to cut the wire for the sensor and find out later on that the epoxy doesn’t work and have to change locations. The magnet is only 5mm in diameter and 2mm tall so maybe it would be smarter to drill the end of one of the rotor bolts and put it in there? At least then I’d have whatever adhesive I use under it and on the sides.
« Reply #1798 on: September 09, 2018, 09:22:19 PM »
Cal does his in the side cover for the front sprocket, very stealthy. But he pops a bolt in the lathe for his magnet and recesses it enough to give clearance. With a drill press you could drill the head of a sprocket bolt or rough it up and attach...provided you have space for the sensor to read the bolt correctly. Looks like a long sensor. Does the magnet have to pass the end of the sensor or can it pass the edge of the end? More room for attaching the sensor without error if the sensor is mounted radially so the magnet passes the end of the sensor but the magnet is 90 degrees perpendicular to the sensor, as opposed to how you were going to have it pass the sensor on the wheel.
David
Offline riverfever
« Reply #1799 on: September 10, 2018, 07:01:41 PM »
I tried this tonight.
7BF57547-593C-4058-A556-F2B669006AE9 by cneumann2000, on Flickr
